Problem for Receivers
Generic problem for all Receivers
Receiver amp problem?
Recently (2 mos.), sound to the speakers is not clear. Not "crackly". Particularly with bass. It seems that the signal coming from the receiver is poor. It is the same for all outputs (CD, tuner, etc.). I have tested with other speakers and other speaker wire. Thoughts?
Same Problem
Feb 21, 2008
-   About a month ago had a small smell of burnt electronics and thought it was from the new TV I bought, but nothing was wrong. Yesterday heard my power regulator for the computer complaining (beeping) as if either I got a huge voltage spike in my electricity (or maybe something shorted somewhere) but the lights or circuit breaker of the house did not go out. Then at night went to listen to receiver and I notice the it was working partially. This is, everything works, sound through all channels, etc BUT it has lost VOLUME this is when volume at 35 out of 60, it sounds like 10 out of 60. Also it lost definition, the sub for example seems to have frequency missing. Could it be that some audio/output amplifier IC burnt? How many IC amplifier does this unit have? If one burnt would the symptom be as describe above? Am I in the right direction to what is my receiver problem? Any help would be appreciated. Thanks-
hillbillykid
Solution #1
posted on Oct 04, 2007
Rank: Wiz
Rating: 84%, 1289 votes
You are having problems with you audio amps, 1 or more are going out. will need to change using part number on amps. you can order from, Bluestar-online.***, VanceBaldwin.***
Popular Solutions for Receivers
Questions and Unsolved Problems for Receivers
tested unit to verify outlined reported symptom (not powering up) Trace cause of fault/symptom to-...
(More)
tested unit to verify outlined reported symptom (not powering up) Trace cause of fault/symptom to- NO clock operation (pins 13 &15 of IC9001 suspect crystal ( X9001) 15.7Mhz XTL clock for main mpu IC-9001( on main pcb assly ) have already checked the folllowing:- 5V supply to IC9001 is ok xreset (pin 12) ok. changed crystal ( X9001 )-still faulty, no change in state Have already checked the following:- STBY 5.6V ( pin 22 IC-401) on front panel pcb - is ok IC401 Vdd pin1= 5V is ok xtal/ clock at pins 3& 4 is operative 1wup is ok (switches when STBY button is pushed detected at Pin 20(1W WP ) of main mpu IC- 9001 ( on main pcb assly ) so guys , what have I missed ?
my marantz sr7400 makes tick tick sound when turned on it only goes away when power cord is...
(More)
MY MARANTZ SR7400 MAKES TICK TICK SOUND WHEN TURNED ON IT ONLY GOES AWAY WHEN POWER CORD IS SDISCONNECTED AND THEN CONNECTED SLOWLY .IT IS NOT ON TILL THIS SOUND GOES AWAY
I have no sound output on my TX-NR900 receiver. I turn it on an I hear a pop noise any idea what may...
(More)
I have no sound output on my TX-NR900 receiver. I turn it on an I hear a pop noise any idea what may have blown so I can fix it?
My Yamaha RX-V2700 shuts off intermittently. The unit has been back to an authorized Yamaha repair...
(More)
My Yamaha RX-V2700 shuts off intermittently. The unit has been back to an authorized Yamaha repair depot three times. The first time back the technician said that the problem was a thermal sensor, which was replaced. That did not solve the problem. The second time back, the technician said that there was nothing wrong and I took the receiver home only to have it fail repeatedly, again. The third time back, the technician said that DC was appearing on all of the amplifier outputs and that all of the output transistors had to be replaced. That did not solve the problem and the amplifier still shuts down. Sometimes within a few minutes and sometimes within a few hours. The problem does not seem to depend upon the loudspeakers, or when or how they are connected. I have tried ultra-short speaker leads and banana plugs to avoid short circuits. I have tried fewer speakers and more speakers. Thanks.
Left side speaker(s) only work on 'CD Direct' setting. Video 1 and Video 2 / AUX do not work at all....
(More)
Left side speaker(s) only work on 'CD Direct' setting. Video 1 and Video 2 / AUX do not work at all. Left side speakers do work on 'CD Direct setting, but do not work on 'Phono', 'AM', 'FM' or other settings.
