1998 Mazda Pickup Logo
Posted on May 01, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Fuel requirements for mazda 1997 2300b
I have mazda 1997 2300b
I was install new fuel pump few month ago, but my truck is "lazy "
and have spark knock I went to mechanic and he told me it is pump
and wants 900$ for new pump
MY question is what is fuel pressure requirements for my truck?
How many gallons per hour?
If you know answer please send me on [email protected]
mike kirschbaum
Level 3:
Genius:
  • Master 1,198 Answers
  • Posted on May 01, 2009
mike kirschbaum
Master
Level 3:
Genius:
Answers
1198
Questions
Helped
359173
Points
3184
I think $900 is way too much. Have another mechanic look at your truck.
Spark knock
This would require the use of advanced diagnostic software to determine where the ECM is setting the timing.
1989 2600i no spark no fuel
Keep in mind the fuel pump only comes on if the car is being cranked over with the starter motor. Have you run a fault code test on the systems computer? If not you will need the daler to do that as it requires a Mazda scan tool for the OBD1 control system.
1997 buick hard to start why?
Have the fuel; pump checked for pressure bleed down after sitting, it should hold pressure within 5 PSI of rated running pressure after shutting sown the engine for extended periods.
Will a knock sensor code cause a no start situation?
The spark should be blue not orange.
But given the story of how it stopped running, I would expect to find water in the gasoline.
Did you drain the tank and put fresh gas in when you changed the pump ?
Did you check with the station to see if other people had problems from the gas that day ?
You should be able to spray carb cleaner into any vac hose to get it into the intake manifold as a way to boost fuel to the cylinders. You may want to disconnect the fuel line at the injectors and check for water too.
9helpful
2answers
Problem starting my mazda bt50 3.0 turbo Diesel 2007. had new injectors 6 months ago
Hi I have a problem, to start my 2010 3 liter mazda bt50.
I change the fuel pump but still the problem didn't solve
Top Mazda Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Mazda Expert? Answer questions, earn points and help others
