Question about Zanussi 18 in. ZSF4123 Slim-Line Free-standing Dishwasher
ZSF4126 - where do i put rinse aid!?
I have a new dishwasher ZSF4126 but cannot find where to put the rinseaid. What looks like the well for it in the door actually is a dial with numbers. Any ideas? Thanks
  • daz323 Feb 05, 2008
    hi I have the beko dwd 5410 w I am not sure where to put my rinse aid, I am able to see the dial for the rinse aid amount but unable to see where to put the rinse aid. If any one knows where to add it please let me know.
    thank you in advance
  • 209 Answers
That dial with numbers is the flow rate for the rinse aid, just to the side of that there should be a little hole, it maybe under the flap where you put the powder, open the door fully, open the flap, find the little hole and pour rinse aid in there it should only hold about 1 to 200ml ( a small cup full? ) the dial should be set about halfway hope i have helped if so rate me please
Posted on Oct 04, 2007
Yard sale inside house;
we have everythinq yoh would want to buy;;
livinq room furniture wich includes to small tables.
i king bed with da base;
2 good condition bicicles;
and a lot more;!
areah of Dale city/ woodbridge,
call for info or adresse; 571-288-6523
Posted on Mar 05, 2008
SOURCE:
Dishwasher cloudy glasses
I do not have enough information to be able to answer with hundred percent certainty.
From my experience, the most common problem is the improper handling of the appliance. Driven by overwhelming commercials we often pass from detergent to tablets. The largest number of tablets contains rinse aid that we already have in the dispenser. Practical adding a double dose of rinse aid resulting in poor washing results and glasses look like washed in milk. The solution is to open the dispenser and put the dosage rinse aid to minimum. In electronic dishwashers new generation is even possible to completely exclude the dosage rinse aid if you are using tablets.
Dado
Aug 26, 2014 | Indesit Dishwashers
KitchenAid Dishwasher Rinse Aid Clogged w/ Detergent
have you tried distilled vinagar? this may work for you.
Jul 29, 2009 | KitchenAid 24 in. KUDI01IL - Multiple...
My dishwasher uses a compartment of rinse aid each wash
The cheapest and easiest option is to stop using rinseaid and use an allinone tablet instead.
Jun 14, 2009 | Bosch Dishwashers
Dishes never come out clean
Sounds like not getting sufficient water. Replace water valve if that's the case.
Nov 14, 2017 | Whirlpool 24 in. Built-In Dishwasher w/...
F&P double dishdrawer
sounds like the rinseaid cap' may not be sealing. I'd try swapping the caps over to see if this fixes the problem if so you need a new cap if not you need a whole new dispenser cheers
May 15, 2009 | Dishwashers
I want to change my rinse aid product
run it through a couple of empty washes or use it just to wash dishes without rinse aid. this should allow you to add rinse aid into the container after each wash there after just add more rinseaid. it could take a while to get full rinseaid coming out but eventually there should be only rinseaid in the container.
Apr 10, 2009 | Maytag 24 in. DWU7402 Built-in Dishwasher
Put rinse liquid detergent in dishwasher rinse aid compartment.
I did the same thing with my Maytag dishwasher, several times actually, before realizing I was putting blue dish soap in the rinse aid compartment which then wouldn't empty. Then my Maytag started making ominous noises during the rinse cycle (appliance guy said it was "cavitation" noise).
Appliance guy wanted to replace the whole detergent/rinse aid compartment but since he told me the noise was probably caused by the dish soap stuck in the rinse aid compartment, I decided to try to get rid of it first. Here is the method that worked for me; it took most of a day but saved me parts & labor:
1. Get some white vinegar--I used nearly a quart.
2. Fill the rinse aid compartment to brim with the vinegar (overfill) but don't put cap on
3. Raise the dishwasher door slowly until the vinegar drains into the lower part of the chamber (at least this is how my Maytag worked)
4. Agitate the contents as best you can by rapidly shaking the dishwasher door up & down.
5. I also used a small plastic medicine dropper jammed into small openings on each side of the rinse aid compartment to agitate the vinegar by squeezing air into them.
6. Drain the compartment by closing the dishwasher door (move it to full vertical)--vinegar will drain into the bottom of the dishwasher.
7. Repeat above steps a couple times, then fill again w/vinegar, put the cap on and let it stand for awhile. Then drain and repeat the whole routine several times.
8. Blue-colored vinegar will come out which is a good sign (or whatever color your dish soap was).
9. After awhile, I started pouring generous amts of very hot tap water thru the rinse aid compartment, alternating with white vinegar. (No reason you can't use hot vinegar also.)
10. Eventually, all the blue stuff came out & the see-thru levels of the rinse aid compartment were completely clear/empty.
11. Run the dishwasher (I decided to not put any rinse aid in). I got some overfoaming (from the washed out soap) the first time I ran it which I probably could have remedied by adding more vinegar & possibly salt, but the noises were gone!
I just ran the cleaned out dishwasher a 2nd time & it was back to its quiet self with no overfoaming.
Takes some patience but hey, beats a big repair bill!!
Apr 04, 2009 | Kenmore Dishwashers
Rinse aid leaks into the dishwasher when the door is closed
sounds like acrack in ht eseal of hte dispensor itself, replacing the dispensor is the remedy
Nov 13, 2008 | Kenmore 24 in. 15652 Built-in Dishwasher
My glasses have started to get a cloudy film on them that I can't wash off
are you using rinseaid?
rather than using all-in-one tablets, better to use seperate powder detergent and rinse aid
Aug 05, 2008 | Bosch Dishwashers
Zanussi 18 in. ZSF4123 Slim-Line Free-standing Dishwasher Logo
2,249 people viewed this question
Top Zanussi Dishwashers Experts
Paul Carew
Archie Ferrarini
Archie Ferrarini
Renee Knafel-Bullock
Are you a Zanussi Dishwasher Expert? Answer questions, earn points and help others
