Question about GE Advantium SCA1000H Convection / Microwave Oven
GE Advantium SCA 1001HS
Hello, I want to know how you replace the interior lamp on a GE Profile Advantium 120, model: SCA-1001HS. Can I replace the lamp without taking the complete Microwave out of the wall. It uses a GE Halogen Lamp part no. WB08X10050. Thanks.
  • Anonymous Nov 04, 2007
    I have GE Profile Advantium 120 microwave Model #SCB1000KBB 01 and the interior light bulb is out. How do I replace and what parts do I need and where do I get parts (Home Depot or other). How do I get access to the bulb. I can find no manuals or instruction for this procedure.
    gpaddle
  • Anonymous Mar 12, 2014
    unit has no power
  • 473 Answers
Should be able to get to the lamp by removing the grill.
Posted on Oct 05, 2007
How to change nightlight bulb on ge advantium 120 oven
Advantium - Interior Light Operation While Microwaving
The Advantium 240 oven interior (cavity) light will illuminate anytime the door is open. However, due to the dark tint on the oven door, there is not a light on while cooking since the food would not be visible using the interior lamp.
Food may be viewed during a microwave cycle by pressing the Microwave/Oven Light pad.
One of the Upper Level Speedcook lamps will come on for 5 seconds. The Microwave/Oven Light pad can be pressed up to 5 times during a microwave cooking cycle. The limit of 5 times is to prevent excessive heat on microwave cookware from the Speedcook lamp.
The Advantium 120 oven cavity is illuminated anytime the door is opened and while the unit is in the microwave only mode. As a result it will not have the Microwave/Oven Light pad.
Aug 25, 2012 | GE Microwave Ovens
Interior bulb needs to be replaced. What needs to be removed to gain access? Thanks
If the light is not operating properly, you will want to have it checked by an authorized service technician. To obtain in or out of warranty repair on Major Appliances, you may call 1-800-GE-CARES (800-432-2737) or schedule service online.
Check here
http://www.geappliances.com/search/fast/infobase/10000007.htm
Aug 25, 2010 | GE Advantium 120 Convection/Microwave Oven
I have a GE Advantium SCA 200 oven that stopped working as we were cooking. the Breaker is OK and there is power to the receptacle. Is there a fuse in the unit that can be replaced without a technician?
Yes, it is a ceramic fuse inside the unit that can be easily purchased at your local Radio Shack. Take the original there and they will find the replacement fuse. Just unplug the unit before working on the electrical parts...
Dec 19, 2009 | GE Advantium SCA2000B Microwave Oven
Need to replace fuse in GE Profile advantium oven
remove outer shell/cover, the fuse will be in a fuse holder about 1" long X 1/8" in diameter and is called a ceramic fuse,take it out,look on ends for current rating go to hardware store they have repl fuses, if the new fuse blows it could be your h.v. diode, capacitor, or the magnetron tube
Sep 05, 2009 | GE Advantium 120 Convection/Microwave Oven
Advantium Bulb replacement
You are describing the little bulb in the front. The speedcook light is a different bulb
See: http://www.instructables.com/id/GE-Advantium-Microwave-Halogen-Lightbulb-Replaceme/
Apr 12, 2008 | GE Advantium SCA1000H Convection /...
GE microwave interior light bulb replacement.
It's pretty simple as long as you have an offset phillips screwdriver...
Of course, be sure to disconnect power to microwave and be sure not to touch the new halogen bulb with fingers.
STEP-BY-STEP:
First, remove upper vent panel and remove inner filter (same directions for just replacing inner carbon filter):
Then, remove inner plastic grille (2 screws) and final screw on left side of metal "air duct" - here's where you'll need the offset screw driver (and a little patience!):
Then, you can gently lift the sheet metal panel, find the light housing, squeeze and remove/replace :)
That's it...just replace bulb and reverse for reassembly. Be sure to keep track of screw locations there are various sizes/lengths used.
Doug
Nov 26, 2007 | GE Advantium 120 Convection/Microwave Oven
GE Profile Advantium Wall Oven 240 volts 950 Watts
How long does it run before it fails? Does it look like the display is getting scrambled characters? I'm leaning toward a bad magnetron, but it may be more or less than that. If you can give more details and especially the actual full model number (as opposed to the model name Advantium 120) that would help. Thanks!
Oct 02, 2007 | GE Advantium 120 Convection/Microwave Oven
Replacing the interior lamp inside the microwave on the top.
Yes, Bobby, it can be done. Before you begin, though, go to Home Depot and look in the tool department. There, ask for a "Husky Pro #66604". It's a 1/4" and 5/16" drive 90 degree ratchet that's about 4 inches long. While you're there, pick up a #2 1/4" drive phillips screwdriver bit. You'll use both of these to do the light. Both for about $12. UNPLUG YOUR MICROWAVE! Stand on a small ladder in front of the Microwave (MW), remove the 2 screws that hold the vent louver in place and remove the louver. You'll now see a black plastic grill (just above the door handle)remove the 2 screws with your new tools and remove the grill and the metal box that covers the relay. Now remove the 2 screws holding the horizontal metal panel that the box was sitting on. Now gently lift that panel up, (don't try to remove it) and you'll see the lamp. It's the one with 2 white wires going to it and a shiny metal cover over it. Place your index finger on the back of the cover of the lamp and gently pull toward you and lift at the same time. This will release the catch and allow you to pull it all the way out to get to the lamp. There ya go! Simple!
Jul 29, 2007 | GE Advantium SCA1000H Convection /...
Oven Halogen Lamp
It's pretty simple to replace the light without having to remove the oven from the wall...as long as you have an offset phillips screwdriver...
STEP-BY-STEP:
Doug
Aug 04, 2006 | GE Advantium SCA1000H Convection /...
GE Advantium SCA1000H Convection / Microwave Oven Logo
295 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
