Question about NEC Dterm DTP 16D-1 Corded Phone
DND button it is flashing and I don't have a manuel so please tell me how to get it off
  • Anonymous Mar 12, 2008
    My line is flashing, it's accidentally set on DND, but it's my CORDLESS which doesn't have a "feature" button. So feature, 69, feature will not work.
  • niran Mar 24, 2008
    how to off the dnd button and how to on?
Ohh my good this worked great!!! feature, retrive, 69, set, feature somthing like that, you have to play the combo, sorry well i fixed mind!
Posted on Dec 05, 2007
This answer was not only correct it was quick and to the point.
Thanks.
Posted on Nov 09, 2007
Press Feature dail 69 press feature
Posted on Oct 15, 2007
Kx-t7433 how to turn on fwd/dnd does not work
What happens when you dial 165 on the intercom? If you get voice mail, then try dialing 7104 165 # on the intercom. That sets CF-No Ans to voice mail for your set and the FWD/DND button should light solid (or not, it's a program option) or flash. If you dial 7101 it should turn on Do Not Disturb (7100 cancels). In DND, the FWD light should flash.
Once you have set these two conditions up, the FWD/DND button has 3 states, FWD, DND, and OFF.
Carl
Jul 10, 2012 | Panasonic KX-T7633 Corded Phone
FWD/DND SHOWING RED AND INCOMING CALLS RESTRICTED
If you have not found an answer to this as yet just pick up intercom and enter 7100 at the phone. This will clear any DND. Now enter intercom 7105165. This will give a long tone and the DND/FWD lamp will flash showing Call forwarding active for VM.
Jan 18, 2011 | Panasonic KX-T7630 Corded Phone
How do I put my phone on DND?
You get a chance for that to work next time :-)
Panasonic features are in the system, not the phone. If you have a TA series, from the phone, pick up the handset and press the FWD/DND button and dial 4#. (you may also dial 71 in place of pressing the button).
Cancel is 0# in place of 4#, but you also have CF to voice mail issues, where 1+VM EXT is all calls and 2 is BUSY/NA.
If you have a TD or TDA or TAW system, you get lucky, because the FWD/DND button works in 3 modes. For DND it's 7101 or *7101. The button will light with a solid red light and when you press it, it either flashes or goes off. The system gives you both FWD and DND settings.
Carl
Apr 05, 2009 | Panasonic KX-T7730 Corded Phone
How do you set the time and date?
Step 1.
Press the PROGRAM button, then press * * 1 2 3 4
The display should now read: USR-PGM NO?
Step 2.
Enter: 0 0 0
Display: Day/Time Set
Step 3.
Press NEXT (or the SPKR PHN button)
Display: shows date (if you need to change the date, see steps 5 thru. 10 below)
Step 4.
Press NEXT (or the SPKR PHN button) again
Display: shows time example: 12:00 AM
Step 5.
Enter the hour
to change current entry, press CLEAR (or the TRANSFER button)
Step 6.
Press --> (or FWD/DND button)
Step 7.
Enter the minutes
Step 8.
Step 9.
Press SEL (or AUTO ANSWER/MUTE button) to change AM or PM
Step 10.
Press STORE (or AUTO DIAL/STORE) - Don’t forget this step!
Step 11.
Press END (or HOLD button)
Step 12.
Press SPKR PHN button or pick up and hang up the phone to leave programming mode.
Dec 20, 2008 | Panasonic KX-T7731 Corded Phone
FWD/DND - PANASONIC KX-T7130
Don't laugh. Push the button and read the display. It will either unset DND or CF :-).
The 7100 command is part of the sequence to cancel those features on most phone systems and 790 or 79# will reset the extension. Of course it may be different if you have a TDA or TAW box (*7100) or a KX-T xxx10 system.
Carl
Nov 16, 2008 | Panasonic KX-T7130 Corded Phone
Features
Not sure how you set this feature but here is the solution:
To set DND you would have pressed your feature button, 60,and then feature button again (if you were forwarding to another extension you would have had to enter an extention after 60 and then the feature button. This sets your DND or call forward.
To eliminate press feature, 69 and then feature again this should cancel the call forawrd or do not disturb.
Oct 01, 2008 | NEC Dterm DTP 16D-1 Corded Phone
Fwd/dnd button will not flash
FWD/DND is programmed in the system, not the phone. When you figure out what system you have, post again.
Carl
Jun 06, 2008 | Panasonic KX-T7130 Corded Phone
Date & Time
Press PROGRAM + ** + User Programming Password (default is 1234)
Press 000
Press NEXT (Sp-phone button) : The date will be displayed.
To change the DATE (or you can press next again to go straight to change the TIME)
Enter the year (last 2 digits)
Press --> (FWD/DND button)
Keep pressing SELECT until the desired month is displayed
Enter the day
Keep pressing SELECT until the desired day of the week is displayed
Press STORE
To change the TIME
Press NEXT (Sp-phone button): The time will be displayed.
Enter the hour
Enter the minute
Press Select for AM or PM
Press Select for 12 or 24 clock hour
Press STORE (Auto Dial button)
Press END (Hold button) to exit
Jan 08, 2008 | Panasonic KX-T7431 Corded Phone
Feature Button Constantly Flashing
1. Press the Feature key.
2. Dial Call Forward All/DND
set code 69.
3. Press the Feature key
again.
Nov 07, 2007 | NEC Dterm DTP 16D-1 Corded Phone
NEC Dterm DTP 16D-1 Corded Phone Logo
240 people viewed this question
Top NEC Lands Phones Experts
Craig Butler
Craig Butler
Norman Al-Anbar
ray gallant
Are you a NEC Lands Phone Expert? Answer questions, earn points and help others
