Picture failure Tv will not work. While watching tv color would sometimes fade in and out. During the last couple of days the picture would come in but the screen would turn green and picture disappears, also tv would somtimes turn off. Now screen is just green and you see no picture or not very clear at all.
  • 4 more comments
  • Forza1 Nov 03, 2007
    COLOR FADED IN AND OUT...UNTIL NOW, IT IS A CONSTANT BLU/GREEN.
    Model # is AV-48WP34. This tv is only 4 years old. Any suggestions?
    Thanks...
  • erinnorman Dec 08, 2007
    I have the same problem with our panasonic hd plasma. The screen all of a sudden turned green. We can hear the sound and use the dvd player perfectly. The model number is TH-50px60u. It is a Panasonic viera? Viesa? June 2006.
    Any help?
  • wishIhadnt Jan 01, 2008
    KDF-60XS955--started getting horizontal green lines and now sometimes the whole screen is green. I can see the picture, but everything is green for a while.
  • robertstri Jan 23, 2008
    I've got the same problem here. Mitsubishi WS-55511. Green horizontal lines arc accross screen, it fades to a washed out green color. Picture is still there but really washed out. This has been going on since the TV was about 1 year old. From what I've read on the internet it seems to be a VERY common problem. Service techs must now about this one. Is it worth fixing or do I dump this piece of technology.
  • CatyandCoug Mar 30, 2008
    Our Mitsubishi 48515 just went ALL green and within minutes powers off. Trying to turn it back on only results in the same pattern; all green and powers off. Trying to QUICKLY use the remote to change settings is difficult since the screen is all green and you can't SEE the selections very well. By the time you go to make a selection change, it powers off! Obviously it's turning off as a protective measure. I've unplugged it and am hoping that once it cools down it will be back to normal. I may use a "system reset" on the front panel to see if that helps. Any other suggestions? Caty
  • hpham2211 Dec 14, 2008
    I HAVE SAME PROBLEM ON MY TOSHIBA DLP 72HM196.
    President:
  • 3,130 Answers
Do not have a clue without a model number and make. Are we to be fortune tellers here too?
Posted on Oct 05, 2007
I have a 55 Vizio 3D smart tv. This picture color fade in and out to the point that I cannot watch tv. I this a problem with the main board?
Hello Patricia,
  • There is a loose soldering connection in the Main Board. That happens because the components on the are generating a lot of heat therefore melting solder connections.
  • Stop beating on the TV's back, that only makes the problem worse.
  • Take it to a shop.Or if you are a tech, try locating the loose connection(s) and solder it back.
  • Also check your Warranty Period, It may cost you 0$. Call Vizio if you still have Warranty on the TV.
Here is a link to Vzio Supoport.
Good Luck,
JP
VIZIO Product Support and Services VIZIO
Jun 25, 2015 | Vizio M3D550KD 55 inch Class Razor LED...
Color
U hear grinding noises,squiling noise,before colors fades in&out,turn to Black&White picture,than died?Yes,than ur DLP tv have a colors wheel,it defective,require replacing.The colors wheel is spinning off of it motor axis.The tv tech,should be hire for changing the tv colors wheel.
Jul 24, 2010 | Sharp 65DR650 65" Rear Projection...
Sometimes has green tint.
YOU ARE 100% CORRECT it is the cameras ....... as a tv camera wears out green is the last to get weak . so the picture turns green crt tvs do the same thing
Mar 25, 2009 | Sony Televison & Video
Color in picture only good in 4 corners
i think it is a magenatic effect called degaussing problem. please remove anything very near to it which has got magnet like speaker headphone etc. call tech to gegauss it. it is hardly 5 minutes job. please do not change the angle while watching tv. your tv seems to be 100% ok. good luck.
Oct 05, 2007 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Color fading to black and red "nightvision" picture
We have a 60" panasonic rear projection television and the color fades in and out. What do you think is the problem the tv is only two years old and is now starting to apear in black and white sometimes. What can be the problem?
Oct 03, 2007 | BenQ PDP-46W1 46 in. HD-Ready Plasma...
Our Color TV is now Black & White
It could be the color wheel and in fact probably is. I've seen them shatter which would explain the noise. They are glass and spinn at 9000 rpm. An involved repair though definatley a job for a pro. It could be worse, probably a few hundred will do it. Was the TV begining to be a little loud before the failure? Could be a sign, i've seen many noisy color wheels.
May 23, 2007 | Samsung HLN617W 61" Rear Projection HDTV
Sony KV-24FV12 Image intermittant Blackout
Hello Robert, the picture tube on your TV set is exausted. Please contact your nearest Authorized Sony Service for further help/advice. After all, Sony is a good choice. The next TV set you buy could be one of Sony-s Bravia LCD. Kind regards, Arpad
Dec 20, 2006 | Sony KV-24FV12 24" TV
No colors
sounds like a leaky cap or bad solder connection
Dec 04, 2006 | Panasonic CT-27G23 27" TV
Doesnt turn on
Good day.
Try to check for the fuse along the units power supply and loose connections.
chris
Nov 21, 2006 | Sharp 25K-M100 25" TV
Televison & Video Logo
453 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
