2006 Toyota Sienna Logo
a
annette Posted on Nov 08, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Rear door handle snapped off.
Can't figure out how to access the exterior handle mechanism
Denny Giesel
Level 3:
Master:
  • Master 818 Answers
  • Posted on Nov 08, 2013
Denny Giesel
Master
Level 3:
Master:
Answers
818
Questions
0
Helped
152739
Points
2428
Remove the inside trim card-there's a pull handle with bolts or screws remove those then the rest pops off-can be hard to pull off-after this is off you should be able to get to the nuts that hold the handle--cheers Denny
3 Related Answers
Anonymous
  • 154 Answers
  • Posted on Aug 04, 2009
SOURCE: replacing exterior door handle on 1998 camry
remove inner panel .. unhook handle assembly and rods.. to replace
Anonymous
  • 3153 Answers
  • Posted on Sep 13, 2010
SOURCE: side door handles are broken. rear door handle is
Hi Bluee
I am sorry but even though you provided a great answer your peers are no longer allowed to vote for you without fear of disciplinary action.
However on this occasion I will risk it for a biscuit
Anonymous
  • 27 Answers
  • Posted on Aug 02, 2012
SOURCE: How do I repair the exterior door handle on a 1999 Toyota Camry ? Will it be necessary to replace the entire door ?
No the door handle is easily replaceable. you do have to remove the door panel and roll the window all the way up. 2 10mm nuts inside the door cavity and one bolt on the door jam near the lock mechanism. These handles are made of plastic and degrade and break easily after 3 or 4 years. Every toyota owner has to deal with this at some point. I also recommend buying the new handles on ebay as opposed to the dealer. The aftermarket handles are better quality than the original and MUCH cheaper. They are ALWAYS available on ebay.
1helpful
Were does the LH mirror on a 2011 f-250 connect. Removed mirror but disconnect is located some were in door or body. need to know what needs to be removed to gain access
  1. Remove the front door trim panel.
  1. Position aside the front door watershield to gain access to the exterior rear view mirror control switch electrical connector.
4.Disconnect the exterior rear view mirror control switch electrical connector
as you see you have to remove the door panel to have access to the electrical connector in case that you dont know how to do it here are the instructions
NOTE: Left front door trim panel shown, right front door trim panel similar.
  1. Remove the sail panel.
    • If equipped, disconnect the electrical connector
  2. If equipped, lift up and remove the exterior rear view mirror control switch panel.
    • Disconnect the electrical connector.
  1. If equipped, lift up and remove the window control switch panel.
  1. If equipped, remove the window regulator handle.
    1. Position the window regulator handle cover aside.
    1. Remove the window regulator handle screw and regulator handle
5.Remove the door trim panel center screw cover
6.Remove the 2 door trim panel center screws
7.Remove the 2 door trim panel lower screws
  1. NOTICE: Do not pull directly outward on front door trim panel as damage will occur.
    • Lift upward to remove the front door trim panel.
  1. NOTICE: Insert the lower panel tabs first or they can break when installing the front door trim panel.
    To install, reverse the removal procedure
Thank you for your response , been going crazy here...got panel off enough to put hand in but don't know where to pull to unlock door.
Jaguar 2000-06 - Locks & Lock Systems
Power Door Locks - Removal & Installation
Door Lock Switch
Door Lock Diagnosis & Testing
  1. Visually inspect the following:
    Misaligned door(s), hood or luggage compartment lid Door latches Actuating rod Exterior door handle Interior door handle Door lock cylinder Cable Luggage compartment lid exterior release switch Fuse(s) Wiring harness Electrical connector Door lock actuator Remote transmitter batteries Vehicle battery Remote transmitter Door lock switch Front electronic module
  2. If an obvious cause for an observed or reported concern is found, correct the cause (if possible) before proceeding to the next step.
Door Lock Motor
Coupe And Convertible
  1. Turn ignition key to position II.
  2. Motor door glass to fully raised position.
  3. Turn ignition key to position O.
  4. Disconnect the negative battery cable.
  5. Remove door casing for access.
  6. Remove door water shedder.
  7. Position PVC secondary water shedder for access.
  8. Slacken and remove the door glass rear runner lower securing screws.
  9. Reposition door glass rear runner. Mark the position of the glass rear runner upper securing screw.
  10. Slacken and remove the upper securing screw and move the runner away from the glass.
  11. Disconnect door handle and lock barrel (driver door only) operating rods from latch links.
  12. Slacken and remove the three latch assembly securing screws and position latch for access.
  13. Remove latch motor harness multiplug from mounting bracket and disconnect multiplug.
  14. Release operating cable from door handle. Move inner door handle to the locked position. Remove operating cable outer abutment from support bracket. Disconnect cable inner from door inner handle.
  15. Remove lock motor assembly from door.
  16. To install, reverse removal procedure.
    Fig. Removing door lock actuator
Sedan
  1. Remove the door window glass
  2. Detach the interior door handle.
  3. Detach the actuator remote cable from the interior door handle.
  4. Remove the interior door handle.
  5. Detach the door window glass run.
  6. Remove the exterior door handle retaining screws.
  7. Remove the front door actuator retaining screws.
  8. Reposition the front door actuator and exterior handle.
  9. Remove the front door actuator and exterior handle.
  10. Disconnect the front door actuator remote cable.
  11. Detach the door lock cylinder connecting rod (1).
  12. Detach the exterior door handle connecting rod (2).
  13. Remove the front door actuator (3).
  14. To install, reverse removal procedure.
    Fig. Removing door lock motor-Sedan
Hope this helps.
2helpful
Install door latch cable
Technical Instructions
See picture below
1. Remove door trim panel and water shield per
NOTE: Place a strip of masking tape along the edge of door before removing trim panel to prevent scratching the door with the trim panel removal tool.
2. Snap cable housing end from slot on inside door handle assembly and disconnect cable.
NOTE: Use care to prevent bending of cable housing retainer bracket.
3. Remove rear window channel retaining bolt to allow access to door latch.
4. Position a block (screwdriver handle) between the latch and the door inner panel and snap the cable housing end out of slot (towards inner panel) on door latch assembly and disconnect cable at latch.
NOTE: Use care when removing cable housing to avoid bending of the latch. Discard cable.
5. Hook up new cable at latch and snap cable housing end into slot.
NOTE: Make sure the cable housing is fully seated in the slot.
6. Apply a light film of Teflon grease to the barrel end of the cable. See Figure A.
7. Install return spring. See Figure A.
NOTE: Ensure that the push button rod is located between the spring and the door inner panel.
8. Install foam block at latch. See Figure A.
9. Position water shield over the return spring and install push pin to retain upper portion of water shield. See Figure B.
NOTE: Push pin goes in the same hole as the return spring.
10. Clean hands of grease before performing step 11.
11. Remove protective backing along the lower edges only of the water shield. See Figure A.
12. Install latch water shield at door latch. Pinch the exposed adhesive surfaces together to secure the water shield. Check to insure water shield is not showing through the door shut-face latch access hole. See Figure B.
13. Attach cable to inside door handle assembly and snap cable housing into slot.
NOTE: Make sure the cable housing is fully seated.
14. Check the gap as shown in remote control using a 3/16 drill bit shank end. The drill bit shank should fit in the gap without any clearance and a tight fit is preferred. See Figure C.
15. If the drill bit is too loose or does not fit, adjust by bending the cable bracket as required.
16. Place plastic wedge on remote bracket as shown. Wedge must fit with at least a light press fit for retention. See Figure D.
17. After installation, Apply a dab of special Teflon grease, supplied with the service cable to cable housing openings at inside handle end. The grease should surround and contact the cable all the way around, to seal the opening between the cable and the cable housing.
18. Check all latch functions to insure correct assembly of latch system. If the inside handle does not release properly, replace the inside handle remote release mechanism.
19. Reposition and install trim panel using new push pins if required.
NEED TO REPLACE THE EXTERIOR DOOR HANDLE
HAVE TO REMOVE THE DOOR PANEL REMOVE ALL EXTERIOR OR VISIBLE FASTENERS AND MOST DOOR PANELS HAVE PLASTIC CLIPS ALSO SECURING THEM TO THE DOOR FRAME.ALSO ANY ELECTRICAL WIRING INTERFERING WITH PANEL REMOVAL. THEN ACCESS THE TWO NUTS/BOLTS ATTACHING IT THE THE DOOR FRAME. THEN REMOVE THE RODS ATTACHED TO THE HANDLE GOING TO THE LATCH/LOCKING MECHANISM AND REVERSE THIS PROCEDURE FOR INSTALL.
Driver exterior door handle broken need to replace
take the 5 screws out of the door panel and use a trim tool from your local auto parts store and pop the plastic snaps holding your door panel in then you can access the screws holding the handle in your door...
2answers
How to change a gmc yukon driver side exterior door handle. door handle has come lose
take the door pannel off there will be a 10mm nut holding it on also there is a 10mm bolt on the side of the door you must remove also. after just pop the handle out disconect lock rods and its off
1helpful
Inside handle will not open door. Can not figure out how to get latch out of door to look at problem. Pulled door panel, moved window rail, 3 screws from latch, and cable mount attached to latch. How do...
There are plastic clips that hold the rods in place - one for the rod that goes to the exterior handle and another that goes to the exterior lock. You need to snap the plastic clips around so they release and then the rods will pull right out.
3helpful
How to replace '96 Ford Explorer driver side exterior door handle
You will need to remove the door panel to gain access to the handle. Roll the window up or down as needed to get to the nuts that attach the handle to the door. You will also need to remove a rod the goes to the door lock. You will see the rod after the door panel is removed. Good luck.
Top Toyota Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
ROBERT GARCIA
ROBERT GARCIA
Are you a Toyota Expert? Answer questions, earn points and help others
