Question about Sova DSV32P112 32 in. LCD Television
Reduce screen size
The picture doesnt show the whole picture. How do i shrink the picture? Also, how do I remove the source that stays on the screen?? thanks,
SOURCE: How do I reduce the size of the picture on my PC monitor
try going to page on the top right corner click on that and then click on zoom and make sure the zoom is set on 100%
Posted on May 18, 2009
0 characters
1 Points
50 INCHAdjust picture size to fit screen
Picture size depends on how the program is broadcast to the TV. You can use shrink, letterbox on some tv's to expand a picture but the aspect ratio will be wrong. There is no adjustments if a program is broadcast in standard definition and viewed on a HI definition TV.
Apr 03, 2015 | Flat Panel Televisions
How do I fix this picture to fill my screen on a 16.9 setting
depending on source you may not be able to , it will depend on what your source is ,IE cable , over the air tv , you can go into settings and change the screen size by zooming in , but that will make less of the show (movie ) seen on the set .
Oct 03, 2014 | Samsung Flat Panel Televisions
My wife was cleaning the front of our flat screen tv ....she must of hit one of the buttons on the front of the TV ....the picture went smaller How do i get it back to normal size?
Can't changes tv picture screen sizes,when the tv is off.She is cleaning the tv,when it is off wright?Yes.Than the tv programming u are watching stay small screen size the whole entire times even different seen or in commercials?Tv even in difference tv channels,screen sizes are small too?Sometimes tv changes screen sizes by itself to fit the tv programming it is playing to fit it prgramming format it displaying.Still have all small screen sizes all the tv channels.Tv must be on and playing.U have the tv original remote wright?Yes.Try looking on ur tv remote control look for a buttons said like Aspect Ratio,Picture Sizes,ZOOM or VIEWMODE buttons,by pushing one of these buttons on the remote should able to changes tv picture screen sizes.
Apr 13, 2011 | Insignia IS-LCDTV32 32 in. Television
May 18, 2009 | Sova DSV32P112 32 in. LCD Television
PLTV-32- Picture on screen is larger than TV screen.
if you have HD cable try shrinking the picture there. LCD's are not subject to 'bloom' like
analog tvs. try the aspect button on the remote.
wrong picture size on a digital tv is a result of the input signal.
Apr 05, 2009 | Protron PLTV-32 Television
Polaroid TLX04011C picture is too big
There is a button on your remote control that controls the TV's zoom level. It is usually labeled WIDE MODE or ZOOM.
Jan 09, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Picture too big
there will be a button on the remote that says aspect, or pic size, hit that button, untill you get the size you want, if you cant find the button, go into the menue, click the picture, or video section, and look for aspect racio, or pic size in there
Jan 09, 2009 | Polaroid FLM-4201 42 in. LCD Television
Screene size
Ok this is called Blooming, this is when the signal intesifier becomes overloaded and the signal becomes overenergized and thus unviewable. This is not an adjustable proble even thoug for a time you can force the picture "shrink" but this is not a fix, it just hides the problem. I suggest that you fide a shop on FixYa that can look at you set and diagnose which components are at fault. You can also take the unit to a Tv shop in your area if that is easier for you.
Sep 08, 2007 | LG 17LX1R 17 in. HD-Ready LCD Television
Sova DSV32P112 32 in. LCD Television Logo
636 people viewed this question
Top Sova Flat Panel Televisions Experts
olayoju victor
Are you a Sova Flat Panel Television Expert? Answer questions, earn points and help others
