Question about Olympus Camedia C-5060 Wide Zoom Digital Camera
Olympus 5060 - buttons not working consistently
I've got a 5060 that has seen a fair amount of use.. Occasionally, I'm unable to adjust the aperture or flash settings - the buttons don't seem to work at all, the on-screen menus don't appear, but the camera still works otherwise (I can take a picture, just can't adjust the settings). I'll change the batteries, turn the camera on and off several times and then it will usually function normally. I've tried leaving the camera in a ziploc bag with some silica packets for a couple of days in case there was some moisture in the camera, but the problem still appears sporadically. Any suggestions would be greatly appreciated.
  • 4 more comments
  • shadowkat Nov 29, 2007
    im having the exact same problems!.......but cant seem to find out the solution short of sending the camera off somewhere.......cant delete pictures either, although i can take pictures........which im doing on the other memory card installed in the camera!
  • fkruger Nov 29, 2007
    I got a similar problem with my camera. As it seems a common pattern,
    it's most likely an design issue with the components or software. Only
    way I see to get it fixed is to send it to back Olympus.
    Regards, F.
  • romano-sk May 20, 2008
    Hi, I have similar problem but on my cam only two buttons doesn't work. Arrow buttons (left and down). The switches can not be cleaned as you can not get to their contacts. Anyway I have dismouned the cam and found that from electrical point of view they are working (switching) so something behind them have to be wrong. Do you have somebody schematic? Thank you for any advice.
  • troykeith Jun 19, 2008
    Follow-Up: I kept at it w/the ziploc bag and silica packs and eventually the problem has gone away (except on extremely humid days) so I'm assuming it was/is moisture related. Others may want to try it for a week or so and see if it clears things up.
    Troy Keith
    Troy Keith
  • babberg Nov 27, 2008
    hi
    awkward but handy when you are stuck , gentle downward pressure on mode dial will give a v.short term fix .
  • 4 Answers
You can find a description of that problem and a fix here: http://www.wrotniak.net/photo/c-wz/c5060-dial.html
Posted on Jun 12, 2008
  • Kaahsi May 23, 2014
    Unfortunately the spar part is no longer available.
I wonder if this is corrupted camera firmwear try updateing to the latest firmwear upgrade.
or take off top of camera and clean switches useing electrical switch cleaner.
jeff oly c5060 user ps could also be dirty mode dial switch.
Posted on Feb 10, 2008
Where do I adjust the aperture on my Olympus 725Sw?
I've gone through the manual, and i don't think you can. Many simple point and shoot cameras have just one fixed aperture. In the manual, the only thing i found was on page "10. P (Program auto) The camera automatically sets the optimum aperture value and shutter speed for the brightness of the subject."
Apr 08, 2011 | Olympus Mju 725 SW Digital Camera
Where can I get a user manual for my Olympus c-5060 wide-zoom camera?
You can download and print the instruction manuals in PDF format by clicking these links:
C-5060 Wide Zoom Basic Manual (11 MB)
C-5060 Wide Zoom Quick Start Guide (811 KB)
C-5060 Wide Zoom Reference Manual (9.6 MB)
Adobe PDF Reader is required to view the manuals. Download Adobe Reader
Hope this helps. Kindly let me know if you have any difficulty in downloading the manuals.
Thanks for using FixYa.
Dec 03, 2010 | Olympus Camedia C-5060 Wide Zoom Digital...
Can this lens fit an olympus C 5060 ?
No, it will not. The C-5060 does not use interchangable lenses. I cannot tell from the picture that you have attached what cameras this will fit. It it was, in fact made by Olympus, it would appear to belong to their line of 35mm film cameras.
Nov 20, 2009 | Olympus Zoom Telephoto 75-150mm f/4 Zuiko...
Olympus C-5060 - green and orange lamps always on
have u switched the batteries? try that
Jul 11, 2009 | Olympus Cameras
How to KNOW the light is right 4 an Olympus OM20 Manual camera?
OM-20 was basically a upgraded OM-10 with the manual adapter built in and a number of other refinements.
The viewfinder has LED's to show the shutter speed recommended by the camera's lightmeter for the ISO and aperture selected. It also has an exposure compensation indicator (the +/- symbol) and an indicator for flash ready which doubles up as a post-exposure flash confirmation. There is also the indicator lamp to show manual mode has been selected. OM-10 lacks the manual mode lamp and the +/- indicator.
Like the OM-10, the OM-20 is primarily an aperture priority automatic camera. In this mode you set the ISO film speed, choose which aperture you wish to use (with the ability to use the lens depth of field preview button) and then the camera selects the correct shutter speed. The +/- exposure compensation control allows the user to tell the camera to modify the recommended shutter speed by up to two stops either way.
In manual mode, there is no manual metering. The light meter behaves exactly as it does in aperture priority mode and the viewfinder shows the recommended shutter speed and not the manually selected one. Correct metering is therefore a case of adjusting the aperture first, and then choosing the correct shutter speed indicated in the viewfinder. If the user then decides to select a different shutter speed, then the aperture ring must be adjusted to maintain the correct exposure. For example the aperture is set to f8 and the camera recommends 1/60th of a second. The user decides that a faster shutter speed is required and chooses 1/250th, but the viewfinder remains showing 1/60th. In order to keep the same exposure value the user must open the aperture by two full stops to f4. The camera's light meter will detect the new aperture setting and providing the light on the object is unchanged the viewfinder shutter speed display should now show 1/250th as well to confirm the correct adjustment. Alternatively, the user can choose the shutter speed first by looking at what has been set on the control ring (or by turning the ring to the end of its travel and then counting the clicks from there as all experienced OM users do) and then turning the aperture ring until the shutter speed shown in the viewfinder matches what's been manually set.
It all sounds clumsy and complex but is done far more quickly than I've taken to type this and becomes second nature.
Aperture priority metering is selected on the camera by choosing AUTO on the mode selecter. In this mode the shutter speed ring has no effect and the viewfinder always displays the automatically selected shutter speed.
May 09, 2009 | Olympus OM-2000 35mm SLR Camera
How to disassemble camera?
Not exactly for your problem but a illustrated manual how to fix the mode dial problem and how to disassemble the 5060: http://www.wrotniak.net/photo/c-wz/c5060-dial.html
May 30, 2008 | Olympus Camedia C-5060 Wide Zoom Digital...
Olympus D-400 Battery Cover
Theres a lttle tab thatmay have broken off I,ve seen it a zillion times.. Consult your owners manual and it will show you how it goes on and if it dosent work like the manual says it probably broken good luck
Apr 18, 2006 | Olympus D-400 Zoom Digital Camera
Wide zoom flash problem
I haven't used that particular camera, but it would sound a bit like a problem with the white balance setting. Check your manual about white balance adjustment and try to take a few test shots manually adjusting the white balance to see if this might be the case.
Sep 13, 2005 | Olympus Camedia C-5060 Wide Zoom Digital...
Panorama feature
You can use the Panorama feature on the C-5060 Wide Zoom provided that you use an Olympus brand xD-Picture Card.
Sep 04, 2005 | Olympus Camedia C-5060 Wide Zoom Digital...
IESP auto focus
iESP is the default auto focus setting for the C-5060 Wide Zoom camera. It uses a contrast detecting system, to analyze the entire image by comparing the subject against the background to achieve focus. When the shutter button is pressed half way on the C-5060 Wide Zoom, the AF target zone automatically moves the to an area of the image where it finds the optimal contrast.
Olympus Camedia C-5060 Wide Zoom Digital Camera Logo
606 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you an Olympus Camera Expert? Answer questions, earn points and help others
