Question about Bissell 1698 PowerSteamer ProHeat Upright Wet/Dry Vacuum
No water out bottom..
No water or soap is coming out bottom onto floor, but water comes out of hand tools what would be the problem??
  • Anonymous Jan 08, 2008
    no water or soap dispensing help
  • shel2008 Jan 09, 2008
    There is no water or cleaner being dispensed out of the actual cleaner.The hose is working fine and the heat is also. Checked belts and they seem to be fine.
    President:
  • 1,673 Answers
Pump may be bad, also the cap for the flow indictor may be leaking air. Does the automix vale knob turn easily? If it turns real hard, then piston that the knob works may be jammed. Ckeck the seals on the bottom of both tanks to make sure they are on the tank and not sitting in the holes.
Posted on Jan 10, 2008
SOURCE:
Water not pumping out
It could Be one or more of a few problems. It may have soap clogging the pump or heater (if your model has a heater) or the belt turning the pump may be stretched or broken. I start by making sure water is coming from the tank. Make sure the belts are good. Make sure the pump is working. If water comes from the upholstery tool. But not at the floor it may indicate the heater Has a clog or restriction. Make sure there is not anything clogging the spray jets.
Mar 14, 2014 | Bissell Vacuums
Bissell cleanview carpet cleaner
There are a few things that can cause a Bissell carpet cleaner to not dispense water. First thing to check is the belts if your machine is a Pro Heat. The flat belt goes around the motor shaft and the pump. As the motor runs it spins the pump. This is a stretch belt and stretch belts should be replaced at least once or twice per year to work properly as they will lose elasticity even if the machine has never been turned on. The first thing to check is to see if water will spray from the upholstery tool. If it sprays but you still get no water at the floor jets then check and clean the jets to insure they are not clogged. Getting water from the upholstery tool means the pump is working ok. If not, make sure the water tank and soap tank are not empty. Even if the water tank is full make sure the soap tank is full too. I would suggest NOT putting any soap in the soap tank because that is what causes most of the problems. Put plain tap water in the soap tank and try the machine again. Hold the trigger down giving it plenty of time to flush out any air bubbles and/or soap from the pump and the lines. If you still can't get any water from to the floor jets the most likely problem is the heater is clogged with mineral deposits or soap gunk. When a machine sits in the closet for months the soap in the lines coagulates and will clog things up. Which is why if you want the machine to work for a long time NEVER put soap in it. To do a better job of cleaning put your soap and hot water into a sprayer and use this solution to pre-condition the carpets. Pre-conditioning gives the soap and hot water a chance to dissolve the gunk in your carpets, then use fresh hot water in the machine to flush the soap and dirt from your carpets. Your machine will last longer and your carpets will be cleaner and stay clean longer because you rinsed out the soap. If you try this method you will be amazed how much cleaner your carpets will be.
If you need to clean the heater you will need to separate the handle assembly by removing all the screws. First make sure the machine is unplugged. You'll have to figure out which screws need to come out, it's not too tough. The heater is inside the handle. Look at how it comes apart so you will know how to put it back together. The heater is the silver metal thing with wires and hoses. Remove the screws that hold the cover on being sure not to lose any of the tiny red gaskets. Remove the cover and clean the soap or mineral deposits from the heater core, put the cover back on and put it back together and it should work fine. To keep it from getting clogged again simply make sure you use soft water if minerals were the problem and never put soap in the machine.
Oct 22, 2013 | Vacuums
I have a Hoover SteamVac F5914-900 SpinScrub... The last time I used the hand tool attachment, it worked fine. Just tried to use it again, and now I only drips of water will come out of the hand sprayer,...
The brushes can be turned off on most of them via a switch on the hood. There shouldn't be water coming out onto the floor unless you are pulling the trigger at that top. You probably broke this when attempting to use the tools.
http://www.vacuummedic.com/product.php?id=231
Sep 23, 2012 | Hoover SteamVac F5914-900 SpinScrub...
No solution is spraying out when i press the trigger
I had somewhat the same problem.... I had water comming out but the solution was not comming out.... I called bissell and the woman talked me through it.... first put in water only mode,,,,, then Fill water tank with fresh water and put back in place,,,, then remove soap dispenser put to the side,,,, now , power on your cleaner,,,, for the next steps, do this exactly as I tell you >>>>>>hold down the trigger that releases soap the whole time you do the following>>>>>> switch between water only and heavy traffic four times,,,, all while while holding the trigger, then still holding the trigger, stop on high traffic the fourth time, leave it there,,, now put the soap bottle back in,,,,, still holding the trigger and hold the trigger down for exactly one minute after you replace soap bottle,,,, you should start seeing the soap come out........ (make sure its on floor cleaning and not TOOLS) Hope this helps and if it does,,,, give these instructions to someone else in this help area.........
Jul 04, 2009 | Bissell 8910 ProHeat Clear View Upright...
Bissell proheat 2x won't release soap water
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
tyu8
Jun 20, 2009 | Bissell 1699 ProHeat Clear View Upright...
Bissell proheat, not sure of model number no water will dispense
Ran in to similar issue except mine would not spray soap or solution through the floor cleaner but would work through the upolstry cleaner.
I found that there were 2 problems as follows:
1) The heater was clogged with mineral deposits and old soap that I had not cleaned out on a previous use.
2) The Valve that attached to the trigger sticks. (I am currently looking for a new valve)
Since you have soap and no water I your problem probably exists in the bottom of the unit. There are 6 screws to take off the cover.
You will see a hose that come from the soap despenser. It leads to the pump which is located in the front left corner of the unit. You can also trace the water hosed in and out of this pump. Since the hoses are clear you should be able to see any clogg. There is a hose that leads up the handle to the valve and then a hose that comes back down the handle (through the wheel opening) The hose that comes back down from the handel leads to a splitter which devides the output to the two jets.
Once it is apart it is pretty simple.
Hope this helps!!
Nov 22, 2008 | Bissell 1699 ProHeat Clear View Upright...
Soap from dispenser will not release into carpet cleaner.
These are two different problems the first could be a clogged heater soap coagulates in the heater passages and clogs the flow of water to see if this is indeed the problem turn the unit on and try and spray water with the top trigger (floor nozzle) then try to spray at the hand nozzle if you get water at the hand nozzle but not the floor nozzle it is the heater. The hand nozzle water bypasses the heater. Also check the solution or soap tank if you pull it out and there is not red seal on the bottom it may be stuck in the machine and won't create a good seal check to see if it is still in the hole where the tank inserts. As for the unit not turning on that could be a number of issues cord,switch or just over heated. Visit www.stevessewandvac.com for any parts or questions about this machine or any other.
Aug 13, 2008 | Bissell 1698 PowerSteamer ProHeat Upright...
Bissell Pro-heat 12
Jul 11, 2008 | Bissell 1698 PowerSteamer ProHeat Upright...
Steamvac drips when tilt to pull back
May have a problem with the seal at the bottom of the tank, the valve and seal sometimes go back and need to be replaced(#43513026).
Feb 22, 2008 | Hoover F7431-900 SteamVac Vacuum
Bissell 1698 PowerSteamer ProHeat Upright Wet/Dry Vacuum Logo
114 people viewed this question
Top Bissell Vacuums Experts
CJ C
CJ C
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
