Question about Compaq P 1220 22" CRT Monitor
Compaq P1220 Had this Compaq P1220 for several months and the picture was bright and beautiful until one day recently it simply lost the picture.Upon repowering power LED goes green for a few seconds then reverts to orange which blinks 7 times before going solid again.. orange.the crt tube has no fire and I am curious as to where to begin to troubleshoot. Not even a test screen will show upon restart.I have experience soldering components and troubleshooting component level but with no available schematics and the proper equipment..am at a loss where to start.Any help would be appreciated.
  • 51 Answers
If that monitor is out of warranty, it's pretty much a throw away item. If you can find a "donor" monitor with a cracked CRT or case, you could probably swap the high voltage units and get it going again.
Posted on Oct 04, 2007
Why is my Bose radio is too dim?
The Bose Wave Radio has two brightness levels: Bright Hi (with a range of 8-15, and default of 10) and Bright Lo (1-8, default 4). The radio automatically goes from Hi to Lo when a room is darkened so the display doesn't interfere with sleep.
On recent models you can reset the defaults to make the display brighter or dimmer in both Hi and Lo levels.
1. Press and hold the Alarm Setup (Menu) button on your remote until -setup menu- appears in the display.
2. Then press the Tune/MP3 button until Bright Hi- appears. Use the Time - or Time + buttons to change the settings.
3. Go to Bright Lo- and adjust that setting too if necessary.
4. Press Alarm Setup (Menu) again to exit setup, or simply wait 10 seconds.
You're done! Note that if you set both Hi and Lo to 8, the brightness will stay the same all day and night.
Aug 21, 2014 | Bose Wave Radio
My P1220 has the problem that when it goes to powersave mode, it completely gets off. and it will not switched on for a while. if we kept the monitor fre for one or two days, it will work as usual(until it...
NO PC stated, NO OS STATED, must we guess it all?
the last running CRT monitor on earth fail 17 years old.
how amazing, no:?
lost the manual you did, google finds is if you had tried.
the OSD menu, works. push mon. menu button
turn off the sleep timer
RTM always works why not do that.
read the manual
your MON is so old its before modern VESA spec sleep modes were invented,
so it had this silly feature called the sleep timer, with clock
yes has a clock too, crazy no?
https://www.manualslib.com/products/Compaq-P1220-187767.html
page 6pdf.
tells me it does have vesa mode, sleep off the sync pins
on the same page this old relic,has DDC modes
but only work on moden PC< DDC uses a pin that was never used before on the VGA jack.
that same page also states, DDC2Bi (plug and play) only works on MONItgor jack B..
so note tell me your PC or its video card model if used.
or whaT this is (windows95.)>?'
we cant help much can we.
but you can test your monitor on another PC.
if that fails, the monitor is bad
but you must try both MON, rear VGA ports.
if the PC was dead, i sure can be.
youd have tried another barrowed monitor to prove that.
easy.
Oct 16, 2017 | Compaq P 1220 22" CRT Monitor
Where is the contrast and brightness button and how do you use it? My monitor is too dark hp nc6120
Just go to power options in control panel and click change plan settings of you current plan and move the slider right to increase brightness.Please note the left slider is for when on battery while the right slider is for when connected to AC power. Finished.I hope it helps
Dec 11, 2010 | HP Compaq nc6120 Notebook
How do you remove the white areas of a shot from flashing black when you look at the image?
What you're seeing is blown-out highlights. These are areas of your picture where the bright stuff (highlights) have been so overexposed (blown-out) that all detail has been lost. That's not necessarily a bad thing, but usually is. The proper fix is to reduce exposure slightly. Lost details in the dark areas are usually considered more acceptable than lost details in the bright areas.
If you simply don't want to see the blinking black/white parts of your picture, simply press up/down on the multiselector to select a different view of your picture.
Apr 25, 2010 | Nikon D40 Digital Camera with G-II 18-55mm...
Samsung moment randomly repowers
fuse on board needs to be replaced
check with a cell repair center
Mar 28, 2010 | Cell Phones
56HM66 Freezes and then cycles on and off.
i have same problem ?Could you tell me if you figured the problem out? solved it thansk
Sep 30, 2009 | Toshiba 56HM66 56" Projection HDTV
LG 47" LCD shuts down several times w/ blinking red light.
Granger1212 we had the same problem. We called LG and although our LG was out of warranty by 4 months, we were asked to supply our proof of purchase and LG sent a serviceman to our home and in 2 days we had our television back working wonderfully. It's the power supply, call LG and BE NICE, I'm sure they will fix it.
Sep 22, 2009 | Philips 42PF7421D 32 in. LCD HDTV
"Disc Boot Failure" upon powering up the compaq
your harddisk is not detected.
open your cpu case.
then reattch the power code and datacode to hard disk.
Nov 03, 2008 | Compaq Presario S6300NX PC Desktop
Did you fix your Compaq 1220?
Any time you have a orange light . The monitor or video card can be at fault. First check the monitor. Turn it on and see if it goes from green to amber. Check all monitor cable connections. to make sure the all 15 pins are there . If monitor displays a message that check video signal most likely video card is the problem. Make sure you have the cable connection plugged in the back of the computer into the video card. Usually a picture of a monitor. Then afterwards turn the monitor on first then the computer. If you do the other way around then the video card most likely will not engage.
May 07, 2008 | Compaq Presario 5000 PC Desktop
My camera taking crapy pictures
Where are you seeing images like this? More setail here please.
May 27, 2007 | Olympus EVOLT E-300 Digital Camera
Compaq P 1220 22" CRT Monitor Logo
542 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Lee Durbin
Lee Durbin
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
