For radiator replacement procedure and radiator problem troubleshooting. I suggest you to click the link below and follow the detailed procedure :-----
How to Replace
Engine cooling Fan on car?
http://repairhelpcenter.blogspot.com/2011/11/how-to-replace-engine-cooling-fan-on.html
Engine makes noise and Cooling Fan belt Breaks?
http://howtobyme.blogspot.com/2011/12/engine-makes-noise-and-cooling-fan-belt.html
Replace Fan Relay
but still Radiator cooling fans not working?
http://schematicsdiagram.blogspot.com/2011/12/replace-fan-relay-but-still-radiator.html
Cooling fan relays location?
http://technoanswers.blogspot.in/2012/02/cooling-fan-relays-location-on-1998.html----------DIC says
"COOLING FAN FAULT"?
http://schematicsdiagram.blogspot.com/2011/12/dic-says-cooling-fan-fault.html
How to replace radiator Cooling Fan?
http://repairhelpcenter.blogspot.com/2011/11/how-to-replace-cooling-fan-on-acura-car.html
Engine cooling
components working?
http://repairhelpcenter.blogspot.com/2011/11/engine-cooling-components-working.html
How does Vehicles
Engine cooling system works?
http://repairhelpcenter.blogspot.com/2011/11/how-does-vehicles-engine-cooling-system.html
cooling fan not working
http://schematicsdiagram.blogspot.in/2012/02/hyundai-sonata-cooling-fan-not-working.html-----------
Fuel pump relay and
cooling fan relay troubleshooting?
http://repairhelpcenter.blogspot.com/2011/10/fuel-pump-relay-and-cooling-fan-relay.html
Why Transmission fluid leaks near radiator?
http://repairhelpcenter.blogspot.in/2012/02/transmission-fluid-leaks-near-radiator.html
Transmission fluid leaking?
http://technoanswers.blogspot.in/2012/02/ford-windstar-transmission-fluid.html
How to replace Radiator?
http://repairhelpcenter.blogspot.com/2011/11/how-to-replace-radiator-on-audi-and-vw.html
HOW TO REPLACE AN UPPER RADIATOR HOSE
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-upper-radiator-hose.html
HOW TO REPLACE A LOWER RADIATOR HOSE
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-lower-radiator-hose.html
How to replace Radiator on Car models?
http://repairhelpcenter.blogspot.com/2011/11/how-to-replace-radiator-on-acura-car.html
How to flush cars radiator?
http://repairhelpcenter.blogspot.com/2011/11/how-to-flush-cars-radiator.html
HOW TO PRESSURE TEST A RADIATOR AND CAP
http://schematicsdiagram.blogspot.com/2011/07/how-to-pressure-test-radiator-and-cap.html
HOW TO REPLACE A RADIATOR
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-radiator.html
HOW TO REPLACE A RADIATOR SUPPORT
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-radiator-support.html
This details will help.
Thanks.
