Question about Panasonic Workio DP-150PA Copier
Error message on copier
Hi, we have a panasonic workio DP-150PA copier and we are getting error message E01 22 on the machine. How do I correct this problem?
  • 3 more comments
  • Anonymous Jan 08, 2008
    Code E01 22
  • Anonymous Feb 13, 2008
    error E01 22
    errorr e1 22
  • Anonymous Apr 03, 2008
    I have an EO-1-22 error code after a paper jam
  • Anonymous Mar 27, 2014
    E0401 error message
  • 25 Answers
That is a laser unit error. If resetting the machine's power doesn't clear it up, then it means the laser unit is dead/dying. If that's the case, your only choice is to replace the laser unit.
Posted on Jan 24, 2008
Dp 1515 copier error E01-02
There is not supposd to be any E1-02,...THERE IS an E1-20, it is saying you have a prob in your "optics" unit, possibly even the Lser unit...you should probably have a service man determine exact prob.
Oct 06, 2010 | Panasonic Workio DP-150PA Copier
What does e0122 error code on panasonic workio dp 150 copier mean?
Hello :
polygon motor synchronization error. possible causes are :
1: engine pcb
2:laser unit
3: lvps
4: sc pcb
reseat all the connectors before starting to replace boards
please rate !
Apr 13, 2010 | Panasonic Workio DP-150PA Copier
How do you setup the email address book on the Workio dp-150?
You might be able to download a manual here:
http://www.retrevo.com/s/Panasonic-DP-150-Copiers-review-manual/
I'm not sure that model supports emailing scans. I couldn't find it in the manual. Just setting up the fax phone book on page 139.
May 01, 2009 | Panasonic Workio DP-150PA Copier
Software for Panasonic DP-1820E
Google "PANASONIC DP-1520 PRINT DRIVERS" or go to:
http://www.panasonic.com.au/support/downloads/file_type_results.cfm?fileTypeID=1&productCategoryID=28&productID=387
It's Panasonic Australia, but its the same ones I use. Use the GDI print driver to avoid any problems. Make sure you get the right one for your OS (ie WIndows XP, etc)
Oct 27, 2008 | Panasonic Workio DP-150PA Copier
Error miss feed j87
just check all sensors in paper path .j87 shows inverter problem.MIAN AKHLAQ
Apr 29, 2008 | Panasonic Workio DP-150PA Copier
Panasonic DP-150PA Light Copies to no copies
Have you reseated the drum and toner?
It can be a drum cartridge problem. have you tried that?
You say copy or print, so I am asuming this is multifunction and you do both printing and copying.
1, Have you shook up the toner cartridge well.
After the drum and shaking the toner, I would suspect the transfer assembly, Off hand I cant remember of that machine has a transfer roller, or if there is a channel where there is a hair fine wire running through it.
The wire may have broken, or if its a roller making poor contact.
The laser is also possible.The transfer will be on the right had door assembly.
Take the cartridges out and see if there is anything laying loose in the machine,
what you are describing sounds more like a drum or transfer problem.
sounds very much like a defective transfer. And again, could easily be the drum.
Did you have a jam just before this occured? If you had a jam in particular in the right hand door, you broke the transfer wire.
Yeah, i am rambling huh?
Apr 09, 2008 | Panasonic Workio DP-150PA Copier
Dp-1820e rebooting not starting
you may try this:
unplug the network, usb, and fax connection
remove all papers
turn on the machine
press print key
press stop
press 1 for yes to cancel the job (if theres a job queue)
Mar 31, 2008 | Panasonic Workio DP-150PA Copier
there is high voltage or corona probleb in your copier contact any technical person
Aug 27, 2007 | Panasonic Workio DP-150PA Copier
Help me on DP1820E panasonic photocopier
if there is no error message dont worry it just needs a routine service if it does have an error message what is it? it will start with an E example : e04-21 kind regards Dr Bob1
Mar 28, 2007 | Panasonic Workio DP-150PA Copier
Panasonic Workio DP-150PA Copier Logo
356 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
HEMANT GROVER
mahesh y.h
mahesh y.h
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
