Question about Indesit 23 in. DV62 IX Built-in Dishwasher
Water will not drain
Hi, The above is a built in dishwasher so it is tricky to get to the drain. I wondered if something was stuck in the impellor. I took the filter out but cannot see how to get to the pump. Any advice would be gratefully received. Best wishes, Bob
  • BobGriffiths Feb 08, 2008
    Thanks for the ideas. In the end I got the engineer in.
    Best wishes,
    Problem Solver:
  • 9 Answers
Check the drain line at the disposal or sink (however it dumps into the sewer line). Remove the line at the termination and blow into the line, matter can collect or clog the line itself. The pumps are hard to get at usually as they are mounted between the motor and the bottom surface of the tank itself. It is common for the motor and pump to be replaced as a unit.
Posted on Jan 27, 2008
I have a Kenmore Ultra wash 665.16522. The water won't drain completely. About 2 or 3 inches of water will stay at the bottom. I wonder if there is a food catcher, and if so, how do I clean it? JSBravo
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you'll need to clean the drain filter and drain pump. Also, check for any food pieces stuck near the pump impeller. Hope this helps... Please post back for any further assistance.
Mar 16, 2011 | Kenmore 16522 Built-in Dishwasher
I have a hotpoint dishwasher model# HDA1000G00WH. until recently never noticed rinsed water not drained after washing/rinse cycle completed. water level just above the drain cover. i removed the cover to...
wow, slow down. you should be looking for something simple. make sure your door lever is in the off position and or the timer at the off position for safety's sake. take bottom cover off. turn the fins on the motor counter clockwise. the seals in the motor pump assembly may be stuck. this is a very simple design washer. good luck.
Jan 20, 2010 | Hotpoint 24 in. HDA3740G Stainless Steel...
Siemens hydro sensor dishwasher not draining
sounds like a drain pump ... you may have a damaged drain pump or something stuck in it.. turn off the power the the dishwasher... .remove toe panel and you can see the drain pump on the left can remove plastic hose on the left to drain the dishwasher sure to catch the water will come out ... you can remove drain pump press release tab and turning drain pump ...hope it helps
Sep 19, 2009 | Siemens 24 in. SE53200 Built-In Dishwasher
I have the exact same problem
There may be something in the drain line that that is limiting the flow. A cherry pit for example. Remove the drain line where it connects to the pump inlet (or valve is there is one) below the washer and see if there is anything clogging it there.
Jul 11, 2009 | Frigidaire 24 in. FDB1050REC Stainless...
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems - Water will not drain out
May 19, 2009 | Kenmore 24 in. 16032 Built-in Dishwasher
Dishwasher is making a loud noice and the water is not draining...
clean out the pump as it cant drain and there will be something stuck in the pump
Jun 13, 2008 | GE Profile PDW8400J Built-in Dishwasher
Dishwasher draining - Bosch SGV4313GB/17
This is generally because of a stuck diverter solenoid. The water goes to the pump and then is either sent to the wash arms or the drain. Also, check the drain.
Feb 11, 2008 | Bosch 24 in. SGE09A25 Built-in Dishwasher
Won't drain
To access the pump, first bail and sponge out any water in the machine's tub. Then tip the machine over on its front, using a heavy blanket or pad to protect the washer's finish. Remove the back service panel. The pump is attached to the motor. Look if the pump's impeller (a round plastic fan blade-type of device) spins around. In case it doesn't spin, look if it doesn't blocked or stuck from any other reason. Good luck!
Sep 16, 2007 | Whirlpool 24 in. DU1100XTP Built-in...
Open Questions:
See all Indesit 23 in. DV62 IX Built-in Dishwasher Questions
Indesit 23 in. DV62 IX Built-in Dishwasher Logo
87 people viewed this question
Top Indesit Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Eric Taylor
Are you an Indesit Dishwasher Expert? Answer questions, earn points and help others
