Question about Asko D1776 Built-in Dishwasher
Asko 1776 dishwasher error message
F1 message comes on- to I really need a service tech. to fix the problem? I have heard this error message means a heater malfunction.
  • Anonymous Dec 04, 2008
    what does the heater element look like and where is it?
  • mikezav Dec 04, 2008
  • 175 Answers
Open up the underside of the dishwasher and check the 2 terminals that connect to the heater element. Sometimes they burn off and it is a quick repair to just put a new terminal on the end. Also make sure the water going into the dishwasher is hot, as that can cause this problem too. Hope this helps
Posted on Nov 06, 2007
Manual fo asko 1776 dishwasher?
Many times the date of manufacture is on the nameplate! (Or stamped nearby). Otherwise search google for the make and model.
Aug 14, 2014 | Asko Dishwashers
I have a 1776 Asko model & it doesn't finish its cycle-code mesage f-2 keeps appearing. Can you help me out.
F2 is a drain error and dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Also, check for any food pieces stuck near the pump impeller & clean the chopper assembly. Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Sep 18, 2011 | Asko 1375 Dishwasher
What does an F1 erroor message mean. I have a
F1 means "flood. there is a flood sensor underneath the drawer, and if there is any water under the drawer the control will show that error. Check the drain hose linkage for cracks. Remove drawer and dry the area underneath.
Jul 14, 2010 | Fisher and Paykel 24 in. DS-603 Built-in...
Dishwasher doesn't drain at end of cycle
The drain time is programmable. If your manual doesn't show how to do it, you can possibly go to and find a similar one. I happen to have a model 1776 and used the model 1755 manual which is identical.
Dec 23, 2009 | Asko 1375 Dishwasher
Asko Dishwasher F2 Error Flashing
F2 flashes, and wll not stop runing. No water in pan. help
Sep 29, 2007 | Asko D1776 Built-in Dishwasher
Dishwasher does not "pause" (hault) when I open the door
it's the door switch gone bad or the wire going to it has fallen off.
Mar 01, 2007 | Asko D1776 Built-in Dishwasher
Dishwasher fault
I got this with another dishwasher. On that one it meant the water wasn't feeding into it (tap switched off, kink in inlet tube, etc.)
Feb 16, 2007 | Asko 24 in. D3120 Dishwasher
Asko D1776 Built-in Dishwasher Logo
430 people viewed this question
Top Asko Dishwashers Experts
Owen Barnes
John Tripp
John Tripp
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
