Question about SanDisk Sansa e200 MP3 Player
Wont turn on and Computer wont reconize it...
I had my Sanasa e200 4G plugged in for a few hours on the USB last night to move some music around. It worked fine lastnight..listened to it a half hour no problems. I go to plug it in to get rid of a couple "bad track"s, the MP3 screen shows that it's connected but the computer doesn't reconize it. I unplugged it to replug it in incase the connection wasn't correct, and the main menu stayed on(MP3)didn't reconize it ws plugged in, then it shut off and I can't get it to turn back on.What happened? Is it broken? Did I do something wrong? It's brand new and I've only had it since sept07.HELP!!!
  • 626 Answers
Try this. Run the recovery tool from the SanDisk website. Make sure you select "format" when prompted. http://www.sandisk.com/Assets/File/Downloads/firmware/e200fw01.00.12.exe You need to put the device into "recovery mode" before you run the tool. - Turn the device off (hold power for 20 seconds) - Slide the hold switch into "hold" position. - Press and hold the "record" button while connecting it to your computer. Keep holding the "record" button until you see the "new hardware found" on your computer. Then run the recovery tool. Select format when prompted. Best of Luck.
Posted on Oct 07, 2007
I Dont Know What Happened But The Same Thing Happened To Me Today. I Put It On The Computer To Charge Overnight To Enable Me To Listen To It The Next Morning.I Took It Off Of The Charger At Around 5:30 A.M. And It Worked Perfectly Fine And I Was Listening To It On The Bus (We Had State Marching Band In Cedar Rapids) And Then It Shut Off And It Will Not Work, And Before This Incident It Did Freeze Up On Me Quite A Bit And It Would Stay On And The Power Button Would Not Shut It Off, But I Did However Find That If You Press And Hold The Select Button Or The Record Button It Will Shut Off In Little To No Time, But Yeah It's Plugged Into My Computer Now So It Is Not A Battery Issue. HELP!!! -Mac
Posted on Oct 06, 2007
SOURCE:
Played in car once. Then plugged in to computer. Now all it says coby on the screen when turned on or plugged in computer. Device manager will not reconize . When not plugged in to computer and turned on...
same problem, only i didnt paly it in car, just around the house for a few min. System , device manager sees it as Other USB device with yellow error icon, so doesnt recognize it, even though 20min before i was moving songs onto it np from same computer. piece of ****
Dec 25, 2009 | Coby MP-610 MP3 Player
Tom tom xl does not turn on. been on charge all night and using car charger still makes no difference
try the usb cable to your. this is the recommended method to charge a tomtom when it wont power on. for reasons unexplained by tomtom they do not recommend the car or house charges.
plug it in via the usb cable to your computer for a few hours(make sure the green light is on and nice and bright) then press and hold the power button(this could take up to 20 seconds)
bill
Oct 15, 2009 | Tomtom ONE GPS Receiver
Computer wont recognize my e book...it was working fine last nigh
I devised these simple steps that tend to remedy quite a few issues with most USB portable / external hard drives and devices (though not always)
A few things to check but assumes USB and Windows for other interfaces / operating systems similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again. This can be especialy true if you move a HUB to another port
If you checked and fixed anything there and still have issues then check your hardware from CONTROL PANEL / SYSTEM / HARDWARE.
Any exclamation marks by hardware need fixing before you investigate any further
Aug 30, 2009 | Western Digital My Book Home 320GB...
Computer wont reconize my 4gb micro sd card
try to plug it in another port at the back of your CPU plug it directly to the motherboard, if it does not work try to use another card reader, check your micro card if it is put correctly to the card reader,
Jul 01, 2009 | PNY 2GB microSD Memory Card
Wont charge
Hi
a nice firmware update should repair all that
go to this website and find the good mp3 player
http://www.sandisk.com/DriverDownload/index.asp
select your operating system and download the firmare
plug your mp3 and run the firmware
select the good device and you should be able to listen music after and turn your mp3 off.
Good luck
Jun 19, 2009 | SanDisk Sansa Fuze MP3 Player
My itouch wont let me turn it off, or type password for home scre
I had this same problem but iff you hold the homw and power button at the same time for 10secs it turns it off but doesn't reset it!
Jan 29, 2009 | Apple iPod touch
1999 durango 5.9 wont fire
could be the cam sensor. or crank sensor
Dec 26, 2008 | 1999 Dodge Durango
IT wont turn on
tyr holding both the power button and the play button for 20seconds at the sametime
Dec 28, 2007 | SanDisk Sansa e260 MP3 Player
WWON'T POWER ON
For one, you don't need the CD to put music on the Opal. It's a plug and play device. Go to My Computer on your desktop and you will see under Audio Devices "OPAL". Click on that and you'll see a folder called "Media" and that's where you put your music.
For not turning on, click Pause/Play twice
For charging, You need to plug in the USB cord into the computer to charge it. Wait 3 hours. The Opal doesn't have a real long battery life, i'd say around 10-15 hours. So you'll be needing to charge it quite a bit.
Dec 23, 2007 | RCA OPAL M4001 MP3 Player
This damn thing....
Charge the player - it needs to be charged daily.
Dec 18, 2006 | SanDisk Sansa m250 MP3 Player
SanDisk Sansa e200 MP3 Player Logo
123 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Joe Negus
Joe Negus
Ekse
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
