Question about Kenmore 44102 Front Load Washer
Kenmore washer smells/mildew on rubber
My mother and I bought the same inexpensive Kenmore frontload washer about 2 years ago. They both smell horribly (I am trying the earlier solutions) plus my softener will not drain (trying that also). Our questions - the rubber that the door closes into is black with mildew. 1) Has anyone ever had that replaced? (we have sprayed with bleach) 2) Has it helped with the smell problem? 3) How did you get the smell out of your clothes and towels? 4)The detergent drawer holder (the part permanently attaced to the washer)has mildew inside. I have sprayed bleach and wiped, but I can't remove all. Please help! Thank you.
  • 2 more comments
  • alicefudge Apr 24, 2008
    My clothes never come out of the washer smelling fresh and clean. I always leave the washer door open to let air circulate and I wipe down the black rubber seal around the door after each use. I have had this problem since I purchased the washer. I do not use fabric softner, I use only the recommended e wash detergent. Any suggestions???
  • hilewe Oct 16, 2008
    my washer also has a bad smell - like wet laundry that has sat around too long. but it's not from the laundry - it's from water sitting under the drum and under the rubber in front. the water is always there and it gets "yucky." i use a towel to soak it up, but...
    how do you solve this problem???
  • Anonymous Apr 02, 2009
    I have this same problem. The gray rubber coil around the opening of the washer door hold water at the bottom, it sits in there and becomes nasty! I clean it out all the time and it never gets better. I was told that there was a kit you could purchase to fix this issue, the rubber coil is supposed to have a drain in it to release the excess water, so that is why the kit was made. Though I was also told the kit may not be available since it now is a part of the new washers that are on the market today. I'm not really happy with this front load washer and will probably never buy another one.
  • Anonymous Apr 21, 2009
    My close smelled too. Run a load with just bleach - no closet. The trick is acutally simple. Never leave the door closed - only durning washing.......yup that is it. Took me 8 years to figure that one out.
Can one purchase or order the detergent drawer holder (the part permanently attaced to the washer)has mildew inside? it is 970 serises
Posted on Oct 09, 2009
  • 447 Answers
The smell problem is actually because of the softener....its nassssty stuff it coats the interior of the washer and forms a grease like residue. I would use Washer Magic (available at all appliance parts retailers) (only half the container in front loaders) and a hot wash. Also keep spraying the boot with bleach and water soluiton every few hours it will dissappear after awhile. please rate my help
Posted on Oct 04, 2007
The controller has a burnt smell
If the washer is still was your cloth to the end cycle that ,ean the machine is good. To prevent the smell, make sure leave the door open after use. so the moisture not trap in the machine which can cause to smell for the next time you use.
Jan 04, 2014 | Kenmore Washing Machines
This kenmore washer makes my towels smell horrible this has been a problem for the two years I have had the washer. I can't take it anymore
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip about how to clean your washer
How to have a Clean Washer
heatman101
Sep 03, 2010 | Kenmore HE2 Plus Front Load Washer
Mildew smell
PLEASE KKEP IN MIND THAT THE MAYTAG NEPRUNE FRONT LOAD WASHER IS WHAT GOT MAYTAG IN TROUBLE!!!!!!
Whirlpool bought MAYTAG about 3 year ago.
THe mold is because of the rubber boot in the front of the door. PLEASE check to see if the rubber seal has a small hole in the lower bottom of the seal to let small portions of water drain out. If you DO NOT have this small hole, you need to replace the rubber boot with one that has a hole.
NOW, WORD TO THE WISE and this is what I tell ALL FOLKS that have a FRONTLOAD WASHING MACHINE:
AFTER you washer in the washer LEAVE THE DOOR OPEN so that the washer can ventilate and remove any moisture that is within.
ALSO, every 2 months, get a WHITE CLOTH with WARM WATER and a littl;e bit of BLEACH and CLEAN THE RUBBER BOOT!!!!!!
Nov 20, 2009 | Maytag Neptune MAH5500B Front Load Washer
My clothes smell horrible with my Ge frontloader. I have tried he detergent, cleaning the parts, bleach wash, leaving the door open. This is very frustrating considering how much it cost and the...
Make sure there are no leaks from the machine. look behind it and check the water inlet hose and connectors for any damage. Also look under the machine for any water as this may indicate a leak from the internal hose and pipe work and / or water pump. Also check that the outlet hose is completely clear of debris and soap scum build up and check that the filter is clean.
To keep the machine clean of waste build up and to keep any bad odours away
1. Remove all items from the washer.
2. Open the dispenser drawer and 2/3 cup (160 mL) of liquid chlorine bleach to the bleach compartment. DO NOT use more than 2/3 cup (160mL) of bleach per cycle as this will lead to product damage.
3. Close the washer door and dispenser drawer.
4. Select the Clean Washer cycle or a full wash cotton 104 F wash (40 C). DO NOT use any higher temperature as this will cause unnecessary fumes
5. Press Start and allow cycle to complete.
6. After the cycle is complete, leave the door open slightly to allow ventilation and drying of the washer interior.
7. Repeat the cleaning procedure monthly
Sep 30, 2009 | GE WSXH208A Front Load Washer
My expensive lg washer makes my cloths smell
Water is staying in the drum because it does not have the ability to pump put all the water. The only fix to this is after every cycle, take the little drain hose located near the bottom of the unit where you have to remove the cover, and take out the plug and drain into a small trash can. You will get about 4 cups water out of the machine. If this water is left overnight, it starts to mildew and will be washed over your next load. It's a design flaw, but this is the only solution. And one other suggestion, after you are finished washing clothes for the day and after you've drained out the remaining water, leave the door open overnight for the moisture in the unit to dry out.
Jul 16, 2009 | LG WM-2277HW Front Load Washer
I have exactly the same problem!
Try using the tub clean cycle and use a good dose of bleach or vinegear. Here is how to run the tub clean cycle.
To start the TUB CLEAN cycle:
1. Remove any clothing or items from the washer and close the door.
2. Open the dispenser drawer and add liquid chlorine bleach to the bleach compartment.
NOTE: Do not add any detergent to the detergent compartments. Excessive suds may be produced and leak
from the washer.
3. Close the dispenser drawer slowly.
4. Power On and then press the Extra Rinse button for 3 seconds. (Prewash option will be selected.)
5. Press the Start/Pause button to start.
6. After the cycle is complete, leave the door open to dry around the washer door opening, door seal and
door glass.
Jul 11, 2009 | LG WM2688HWM TROMM SteamWasher
My Kenmore series 70, top loading, washer has a mold smell.
thaty have this one stuff called affresh its used for frontloaders but you can use it for toploaders too it works great
Mar 24, 2009 | Kenmore 22422 Top Load Washer
Moldy smell in front load kenmore washer
I had the same problem. Have you cleaned the filter under the front panel? Simply remove the three screws holding the panel below the door and remove the 2" white screwcap. Be sure to have a basin handy to catch the water. (possibly a couple of gallons if the stainer is really clogged) I suspect you'll find several moldy items that are causing the odor. Good luck.
Feb 28, 2008 | GE WSXH208A Front Load Washer
Frigidaire GLTF2940ES Front Load Washer
Have you tried using detergent HE (High Efficientcy) for front loaders? I had this problem and changed over to HE Detergent (Tide) and it solved my problem. Good Luck
John 3:16
Dec 28, 2007 | Frigidaire GLTF2940ES Front Load Washer
Kenmore 44102 Front Load Washer Logo
873 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
