Question about Hoover F6212-900 / F6215-900 SteamVac Agility Upright Vacuum
Hoover Agility, No Suction!!!
I purchased my Hoover Agility in August and it worked GREAT!!! I went back to use it this week, (first week in October) and I cannot get it to suction in the main cleaner. When I attach the upholstery hose, it works great, but I cannot get any suction from the main part of the machine...one person suggested the problem is "hose attachment", and unless they are talking about another attachment I am not aware of, I am not seeing what I need to detach...any ideas! I have a very sick cat and for reasons you can ony imagine, I really need it to work!!! I appreciate any help!!!
  • 6 more comments
  • lakechick Jun 11, 2008
    I have the same problem!! For one tank of clean water it may **** up just a few inches of nasty water!!!! I made sure the filters were clean,no broken hoses and made sure the plastic 'hood' snapped into place!!! What now????
  • stevekat Jun 30, 2008
    Have the same exact problem.
  • ryanki Oct 07, 2008
    Will not ****, there is no dirty water in the tank when all of the clean water is almost gone and my carpet is soaked.
  • munsie2 Nov 07, 2008
    Lost suction today. Low and behold I too have a split suction hose!!! Removed many screws, but cannot get the upright seperated.
  • Anonymous Dec 30, 2008
    Thanks for the duct tape suggestion. It worked!
    I noticed that we've been slowly losing suction. I checked the filters, etc and there were no problems. Then I saw the crack in the hose just behind/under the water containers. I slapped a piece of duct tape over the crack (didn't bother to remove the hose at all) and I'm back in business. It probably won't be a long term solution, but I imagine I'll get a few more months - year out of it.
  • SBTD Feb 01, 2009
    same issue with lack of suction. Found broken/split hose.. almost split in two, so duct-tape not possible. ordered the part from http://www.usavacuum.com/ for $11.99 +4.50 for shipping after taking apart the machine. Hope we can put it together again when the part arrives!
  • sassidst Mar 29, 2009
    can anyone point out the screws to take out of the cleaner to replace the lower suction hose in the hoover agility steamvac?
  • kippinb Apr 19, 2009
    the exact same thing , not the cat, is happening to mine. it blows out air from the main part but no suction.
We know the suction hose is cracked and we need to replace it. (1) we cannot find the number to order the part, and (2) there are no instructions in the manual as to how to take the machine apart to replace the hose. Has anyone had any success doing this?
Posted on Nov 17, 2008
I had the same problem. Lower the handle to the floor and check the black spiral suction hose at the neck of the machine. The lower hose in my Hoover split. Check and see if yours has done the same thing. If so, the lower suction hose will have to be replaced. Hope this helps.
Posted on Oct 05, 2007
We had the same problem.  We just fixed it.  We took the plastic hood off and put our hand under and realized we had suction but it wasn't picking up water.  The only thing we had done was remove the lid to clean some carpet fibers and debris.  However, we did not put it back on correctly.  We had to make sure we put the plastic top on from top to bottom and that we had it securely in place.  Once we did this we were able to pick up water again.
Posted on Oct 27, 2007
Make sure that the door for the upholstry hose is CLOSED tightly.
Posted on May 01, 2009
I went to use my hoover agility today. I was noticing that the water wasn't being sucked up like usual. I pulled the handle all the way down and noticed that the suction hose was torn in 2 places. I removed all the screws and was able to get to the hose out easily(be careful to not miss a screw. There are some hidden screws). I removed the hose without a problem. I might do a temporary fix with duct tape until I can get a new suction hose delivered. It seemed harder than it actually was. But then again taking things apart is alot easier than putting things back together.
Posted on Nov 29, 2008
If you have a cat or dog and you use this product, let it be known that yes cleaning filters will help but only momentarily. Why you ask because as soon as the suction is restored, all the hair caught half way in the machine will hit the filter now that there is suction. So clean and turn it on about three times and then use, but keep in mind pet owners, that you may have to do this again because this is what you are shampooing up. I know this because we borrowed ours to a cat owner, and she returned it I kept cleaning the filter over and over. Still poor suction, so I dismantled it which was easy just the top half where I could see all the hair. After that good cleaning worked just as I got out of the box.
Posted on Aug 10, 2008
My machine has stopped suction on the main unit, but has suction on the hose adapter.  When I tilt the neck all the way back, the hose is split around its diameter.  Is there a straightforward way to fix this?
Posted on Jun 30, 2008
I'll bet 10 to 1 it's split suction hose which is most difficult to replace. I've got same problem and spent 2-hours removing several screws but could not get to the upper hose connection which is embedded in the upright component of the machine.
Does anyone have any ideas on how to separate the two halves of the upright section of this machine in order to replace the split suction hose?
Posted on Jun 22, 2008
  • 94 Answers
Try cleaning out all the filters and emptying it. prem
My hoover upright agility vacuum has no suction and we cleaned all filtees
check in the floor suction pick up
you can take the whole thing apart and check for blockages
if the motor is overheating and slowing
dust inside motor
Nov 09, 2016 | Hoover Vacuums
How to repair the lower intake flexible hose on the Hoover Agility
hoses are screwed into the end bits by turning in the do up direction
original equipment hoses are normally glued into the end piece but with a bit of determination and a flat bladed screw driver, the glue can be broken and the end removed
fit the good section of the hose into the end and screw it in using an un do direction
if it is the plastic fitting itself that is broken then weld the broken section back together
Basically use a soldering iron and heat the sections until the plastic melts back together
There are u tube pages that show how easy it is to do as they heat weld all sorts of plastic and tips on how to improve the strength of the repair. go google and type in how to weld plastic.
Apr 14, 2015 | Hoover F6212-900 / F6215-900 SteamVac...
Why is the recovery tank on Hoover f6212-900 not filling up?
Hello! There are a few things that can cause the cleaner to lose suction. Please try these quick steps.
1. Remove the dirty water tank.
2. Clear the filter screen of any dirt or debris.
3. Turn the cleaner on, check your motor suction by the filter screen.
4.. Replace the dirty water tank making sure it is flush to the cleaner on all sides.
5. Lift up on top of nozzle and slide off cleaner.
6. Wipe debris off nozzle and front of cleaner with a damp cloth.
7. Replace dirty water tank.
If you felt suction by the filter screen your suction should now be restored. Hope this was helpful!
Jul 21, 2014 | Hoover F6212-900 / F6215-900 SteamVac...
Hoover agility steam vac F6210 solution tank repair
Hello! The valve assembly is not replaceable on the F6210. We recommend replacing the solution tank part number 90001091, can be purchased online or through a local service center. Hope this was helpful!
Jun 19, 2014 | Hoover F6212-900 / F6215-900 SteamVac...
Lost suction, gasket problem
This is a great basic steam cleaner. I have not heard of repeated problems of this type. The gasket is called a standpipe gasket. I would try to use a non-permanent sealant such as RTV silicone to adhear the gasket, eventually if this needed service you will want the gasket to be able to be removed.
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_b96ba3f038cf317c
Feb 02, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
Suction
Take the recovery tank out, there is a filter on the handle part where the tank sits in, make sure it is clean. Check for any other filters to make sure they are all clean.
Jul 10, 2008 | Hoover F6212-900 / F6215-900 SteamVac...
Hoover agility--poor suction, still!
When you remove the dirty water tank, on the machine, there is a screen that gets clogged and will prevent good suction, is this one clean? If it is, do you feel suction at that screen, if so then there is a problem with the tank. If no suction there, then you will have to check it over for a air leak or a bad seal.
Apr 29, 2008 | Hoover F6212-900 / F6215-900 SteamVac...
Hoover F6212-900 / F6215-900 SteamVac Agility Upright Vacuum Logo
3,416 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Kirk Thompson
Level 1 Expert
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
