Question about Sony PlayStation Portable (PSP) Console
Control stick eternally up!
My control stick on my PSP suddenly stopped going in any direction except up. It has become the neutral position even if I don't touch it.
    Scholar:
  • 143 Answers
Use a flat object to pop off the pad, clean around it & replace it. if it still sticks turn it round.
Posted on Dec 17, 2007
Why won't My 2000 Lexus es300 go into reverse or neutral?
Probably the stick that control your transmission has moved. It's not sync. I recommend that you take it to a specialist.
Sep 07, 2014 | 2000 Lexus ES 300
Hello sir..or who it may concern........while playing my psp or while going to my home page it suddenly goes to most left and then i cant go anywhere it stays right there.please tell me what to do...
I would suggest restarting the system. Shut down the PSP, remove the battery, let it stand for a minute or so, put the battery back in place, start up the PSP. When the PSP is starting, do NOT touch anything. Moving the control could cause the PSP to assume that moved position is the neutral base position. If this does not fix it, contact Sony directly.
May 28, 2011 | Sony PlayStation Portable (PSP) Console
I can't get any game to work. We used to be able to wiggle the game or take it out and put it into the console on a different angle, but now it won;t work at all. The power light still comes on on the...
Note: It is possible that the problem you have may be game play related. For example, if you cannot defeat a particular enemy, or are missing an item you need to complete an area, the problem is likely game play related and there is nothing wrong with your game. Please check our game play help for assistance.
  1. Insert the Game Pak into the system. The Game Pak label should be facing the front of the Nintendo 64.
  2. Make sure the Game Pak firmly clicks down into place.
  3. Remove all accessories (with the exception of the N64 Expansion Pak) to see if the Game Pak works correctly without the accessory. If the game does work correctly once the accessory is removed, then the game pak and the accessory may not be compatible. Check the game pak instruction manual.
  4. Check the instruction manual for the game to see if it requires any special accessories, such as the Expansion Pak, to operate.
  5. Check the list of specific game issues to see if there are any known problems for the game you are playing.
Due to the age of the system, we no longer offer factory repairs directly from Nintendo. Please click here to find out what options are available for repair or replacement of your product.
  • Controller Error Messages (e.g. No Controller Detected)
    1. Make sure you are using all licensed accessories with your system. Make sure both the controller is licensed and any accessories you are using with the controller (Rumble Pak, Controller Pak) are licensed as well. Unlicensed products may not be fully compatible with our systems.
    2. Slide the Power Switch on the control deck to the OFF position and unplug the controller. Plug the controller back in, making sure the controller-plug is firmly inserted into socket one (on the left front ofthe control deck). Slide the power switch on the control deck to the ON position.
    3. If possible, try another controller in the left-hand port. If you have a second controller, repeat Steps 1 through 3. If the trouble disappears, the first controller may need to be replaced. For information on locating replacements for older products, please click here.
  • Character Won't Move or Moves on its Own
    1. The most common cause of this problem is when the control stick on the controller is not in the neutral position when the N64 system is turned on. The neutral position is when the control stick is centered, as it is when you hold the controller while not touching the control stick. Recalibrate the Controller by using one of the following methods:
      • Turn the power off on the system. Make sure the control stick on the controller is in the neutral (center) position, and slide the power switch to the ON position. Be sure not to touch the control stick for the first few seconds.
      • During game play you can press the L+R+START simultaneously while the control stick on the controller is in a neutral (center) position.
    2. Consult the Game Pak manual for information on the primary directional control for the game. Some game paks use the control pad rather than the control stick for character movement.
    3. Try cleaning the controller (See Below).
    4. If possible, try another controller in the left-hand port. If you have a second Controller, repeat Steps 1 through 3. If the trouble disappears, the first controller may need to be replaced. For information on locating replacements for older products, please click here..
  • N64 Sticky Buttons or Control Stick, or other controller problems Try the following cleaning procedures:
    1. Unplug the controller from the control deck.
    2. Get a clean toothbrush (no toothpaste) and a cup of warm tap water (not too hot). Do NOT pour or submerge the controller in any type of liquid.
    3. Slightly dip the toothbrush in the water (the toothbrush should not be dripping wet) and scrub the area of the controller around the buttons and control stick.
    4. Work the bristles down around the sides of the buttons and the control stick.
    5. After cleaning the controller, dry it off with a paper towel.
    6. Let the controller air dry for at least a couple of hours.
    7. Test the controller for proper response.
    If possible, try another controller in the left-hand port. If you have a second controller, repeat Steps 1 through 7. If the trouble disappears, the first controller may need to be replaced. For information on locating replacements for older products, please click here.
Transfer Pak
  1. Verify that only licensed accessories are being used with the system. Unlicensed products are not fully compatible with Nintendo systems, and may not work correctly.
  2. Check the game pak manual or packaging to verify that the game is designed to be used with the N64 Transfer Pak.
  3. Make sure the Game Boy game pak works properly in a Game Boy system. It may be a problem with the Game Boy game pak and not the Transfer Pak.
  4. Verify that the game paks are inserted in both the control deck and the N64 Transfer Pak. If they are not, insert them and then turn the control deck power off and back on again.
  5. Verify that the controller is plugged into the proper controller socket on the front of the control deck. If it is not, secure it and then press reset on your control deck.
  6. Remove and re-insert the N64 Transfer Pak, making sure the pak is fully inserted into the bottom of the controller. If it is not, secure it and then press reset on the control deck.
  7. If possible, try another controller. If the Transfer Pak works in another controller, it may be the controller that is having a problem. Check out controller troubleshooting (click here).
If the issue persists, the Transfer Pak may need to be replaced. For information on locating replacements for older products, please click here.
Controller Pak
  • Deleting Saved Information From Controller Paks Depending on the game you own, there are a couple of different ways to delete the saved information on a Controller Pak.
    1. While turning on the Control Deck, hold down the START button on Controller #1. If the programmers utilized this feature, a Controller Pak menu should appear. This menu will allow you to view and delete the contents of the Controller Pak.
    2. If the first option doesn't work, then the game pak will have a feature that can only be accessed from a game menu. For example, in Wayne Gretzky's 3D Hockey, you delete saved info from the Options screen.
    To find out the specifics of how the Controller Pak works with a particular game, check the game's instruction manual.
Expansion Pak
  • For assistance with installing the Expansion Pak, click here.
Jan 19, 2011 | Nintendo 64 Console
My psp keeps sticking, the control sticks down even if I move the control
you need to be expert for that ..........
any way if you are in great hurry then
you can do this with out having much technical knowledge
download this repair guide each and every thing regarding psp is given in such way that even a 3rd standard student can understand every thing
click here to fix
Dec 14, 2010 | Sony PlayStation Portable (PSP) Console
Runs only in reverse i have other pre war 1681e does the same
Have you changed transformers? You can also make a Lionel run in opposite direction by using the throttle control...just go to stop and then to power and then back to no stop and right to power. That often works.
Apr 30, 2010 | Lionel Trains 51009 Prewar No 246e O Gauge...
My psp joystick is having a problem.... the guy in the game is still going foward, but im not controlling it...even if i do it will still run foward it happen to my old psp before and then i threw it in...
dont throw this one in the trash. your analog stick on the psp is stuck in the forward position. just take your analog stick off and replace it to where it is centered.
Dec 14, 2009 | Video Game Consoles & Games
Dual gate Hurst shifter adjustment
Hello! Here is what I was able to track down:
Hurst Dual Gate Shifter Assembly Parts Breakdown:
Removing & Replacing The Hurst Dual/Gate
1. Disconnect car battery.
2. Remove Knob. Remove four Phillips head screws that hold escutcheon plate down to console.
NOTE: SHORT SCREW IS USED IN REAR RIGHT - HAND HOLE. Remove escutcheon plate and console from floor tunnel.
3. Lift selector indicator lamp housing out of shifter and pull bulb socket out of lamp housing. Disconnect wire connectors from combination Back - up light / Neutral safety switch.
4. Remove two 1/4 - 20 x 1/2 hex-head cap screws that fasten Dual / Gate shifter to rear mounting bracket. Remove 1/4 - 20 x 1/2 hex - head cap screw that holds cable bracket to shifter frame. Remove two #10 - 32 x 3/8 slotted head cap screws that fasten Dual / Gate shifter to front bracket. Free shifter from cable by removing cotter pin and washer.
5. Remove combination Neutral - safety / and Back - up light switch. Install switch on Replacement unit.
6. Install replacement shifter unit in reverse order of removal of original unit.
7. ADJUST CABLE: SEE FIGURE 1 (Below)
Loosen nut that fastens cable pin to transmission control arm. Loosen nut enough to allow pin to slide in the slot in the arm. Turn the arm to NEUTRAL position. Move the stick to NEUTRAL. Tighten the adjusting nut. Test movement of stick and check to be sure that stick positions agree with transmission control operation.
8. SEE FIGURE 2 (Below)
Connect car battery. Apply hand brake. Move stick to NEUTR AL position. Press foot on brake pedal. Start engine. If starter fails to operate, Neutral Safety switch must be adjusted. Adjustment is made with a long-bladed Phillips screwdriver through the "Street" gate. This screw is directly in front of the st ick. Turn the screw about 1/2 turn past the point where starter operates. (STICK MUST REMAIN IN "NEUTRAL" WHILE ADJUSTMENT IS MADE). Starter should operate ONLY when stick is in PARK or NEUTRAL position.
Hope this helps and thanks for using FixYa!
Oct 22, 2009 | Pontiac GTO Cars & Trucks
Game control problems
Firstly, get a screwdriver compatible with the psp,Take the faceplate off.And dust the analog section of the psp with a very soft brush.Reason why there might be dust that is malfunctioning your analog stick.Make sure you take off the analog faceplate though
Apr 18, 2009 | Sony PlayStation Portable (PSP) Slim...
Memory stick
go to setings and go to system setings then go to format memory stick then clik yes. then it will work.
Jun 09, 2008 | Sony PlayStation Portable (PSP) Console
Sony PlayStation Portable (PSP) Console Logo
Top Sony Video Game Consoles & Games Experts
shaun taylor
juanmireles1
Damen Wong
Damen Wong
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
