Regarding toWorkstation HP xw6400
In windows XP-64 bit, Only one Harddisk detected by system,other hdd not detected why? HDD detail- 2*73 sas
    Problem Solver:
  • 15 Answers
In order for the bios to recognize the hdd's you have to make sure you have the jumpers on the end of the hdd next to the cable connection on the right pins. There are usually a picture on the lable of the hdd that shows which pins to put the jumper on according to master and slave selections. It sounds difficult but it isn't. you have to unplug the computer first and take the cover of the case off and disconnect the cable from the hdd's and unscrew the any screws that are holding the hdd in the slot. then slide it out however it comes out and look on the end where the power and cable connect, there is a little black or white could be another color, jumper, that is what it is called but you can google it to get a picture of it if needed. Any how that jumper on the correct pins will tell the computer which hdd's it should recognize first and second. If the jumper is on the wrong pin the computer will not recognize your hdd.
Posted on Sep 12, 2009
Keep the first harddisk as master and second harddisk as slave ok
Posted on Oct 06, 2007
UHB-330U doesn't work for Windows 7
Try shutting down your PC then start it back up again.. Sometimes it fixes the issue
Oct 31, 2017 | Fanner Masscool UHB-330U 3.5" Aluminum IDE...
Hp pavilion dv6-2113ax i installed xp but hard disk not detected plz give solution/stata drivers
Hello Shubha,
If HDD not detected then how you install XP. Or this is a secondary HDD.
Normally windows automatically install the SATA drivers no manual intervention needed.
Please clarify.
With regards
Sep 22, 2010 | HP Computers & Internet
The machine restart and the harddisk cannot be recognise
Do you mean that the HDD is not detected when you restart your PC?
Is it a New HDD or used HDD? If it is an old HDD probably the HDD have failed.
Is your disk a "SATA OR IDE" interface connection?
Go to your BIOS settings and see whether your HDD is recognised on the BIOS settings.?
Best thing is to go back to your MotherBoard manual and look an the BIOS settings. If you are not sure just use the default settings.
Jun 28, 2010 | Microsoft Windows XP Professional
I can't get Vista Ultimate set up to recognize my WD 1TB HDD in a new build. Is this a software problem or problem with the HDD. I get the short beep at BIOS start up so I don't think its with the...
Few steps to check your harddisk status on the motherboard would resolve this issue. Checkin to the cmos setup and look for the detection of the HDD and the size it shows once you have done a formating.
Vista 64 bit shows issues at times while installing a new SATA 1TB HDD. Check if the 1TB HDD is installed on to SATA 0.
Use a WD Disk Manager and format the HDD initially and then try install Vista on to it. Else if this doesnt work on the system, Put the HD on to another working system and Format it with NTFS File system and try installing Vista.. You will be successful. Good Luck.
Feb 13, 2010 | Gigabyte GA-MA785GPMT-UD2H AM3 AMD 785G...
Are you trying to do a fresh install? or upgrade from another operating system? Generally have to do a fresh install when going from 32 bit version of xp to 64 bit. IF you have more than 4 GB of ram installed, you may have to remove some, then install 64 bit XP Pro, then install your ram after. (this is a known problem with some machines and 64 bit xp) IF this is none of the above?
Please add a comment with more information as per your BSOD. This way I can identify with you what it is the system does not like
Oct 08, 2009 | HP xw6400 Workstation PC Desktop
MSI RC410 - cannot detect Sata HDD
i think the problem is with ur SATA HDD. To confirm, try another SATA HDD on ur mother board and see if the problem persists
Sep 20, 2009 | ASUS P5RD1-VM Motherboard
Mother board cant detect my Sata HDD, please advise me urgenly...
I will advice you to exchange the HDD with someone or with brand new one as it seems to be problem with drivers of the sata.
Sep 20, 2009 | MSI RC410M-L Motherboard
Hard disk not being detected
Check ur HDD cable attached with motherboard.. may be they are loose . if still prob remains then HDD can be corrupt.... chk same harddisk in another system
Mar 28, 2009 | Intel Motherboard
Virous in removeble harddisk
try to boot to safe mode, and see if it is detected. If it is detected in safe mode. Uninstall and reinstall any drivers that came with your external hdd. If still no go, reinstall windows. If after reinstalling windows, still not detected, replace external hdd.
Feb 16, 2008 | Microsoft Windows XP Home Edition
Computers & Internet Logo
196 people viewed this question
David Payne
David Payne
