What is the x wire use for on a ruud achiever 90 plus
SOURCE: Ruud achiever 90 plus wouldn't start
Thanks for the carefull description of the fault, The vent system is designed so that if a leak occurs fresh air from the living space will be pulled into the vent rather than dangerous combustion gases pushed out to insure this there is a carefully calibrated -pressure switch that will not allow the unit to fire unless a negative pressure on the vent is proven this can be prevented by many things, here are a a few :a sticky micro switch, a leaking hose from the vent to the pressure sensor, cold stacking in the flu(either a down draft or extremely cold air in vent that restricts warm combustion air from being pushed out), a problem with the power exhaust fan(debris has gotten in the housing preventing an easy start), i usually find the cause to either be a bad pressure sensor hose or debris in ths exhaust fan housing either blocking blade movement or obstructing the pressure sensor hose port.
To clear the fault turn of the breaker to the unit then restart the unit and fallow the sequence of operation to see where the fault occurs the fan should come on first then the exhaust blower should come on when negative pressure is achieved it start the lighting sequence if the lighting sequence doesn't start and you get the same fault take the neg pressure hose loose from the exhaust fan housing and start the sequence again while pulling a slight negative pressure on the pressure sensor with a hand held pump continue this process until you find the fault.
SOURCE: ruud achiever 90 plus blower not working
does the furnace ignite?? your system may not have been lighting and has gone into ignition lockout count the codes of the led lights then remove panel led diagnostic codes are listed there.
if led codes indicate no problem verify capacitor is good and that mtr is getting 115 volts.
SOURCE: Ruud achiever 90 plus gas furnace not blowing any heat
These new furnaces are trouble. Ive been in the htg trade for 25 yrs. The fan is running because they are now controlled by a timer instead of a temperature control. Rather than sensing a preset temperature and turning on the fan, it comes on by a preset time. Couple of things, does either of the doors have an inspection window? most newer furnaces have what is called a smart board. The board will flash a trouble code. ie: 1 long 2 short etc. #1 turn your thermostat to off, youll need 2 people for this! Go to the furnace, If it has the above mentioned inspection window ( usually about 2" round) while peering through the window have someone turn the thermostat to about 80 degrees. Let the furnace cycle and see if it flashes a code. If it does the codes are usually on the bottom door, May be on the inside. The most common cause is either a bad transformer, bad hot surface ignitor or pressure switch failure. Further questions feel free to ask. Steve
SOURCE: i have a Ruud Achiever 90 plus furnace that will not ignite
Again is this a spark or a glow coil? If it is a glow coil look at the coil and see if there is a crack or white spot on it. If so it needs to be replaced.
