Transformer in Samson servo 500
Transformer (trafo) broken on primary circuit. Amplifier has been left switched on for many days and suddenly stopped working. All electronic is fine. All I want is know the place where can I buy new transformer, or place where can I fix it.
  • lenox
    lenox Apr 27, 2008
    I tried on radio shack, but they have popular trafos, but mine amplifier is a professional 500 W, and have untypical unit. There is no other equipment using transformer like this one in my Servo.
    Thanks for trying.
    P.S. I need original Samson part, or another amplifier with f.ex. burnt MOSFETS, or eventually company doing trafo's rewiring.
  • Anonymous Mar 25, 2014
    I need just wiring Trafo-primary...to Volt adjust
  • 682 Answers
Check (radio shack)near to you for transformer with same rating.or any electronic store.
Posted on Apr 25, 2008
I need a transformer for my resolv 65a monitor
Are you an experienced tech? In most cases (unless there is a defect in manufacturing) transformers are not a common cause for failure. If it blows the fuse disconnect the secondaries and see if it still blows the fuse. If it does then the transformer is likely the cause, if the fuse doesn't blow then the problem is elsewhere. If you have 120vac at the primary and nothing(or very low) at the secondary(s) then the transformer could also be at fault. If you have done this already and narrowed it down to the transformer, sorry I cannot help. I used service Samson but no longer am able to get parts. Good luck!
Jan 04, 2015 | Samson Audio Resolv 65a Active Studio...
Good day to all,can i ask some help about my automatic voltage regulator 1500Watts using a servo type transformer to identify the wiring connection in the primary?,,thank you!
If the transformer is still in the mixer you should be able to trace out the primary by using an ohm meter or continuity tester. connect the meter to one side of the power connector and probe the leads on the transformer til you get a hit mark that wire and continue until you get another hit and that is the other primary.
Jun 08, 2014 | Pyle 10 Channel 800 Watts Powered Stereo...
I got a used Velodyne SC1250 Amplifier from a friend in the states. Can I switch the power supply from 110 V to 230 V? A pretransformer from 230 to 110 V is to big and not a wishable solution. Are...
If its a transformer based Amplifier you can rewind the primary winding for 230Volt. But it has to be done by a transformer specialist.
All one has to do is unwind the primary on a winding machine and make a note of the number of turnings in the coil. Then wind back twice the number of turns using half the thickness of the wire that was used for 110v.
Eg: if the there were 1000 turns of 20 swg wire in the 110 circuit when you rewind you have to use 40swg wire and wind 2000 turns on the bobin.
Jun 29, 2011 | Velodyne SC1250 Amplifier
I have a Roland AC60 amplifier that I brought from Australia to the US. The Australian version of this amp runs on 240 volts not 110. My question is; 1) does anyone know if converting this amp to...
The only simple way that I could think of is for you to purchase a STEP DOWN TRANSFORMER rated at 500 watt, 110 volts, 60cycle. The transformer inside that amplifier have four output 12v and 15v DC.2amps It will be hard to get the transformer for that! Hope that might help you! taah!
Nov 18, 2010 | Roland Ac60 Acoustic Chorus Guitar...
I need the Samson servo 300 circuit diagram. THANKS a lot! Regards Carlos
I dont have The diagram
Carlos sorry :O[
can you find the "Bridge" switch?
Aug 11, 2010 | Samson Servo 300 2-Channel Amplifier
The main transformer in my Sherwood amplifier is down the primary winding is open circuit. I cannot find the transformer outputs as to replace it. does any one know the voltages and current ratings for...
I would contact Sherwood as Transformers are deemed to be safety components and should be replaced with excat parts or those recommended by the maker.
Jan 25, 2010 | Audio Players & Recorders
Samson Servo 170 protection circuit problem!
my friend resistors and diodes don't just go off your circuit without a real problem. those parts gave up because of shortage on your power section, i suggest that you check your power transistros first along with the diodes and resistors.
noisy transformers... hmmmm why is that making sound? the solution there is to dip the power transformer to a thick shellac varnish let it there for let's say an hour then let it dry for a day. then place it back in your unit and see if still sounds
Aug 11, 2008 | Samson Servo 170 Amplifier
check see if youy have some coving the vent or the speak connect right
Dec 05, 2007 | Samson Servo 170 Amplifier
Amp power
Make shure with an ohm meter that the primary and secondary windings have very little resistance on the main trasformer,then check voltage in trasformer and out from transformer...BIGRED
Sep 02, 2007 | Audio Players & Recorders
568 people viewed this question
 Grubhead
Grubhead
Marvin
Marvin
