Question about Acer TravelMate 2300 Notebook
Pls help me
I have an internal wireless card but i cant access wireless what do i do .
    Sergeant:
  • 457 Answers
There are a few things you need to check. Has it been going before? Is this the first time you have had it going? Is it installed have you switched it all on. Are you in range of one?.
Posted on Oct 04, 2007
SOURCE:
Good day sir, i have a toshiba laptop but i cant connect the wifi eventhough i already switch it on. what should i do? some tips pls. thank you and more power. sincerely yours, james
If you have a wireless router and it is connected to the DSLor cable modem then - To connect to your wireless router, the router needsits wireless settings to be configured with the SSID, encryption key etc., alsothe wireless cards and wireless adapters in all the laptops/computers needs tobe configured with these router's wireless settings. Then the laptops/desktopcomputers can communicate with your wireless router and access the Internet via the DSLor cable modem.
Sep 04, 2011 | Intel Computers & Internet
I've set up the password security for my Dynalink wireless router but now i cant even use the wireless internet pls help
Theencryption key secures your data from unauthorized access. The router's password is a Passphrase or the WEP or WPA orWPA2 encryption key. The Passphrase generates the WEP or WPA or WPA2 encryptionkey and this is in the router's wireless settings. To connect to your wireless router, configure the router'swireless settings ie SSID, plus the WPAor WPA2 encryption key and then configure wireless cards in the laptops and orcomputers with these router's wireless settings. Then the laptops and desktopcomputers can communicate with your wireless router.
May 01, 2011 | Computers & Internet
Wireless activation in laptop
Check connectivity with router. Make sure router is setup for wireless access point. Make sure the internal wireless card is setup for access point as well. hope this helps!
Aug 14, 2008 | Computers & Internet
Aspire 4315 - Driver Problem for "Network Controller" both Win XP/Vista
there are 3 or 4 different drivers on the acer website for you system for wireless networking download all of them and try them all one at a time if you do no know which one suites your system. they are labeled as wifi drivers. that would be the easiest route.
Jul 10, 2008 | Acer Aspire 5100 Notebook
Wireless conect
see that is firewall is on or proxey server are thery so pls remove it after then you try.
after then you not get it then re-configure your usb adapter
Jun 26, 2008 | Computers & Internet
Most of the time the problem with the network controller is that you have the wrong driver. The easiest way to get the right driver is to get the make and model off the wireless card, then go driverguide.com and download a driver for the card. You may have to download several before finding the right one. Once you've found the right driver, burn it to a disc for future reference. When downloading the drivers save them to the desktop before installing.
Jun 25, 2008 | Acer Aspire 4315 Notebook
WIRELESS CARD FOR LAPTOP
Hi
Your did not provide any info on which card you have or wish to install; USB, PC Card, or internal mini PCI card.
For mini PCI cards, first you have to open up the D600 laptop and install the Hardware (ensure to connect the antenna cables) then power-up and install the software (drivers and utility).
For USB and PC Cards, follow the device manufacture's recommended steps. Generally, for USB devices, the software (drivers and utility) needs to installed first before the hardware is connected.
If you have successfully installed the hardware and software (driver/utility) you can scan, choose and connect to an available wireless access point or wireless ad-hoc setup. This can be done through the wireless manufacture's utility or from Windows Wireless Zero Configuration utility. If you use the manafucature's utility, Windows Wireless Zero Configuration utility will not work; will not scan or list available wireless network.
Check "Dell Connect To A Wireless Network" article
http://support.dell.com/support/topics/global.aspx/support/dsn/document?c=us&docid=338826
Mike
May 07, 2008 | Dell Latitude D600 Notebook
WIRELESS MODEM
Pcg U1 doesnt have wireless card. But is has PC card slot. You can buy a PCMCIA wireless card or USB wireless to get access to wireless internet access or PCMCIA modem if you use a modem to access the internet.
I hope this help
Jan 25, 2008 | Sony VAIO PCG-U1 Notebook
Dynex wireless adapter
When you posted "cant...dynex wireless notebook card...operate..." do you mean:
1. It is not recognized by Win98SE;
2. Will not install:
3. missing/error on drivers;
4. will not connect:
5. will connect but drop;
6. will connect but no internet access?
Pls post back details. Further to what AP/Router are you connecting to?
Kind regards.
Nov 04, 2007 | Intel Pro 1000XT Server Adapter...
Computers & Internet Logo
78 people viewed this question
Ekse
Alun Cox
