Question about Hoover S2105 Slider Bagless Stick Vacuum
Problem with Hoover slider
This slider seems not to hold the charge as long as it should. The big problem is that when trying to recharge it, the red light doesn't stay on and if I move the plug around at the plug in site on the machine itself, it won't stay on. It seems like the plug does not fit tight into the machine. Anyway, it will not charge. I would appreciate any help you can offer me. If I need to get another cord, where can that be purchased?
    President:
  • 1,673 Answers
If it doesn't charge, the problem may be the batteries have gone bad.
Posted on Feb 17, 2008
SOURCE:
When I release the red bar to Hoover the section that holds the bush bar won't lie flat to the floor? Any ideas on how I can fix this?
I would disassemble the hinge section and see what is causing the problem. Sounds like something has either broke or gotten caught in the hinge mechanism.
Feb 04, 2015 | Dyson DC25 All Floors Bagless Upright...
Replace a battery in a Hoover jovis
I checked some reviews of this product, and one mentioned, (QUOTE), They called Hoover and asked to asked to buy a replacement battery, and guess what? They don't make one available. (UNQUOTE)
I only found that it just has to be recharged very, often.
When a Company puts out a bad product, across the board, explain to them your dismay, & ask for your money back. I have personally gotten products that didn't work, replaced, and they even sent me a shipping label to send to bad one back. Since this particular product has such bad reviews, tell that to the Company, and maybe you can get your $ back. Don't give up, there ARE Great Companies out there, still!
Sep 17, 2014 | Hoover Jovis Sj96co4 Bagless Rechargeable...
Hoover linx
How old is your battery? and did you keep it on charge when it was not in use?
Most rechargeable batteries require a spindown, where as you completely discharge the battery before recharging it again.
I know you aren't wanting to hear this but in all probability that battery is spent and will need to be reconditioned at a battery place, however, it will cost almost as much as a new one it would be your call.
if you have a ohm/volt meter it might be possible to look at the charger and get a volt/amp reading and then test it see if it is putting out the proper voltage it could be putting out a trickle charge and it would take forever to charge it.
there is one other situation to look at and if the beater brush or motor is causing a resistance it will pull a battery down quick.
I do not own this vaccum so I can only guess as to the possibilities.
Jul 02, 2014 | Hoover Platinum LiNX Cordless Stick Vacuum
Hi, my Dyson DC16 works fine but after removing from charge base following recharge the red and green lights remain lit and the unit will not operate until i remove the battery and reconnect to vacuum,this...
If it is within the warranty period get Dyson to replace it. If not, live with it until it fails completely, then buy a Hoover. Your computer board is starting to fail. That's not repairable.
Aug 06, 2017 | Dyson DC16 Root 6 Bagless Handheld...
Oreck Electrikbroom (battery) won't hold charge and pick up dirt.
Battery needs to be replaced. All rechargeable batteries have limited recharge cycles. NiCad's are usually used in these and also develop "memory' which keeps them from recharging fully.
Contact Oreck or reputable dealer for replacement.
Nov 15, 2008 | Hoover Floormate H3000 Upright Wet/Dry...
Power switch will not work
Hoover U6437-900 U6439-900 Windtunnel Upright
seems there is a short in the power switch, is that possible, I have it disassembled and seems there is power going into the on/off button, but will only sporadically turn on
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
This could be a defective switch or it could be a loose connection or wire – chances are that it is a defective switch and needs replacement – this could be a slider switch of which does wear out and that is why it will comes on sporadically – if there is a local vacuum cleaner shop in your area they can test the switch and possibly sell you a new one
http://www.hoover.com
Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Apr 02, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Rechargeable battery does not recharge
They are nickel cadminum batteries, and are replaceable, you may have to order from a repair shop, or go thehooverstore.com. Once you have the battery pack out, maybe you can find them like at Radio Shack or other places that sell these type packs,
Oct 15, 2007 | Hoover S2105 Slider Bagless Stick Vacuum
Hoover S2105 Slider Bagless Stick Vacuum Logo
110 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Kirk Thompson
Level 1 Expert
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
