Master
- Posted on May 01, 2009
Re: How do i replace the keyboard on a dell inspiron 1525
How to Install a Replacement Keyboard on Dell Inspiron 1525 Laptop Computer You may need:
---Be careful to not break off any of the plastic tabs on the keys as they are difficult to replace.---
- Turn the computer off and slide the tip of the screwdriver in the
notch on the right side of the hinge cover (the plastic section above
the keyboard). Slide the hinge cover up and remove it from the
computer, exposing a series of bolts. Unscrew the bolts and remove them.
- Pull up on the edge of the keyboard and slide it forward toward the
display. Slide the keyboard all the way out of the computer case slowly.
- Unhook the flex cable from the computer board to disconnect it from the computer.
- Slide the new keyboard into place, connecting the flex cable first.
- Screw down the edge of the keyboard with the 4 bolts from before and replace the key cover.
- Power up the computer and see how your new keyboard works!
will let ya know how it works after i try it ..thanks
Got a new keyboard for my inspiron 1525, don't know how to install.
