Question about Jenn-Air SVE47100 Slide-In Electric Kitchen Range
Jenn-Air stove locked
I put my Jenn-Air stove on the clean cycle and when it started to beep 1 hour into the cyle, I hit cancle. Now the stove is perminatly locked and I can't get it to open. It is not heating. I turned it off at the circut breaker, and that did't work. I also tried to restart the cleaning and it just beeps "F5" at me. Help! How can I get the stove to unlock?
  • 5 more comments
  • leaolen Nov 19, 2007
    Yeah - except that ours shows "F!" on the display, and the door also will not open. In addition, the fan is on a low bow level.
  • Anonymous Nov 21, 2007
    I have the same problem. We turned off the power, unplugged it and it is still locked. HELP
  • Anonymous May 12, 2008
    I have finished with the cleaning prosess the oven has been cooled for two days. The door latch will not open. I can see into the oven.
  • Anonymous May 16, 2008
    Same problem! Set it to clean, now it won't open! What do I do?
  • Anonymous Dec 23, 2008
    I had the same problem so I called a repair man and he charged me $75 to open it it. Now it won't lock and I can't clean it
  • txrennie Dec 30, 2008
    The oven can be heating and running for some time and it turns it self off and the lock button comes on and the door locks
    Sometimes in the middle of the day for no reason been off for a day and the fan comes on and the door locks. YOu can hit cancel enough times and the door will open and it not hot or heating. sometimes this stops sometimes you have to leave the door open for long peroids of time or it will do it again,
    I don't have an owners manual.
    We have cut off the breaker for 24 hours and it did not reset itself.
  • fleming931 Jan 08, 2009
    I have the same problem. I put it to self clean and now the lock keeps going on and off and I can't turn on the oven. HELP!
I tried pulling my oven out so I could unplug it and the door just popped open and the codes stopped beeping....
Posted on Dec 01, 2007
  • 114 Answers
Check the trouble shooting section of your owner's manual for your various fault codes. It may point you in the right direction as to your next course of action.
Posted on Oct 05, 2007
SOURCE:
Whirlpool range self cleaning oven door won't unlock after the cleaning cycle was done. gets error code -f5-
I took the back off the stove and manually moved the door locking mechanism to unlock the door. Then started a cleaning cycle untill the door locked. Cancled that cycle and the door unlocked just fine.
Seems OK now.
Oct 15, 2009 | Ovens
My jenn -air self clean over just beeps when i hit clean
Before you go working too hard to get you oven to go into the self clean (self destruct) mode....check out this tip...
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! "
May 31, 2009 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
Stove door locked and continues to beep and flash code F9
The F9 code indicates there is a problem with the door lock.
Try disconnecting the power to the range for 10 seconds and reconnecting. Open the oven door and hold the door switch plunger in while you try these things. Put the control into clean for 5 minutes then cancel clean. You must hold the door switch plunger in for the 5 minutes.
Try canceling the clean cycle without putting the control into clean.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question$$%^^%$
Mar 27, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
I need direction on how to start the clean cycle on my jenn air
CLEAN PAD
Use to set a self-clean cycle or a delayed
self-clean cycle. One press of the Clean
pad sets up an immediate clean cycle. A
second press of the Clean pad sets up a
delayed clean cycle.
• Clean oven
frame, door
frame (area
outside of gasket)
and
around the
opening in the door gasket with a nonabrasive
cleaner such as Bon Ami*. These
areas are not exposed to cleaning temperatures.
• Remove air grille.
• Remove oven racks. If racks are left in
during a clean cycle, it may impair function
and they will discolor. Turn off the
oven light and close door.
* Brand names for cleaning products are
registered trademarks of the respective
manufacturers.
TO SET FOR IMMEDIATE START:
1. Press Clean pad once.
2. Press the Auto Set pad for 3 hours of
cleaning time, press again for 4 hours
and again if 2 hours of clean time are
desired.
3. CLEANING and LOC plus the clean
time will appear in the display.
4. When the clean cycle is complete,
CLEANED will be displayed. LOC will
remain on until the oven has cooled
(approx. 1 hour).
5. When the oven is cool, LOC will no
longer be displayed and the door may be
opened.
6. Wipe out the oven interior with a damp
cloth. If soil remains it indicates the
cycle was not long enough.
TO CANCEL SELF-CLEAN:
1. Press Cancel pad.
2. If LOC is NOT displayed, open oven
door. If LOC is displayed, allow oven to
cool.
Thanks for using Fix Ya, Please take the time to rate this solution.
clarkco
Feb 08, 2009 | Jenn-Air JDS9860A Dual Fuel (Electric and...
I have a Jenn Aire SVE47100 that keeps beeping
my stove did the same thing. I turned on the downdraft fan and it quit. I think it overheats the board when you are baking. try it and see if this helps.
Jan 02, 2009 | Jenn-Air SVE47100 Slide-In Electric...
After the lock indicator light goes out, move the door lock lever to the left. The oven door can now be opened. Turn the selector and temperature knobs from clean to off AFTER THE DOOR IS UNLOCKED. If the temperature knob is turned to off BEFORE the door is unlocked, the door will not open. Forcing the lock will damage the lock mechanism. If this should happen, return the temperature knob back to CLEAN, unlock the door, THEN turn the temperature knob off. Source(s): Jenn-Air Grill Range with Self Cleaning Radiant Bake and Convection Oven models S136, S156, S161
Dec 10, 2008 | Ovens
Jenn-Air S160
I did it by mistake. I tried to move the lever over and of course, it didn't open but went to restart. I hit the cancel button and then tried the door again and it opened. Yup, we all here feel likes dorks!
Thank you!
Sep 06, 2008 | Kitchen Ranges
My stove is saying f9 and constantley beeping what do i do
If you hit clean Button, try to Cancel it.
If it's beeping... and see F9, I tried to push in the door... and the "lock" was clear..... and the door was opened.......
I thought i will share this w/ you...
Jun 17, 2008 | Jenn-Air JES9800A Electric Kitchen Range
Clock assembly
my automatic cleaning setting in my oven will not heat up. I set "clean" on both dials and put the lock on, the fan comes on but no heat. Is there a certain system to turning it all on and the timer so it will work?
Mar 21, 2008 | Jenn-Air SVE47100 Slide-In Electric...
Jenn-Air SVE47100 Slide-In Electric Kitchen Range Logo
692 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Thomas F. Schneider
Paul Carew
Ismael Rodriguez...
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
