Question about Motorola Mobility RAZR V3
MotorolaV3x locks up when accessing camera or camera menu
Hi, dropped my Razr in fresh water. Keys stopped working. Got best local repair shop we could find in Baghdad. They fixed keys & calls are ok but phone locks up if access camera or camera menu & have to take battery out to clear. Is it a software firmware prob or better to buy new phone. No-one here knows how to fix it or what's wrong - pot luck really getting anything fixed in Iraq.
You could try opening the top part of your phone and unplug and replug the camera connector. unscrew and pop open the case. The wire for the camera is the wide one on the left. flip open the lock(brown plastic), take it out, put it back in and flip back the lock.  good luck!
Posted on Oct 12, 2007
I have a samsung J700 and almost everybutton has stopped working, I would rather not go to the shop I got i from because i need a quick fix that i can do at home
Normally this happens when one or more keys on your phone are stuck are permanently pressed so you can not use any other key as well.
Please check all keys individually specially side volume or camera keys. If any key is stuck, then you should try to release it by pressing it few time.
I have seen same problem on many water damaged phone as well. if your phone happen to be water damage then cell repairing shop is best option.
Aug 25, 2011 | Samsung J700 Cellular Phone
Dropped my canon power shot SD1400is and it will not turn on is it fixable
Here is a tip that I wrote about How toget a Digital Camera Lens to work again
Steps toRepair a Digital Camera Lens
May 24, 2011 | Cameras
I can not take photos. The message on the screen says "This memory card is locked"
hi first you should check the small piece (lock/unlock) on SD card. if not, you should consult to local repair shop. It is then two possible is memory receptance pcb, two is main pcb.... It is very easy repair. Your local repair shop would charge $45 to 115 depend on what they really want to charge. Thanks and best regard!
May 23, 2011 | Panasonic Lumix DMC-TZ3 Digital Camera
Unable to view and change settings through menu button, nothing is visible
It is known problem of ccd imager chip failure in Canon A85 camera, ccd imager chip will be replaced to get live view in camera mode to take fresh pictures.
Local camera repair shop will replace ccd imager chip in camera because camera will take apart and soldering work is required to complete this job.
Hope these info will help you.
Jan 10, 2011 | Canon PowerShot A85 Digital Camera
I just replied your previous question that this problem occurs due to ccd imager chip failure that will be replaced to get live view in camera mode to take fresh pictures.
Local camera repair shop will replace it, let me know if you need part number of ccd imager chip of DSC-T33 camera.
Sep 28, 2010 | Sony Cyber-Shot DSC-T33 Digital Camera
I can see the menu and icons on the LCD screen,
It is known problem of ccd imager failure in S3IS Canon camera and ccd imager chip will be replaced to get live view to take fresh picture.
Local camera repair shop will repair camera by replacing ccd imager chip because camera will take apart and soldering work is also involve so its not likely novice fix.
May 30, 2010 | Canon PowerShot S3 IS Digital Camera
The lens is stuck 1/2 way out and I am unable to access the menu and have taken the batteries out and even replaced them.
The lens has probably got something in the retraction mechanism that is stopping it retracting. This can be something as simple as sand or grit or as a result of a drop or knock. In most cases the camera will need to be stripped apart to remove the lens assy before it can be repaired. This is best left to a professional camera repair shop.
Oct 30, 2009 | Nikon COOLPIX L18 Digital Camera
Play & Menu buttons/display not working properly after water got in
I took mine surfing, and it leaked salt water (just a couple of drops) into the battery compartment. I rinsed the whole camera with fresh water, and the camera came back to life -- but had similar display issues.
I had the camera serviced at Best Buy, where I had purchased a 4yr maintenance contract. In addition to fixing the electronics, they replaced the door on the battery compartment with one that has a metal hinge instead of the original plastic.If you don't have a warranty, then getting a used replacement is by far the cheapest route.
My advice: buy another one on eBay or Craigs. I just got a second one two weeks ago for $70.00 and it is working perfectly. This is an awesome camera, and worth the hassle to repair or replace.
Nov 06, 2008 | Olympus Stylus 720 SW Digital Camera
Arrows don't work...can't save contacts to SIM
  your arrow keys have problem, so take it to the service center for i ll tell you how to access ur phone without arrow keys.. imagine ur menu is like wat i shown below..
       cal log      phonebook      applications
       browser    messages       files
       calendar   camera           settings
now if u want to access "cal log" press 1 ; "phonebook" press 2; " applns" press 3 ; "messages" press this as in your keypad...
now select contacts by pressing any suitable options...assume if your options are placed like this
create contact
send via
copy to sim
then u can access view by pressing 1, create contact by pressing 2...and copy to sim by pressing it as it is in ur mobile...
good luck
Jul 03, 2008 | Motorola Mobility RAZR V3
Mororola v3x
i lost my software to my razr v3xx can i find a free download?
Apr 23, 2008 | Motorola Mobility RAZR V3xx Cellular Phone
Motorola Mobility RAZR V3 Logo
55 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
