Question about GE JKS05 Electric Single Oven
Oven won't turn on
Hi, we recently had a power surge and now my oven does not turn on. When you open to oven door the light comes on, but the digital does not work. What can I do to get this working again? Would it cost more to fix or to replace?
  • 114 Answers
If you haven't already, try turning off the circuit breaker for a few minutes. Turn it back on and see if the clock display is lit. If it does not, you may need to replace the clock assembly. It is sometimes costly for this repair.
Posted on Oct 05, 2007
6ya staff
SOURCE:
Replace light in KEMC378KSS microwave
The oven lights are 12-volt, 5-watt maximum halogen bulbs. They
will come on when the oven door is opened. On double oven
models, both upper and lower lights will come on when either
door is opened. The oven lights will not work during the Self-
Cleaning cycle. When the oven door is closed, press OVEN
LIGHT to turn them on or off.
To Replace:
Before replacing, make sure the oven is off and cool.
1. Disconnect power.
2. Remove glass light cover by grasping the front edge and
pulling away from oven
3. Remove bulb from socket.
4. Replace bulb, replace bulb cover by snapping back into wall.
5. Reconnect power.
Feb 04, 2013 | KitchenAid KEMC378KSS Electric Double Oven
We were without electricity for 2 daya following hurricane Irene. When power was restored, the oven display (time, temp, etc) did not come back on. The oven lights come on when the button is depressed. and...
Try turning off the circuit breaker to the oven for 30 min or so and then turn it back on. If it does not come back on the oven probably got a power surge and the control has been damaged. Hope that helps
Aug 30, 2011 | Whirlpool RBD305PD Electric Double Oven
The temperture pilot light will only come on when the oven door is open.So therefore in the oven will only heat up when the door is open. close the door and the temerture pilot light goes out The clock has...
Problems like this are almost always control board related and are the result of a power surge/spike....
Replacing the control board should solve your problem...
Here is a tip that will help you with the online buying...
How to Buy
Appliance Parts Online
heatman101
Dec 26, 2010 | AEG B8139-4-M Electric Single Oven
Double oven control panel just quit after power surge.
This is unfortunate.
The display is a computer you need to do most of the work.
Go Onlne to www.partselect.com and order that display. You will need a friend or a service guy to open and install you new display
Jul 26, 2010 | GE Profile JTP18 Electric Single Oven
Power surge fried Frigidare FEB24S2ASB
The electronic oven control has gone bad. The repair is a lot less expensive than the replacement of the whole stove. Part number is 903091-9051 at about 165.00 retail. You can fix rather than replace whole stove. Hope this helps.
Mar 04, 2010 | Frigidaire FEB24S2AS / FEB24S2AB Electric...
Locked latch on the self cleaning oven
try wiggling the door latch to get it open if not try the cleaning process, if that works, and see if the door comes unlatched and the light goes off. if not the lock light switch is stuck and it will need to be taken apart and cleaned
Oct 13, 2008 | GE JKP15 Electric Single Oven
Oven Not Working
your clock need a reset you need to turn it off and back on then hold in your manul button it looks like a hand and the + that should then be ready for you to cook
Nov 06, 2007 | Smeg SE399X/5 Stainless Steel Electric...
Oven won't work after power cut.
The power outage may have been a result of a power surge or included one. Check the surge protection, breakers or fuses, most likely found inside control panel. Of course turn power off to stove before opening up the panel. Breakers should be pushed all the way off before being pushed to the on position.
Nov 05, 2007 | Ovens
GE JKS05 Electric Single Oven Logo
140 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Ekse
Marvin
Marvin
Are you a GE Oven Expert? Answer questions, earn points and help others
