Question about Samsung HT-X40 System
Samsung HT-X40 System Problem
I have recently connected my home theatre to my Samsung 40' LCD via an optical cable so that I can use the surround sound while watching TV. However after about 10 to 15 mins I get a delay between the sound and the picture. The sound lags behind the picture on screen. This does not happen while I'm watching DVD on the system but I'd say that because I have a HDMI connection. Does anyone know why I get this delay???
  • 1 more comment
  • Anonymous Nov 06, 2007
    i have exactly the same problem as yours.Everything works fine until we watch the tv programs through the home cinema system.Everything starts of in sync then after a few minutes its well out of sync.i would apprieciate any advice.
  • mx5al Nov 18, 2007
    just bought 40" 1080p with home cinema system. having exactly the same problem, after about 5 mins sound falls behind, only when watchin tv through cinema system. dvd work fine no delays. any advice? ? ?
  • BoroBoy Nov 24, 2007
    I have the same problem, and there is also half a second difference.
    I go into the menu's to change the delay time, through the cinema menu, and this seems to solve this temporarily.
    Can someone please offer some help and advice to this very tedious problem?
    Thank you
I have both the delay in sound and the loss of picture, I just bought and hooked everything up a few days ago and I am very frustrated, i may take it back if they cant help when i call on monday, I"m not sure I can get the download to fix it, even my roof antenna which i mainly use for HD football games has a sound delay with the digital cord and the rca plugs, it tried both. I hate to have to take all that back down and take it back but I wanted perfect by super bowl sunday,
Posted on Jan 19, 2008
  • jfngrs33 Jan 19, 2008
    I'm thinking about taking mine back and opting for that phillips system too, it's even cheaper. I talked to samsung today, they told me it was my signal. but to unplug for 20 seconds, then plug in and hold stop for 15 seconds to reset, the sound is improved, more in sync but still not perfect and I watched some movies today, this player has all kinds of issues with dvdr's it plays dvd-r ok but still blacks out after watching half a movie, I tried a regular dvd and made it through alright but the picture wasnt any better in 1080i than normal with the hdmi, component cables looked the same to me!
I have simply taken my optical cable out of my TV and connected it from my Sky+ box direct to the cinema system and it works perfectly fine now.
I am afterall, only using the TV for the picture, the sounds comes from the cinema system.
Thank you "guest" for your comment, much appreciated.
Posted on Dec 09, 2007
  • BoroBoy Dec 09, 2007
    If you have a SKY+ box, connect your optical cable from the SKY+ box to the cinema system and it will work perfectly well.
    I am still waiting for the update from Samsung, but I am happy with how it works now.
    Money well spent.
    Thank you "guest" for your comment which helped immensley.
I've run across the same problem. For now I've run the optical cable directly from my cable box into my stereo and I'm good to go. I hope the update will be something I can download and use with my flashdrive since i'm not connected via a direct cable connection which I assume is how the update will be sent. I'm not sure if it will make it through my cable box.
After taking tv and cinema system back i found out that using the old style phno leads(red,white) instead of optical wire it works fine. i now have a phillips system ten times better!!!!
Posted on Dec 04, 2007
Hello All, I discovered the same problem when connecting my LCD TV LE40R8 to my HT-X30. I reported the problem to Samsung this morning and they told me that they are aware of the issue (which is with the TV) and an automatic software update to resolve the problem will be sent out to the TV early in December. You should get an automatic update message on your screen, just follow the instructions and this should upload the fix. Fingers crossed!
Posted on Nov 27, 2007
Samsung tv to panasonic sa bt100 home theatre
it is the problem with the hdmi cable .. dont buy cheaper cables it may damage after some time
Aug 24, 2012 | Audio Players & Recorders
Insignia Remote Code Needed for Samsung HT-X40
Many remote control codes can be found at InsigniaProducts.com. Search for your Insignia product model number and click on the Support tab.
Dec 27, 2009 | Samsung HT-X40 System
Samsung HT-BD2R 7.1 Channel Blu-ray Home Theatre System
Connect the PS3 with HDMI to the Home theatre.
Connect the TV digital optical out put to the optical input cable of HT-BD2R provide your tv has a optical digital out put
You have the option of channeling the out put through either optical or HDMI in PS3.Go to the set up and set the audio out put to HDMI
Nov 28, 2008 | Samsung HT-BD2R 7.1 Channel Blu-ray Home...
I have no surround sound when watching normal T.V
Hi there, in order to listen to t.v you need to purchase an optical cable and plug this in the optical out of the tv to the optical in on the blue ray then select D.IN.1 on the blue ray and press mode on the remote until it says matrix . This will allow you to listen to the t.v through all speakers. hope this helps. Also remember to take the rubber protectors off the ends of the optical cable, a lot of people forget this :)
Nov 17, 2008 | Samsung HT-BD2R 7.1 Channel Blu-ray Home...
Getting home theatre sound AND sound from TV
i dont think you are suppose to have the tv speakers on with the theather systems speakers on because of the magnectic field can cause your tv speakers to mess up.
Jan 30, 2008 | Samsung HT-X40 System
I received an e-mail from Samsung which reads
"What you have described in your e-mail was an issue that was logged and has been investigated we have released a firmware update to resolve the issue"
also
"In order for the firmware to be updated on the unit please call our product support team on 0870 726 7864 for assistance"
Dec 16, 2007 | Audio Players & Recorders
SAMSUNG LE40R88BDX 40" LCD TV with DVD home Cinema system
if ur surround hasnt got digital in then it wont work also its better to use the red white and yellow wire, i have hdmi and them wires hooked up and i have sound through everythin all i have to do is put it on aux 2, try it out
Dec 02, 2007 | Samsung HT-X40 System
Digital optical connection is creating any sound
Check to ensure the Home Theater is outputting the digital audio via the optical cable.
Nov 21, 2007 | Samsung HT-TQ85 Five DVD 5.1 Channel Home...
Set up help!!
Firstly connect your home theatre outpu HDMI to HDMI input1 on the TV. Then connect the PS£ HDMI to the other HDMI input on the TV. Now connected the optical cable from the PS3 to the optical input of the home cinema system. Your should now have surround sound from the PS3 and DVD.
Sep 11, 2007 | Samsung HTP-1200 System
Samsung HT-X40 System Logo
557 people viewed this question
Top Samsung Audio Players & Recorders Experts
Mike Duncan
Mike Duncan
Marvin
Marvin
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
