Question about Mitsubishi WS-65809 65" Rear Projection Television
Mitsubishi WS-65809 65 in. Rear Projector
The top left and right corners of screen display a distorted coloration. Its fine at initial startup (powered on)then it comes and goes frequently. What could be the cause of this? I would appreciate any help or advice you can provide me. Thanks in advance, Elijah
  • rlien10 Oct 21, 2008
    I have a Mitsubishi ws 65809. I need to disassemble it to get it up from my basement. Is there any diagrams of how this thing goes together?
    Genius:
  • 1,694 Answers
Bad solder connects on pins of STK convergence IC's.Replace IC's for reliability,then re-align if necessary.
Posted on Oct 04, 2007
2 Suggested Answers
SOURCE:
  • 1694 Answers
SOURCE: Mitsubishi WS-65809 Color Distortion
Bad connections on pins of STK IC's.Replace w/high quality new parts for reliability. Re-align as needed. .
How can I stop the colorful spotting in the display of my NEC NP410 Projector?
Its the dlp/dmd chip going and soon will look like the star screen saver on windows 98. it will need replacing. they start with one or two dead pixels then it spreads. ref only->https://www.replaceyourlamp.co.uk/projector-lamps/nec/np-u250x/dmd-chip-1076-6439b/dlp-dmd-chip-1024x768-pixels-model-b.html
Mar 02, 2018 | NEC NP410 3LCD Projector
I have a Mitsubishi 55"
This set has a convergence problem. You should only need to replace the IC. Part is STK393-110. It sits on the middle board behind the large heatsink. Use a heat transfer compound to ensure repair lasts. If you have no experience soldering (or unsoldering) please use a professional for the work. The traces are fragile and I have fixed many mistakes local DIYers have committed. Goodluck.
Jan 20, 2011 | Mitsubishi WS-55511 55" Rear Projection...
Mitsubishi WS-55511 convergence problem?
No,need to diagnose.It a 100% convergence problems.Convergence problems very easy diagnose.The picture look like 3D,colors lines don't lines up.Fuzzy,out of focus.Convergence controls don't work to lines up any colors cross.The tech is cheating u if he said cost $125 to diagnose.If u know how to solders u could fix this convergence problems about $100.U can buy a convergence kit at Websites Tv repair World.com,Tvrepairkits.com.The shop everythings fix parts and labors only $300.
Mar 16, 2010 | Mitsubishi WS-55511 55" Rear Projection...
Mitsubishi tv model WS-55809
that happened to me and i just gently hit it on the top and it fixed itself
Jun 28, 2008 | Mitsubishi WS-55809 55" Rear Projection...
I think it what is called convergence
Maybe loose connection on the convergence board around the IC's or amps
Mar 22, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Mitsubishi WS-55809
1)Check for coolant leak from CRT onto signal board
2)Possible convergence problem ..................T.
Oct 26, 2007 | Mitsubishi WS-55809 55" Rear Projection...
Oct 03, 2007 | Mitsubishi WS-65809 65" Rear Projection...
Color sag on mitsubishi ws-55909 projection tv
Adjust convergents for blue.This is done with your remote control. go into menu, setup, instructions will come up on screen, also in manual.
Feb 04, 2007 | Mitsubishi WS-55909 55" Rear Projection...
WS-55809 - Video pinched in center, distorted, yellow/blue/red glow
This doesn't sound like a programming issue. I had a very similar problem about 6 months ago and I fixed problem. I had cold solder joint on the video power board. It was the board in the middle. The power supply was to the right. The video board had a driver with a bunch of legs. About 7 solder joint where cold or loose. I solder the board and my mitsu wide screen was fixed. Hope this helps.
Andy
Aug 22, 2006 | Mitsubishi WS-55809 55" Rear Projection...
Mitsubishi WS-65809 65" Rear Projection Television Logo
113 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
