Question about Nikon Coolpix 5600 Digital Camera
Will No Longer Format SD Card
Actually, it shows all SD cards as "Write Protected" even though they are not locked. Ready to throw camera out the window. Any last minute suggestions . . . like, "Open the window first!"
  • Thunnar Oct 08, 2007
    It was a good idea, but tried it twice without success. Think I will just get a different camera. Thanks
  • Anonymous Jan 04, 2008
    when the memory card is in the camera it has write protected on it?? What does this mean and how can i get rid of it??
    Problem Solver:
  • 13 Answers
I'm assuming that you have used tried other SD cards? If so, have you tried to do a factory reset of the camera? If you have tried that and it still hasn't worked, I have one last suggestion that might help you. First, remove the battery from the camera. Once the battery has been removed from the camera get yourself a bottle of Isopropyl Rubbing alcohol and some q-tips. I tell you where I'm going with this: The contacts for the SD card in the camera could be dirty thus not allowing the camera to send the "write" message to the card, hence you get the write protected message. We going to clean the contacts to try and get it working again. One you have all the supplies, lay an old memory card down on a table with the connector pins face up. Use a memory card that you don't have any pictures on in case this process damages the data on the card. Take the q-tips and dip them in the alcohol and get a liberal amount of fluid on the tip. Next, coat each pin so that it is somewhat wet with alcohol. Don't use too much, you don't want to soak it. Next insert the SD card into the camera horizontally so that you can get the alcohol to the pins in the camera. To clean the pins remove the card and insert it several times. Repeat this whole action three to four times. Remove the SD card and let the camera stand in a position that would let the pins if they were wet drip down toward the surface. The pins should not be sopping wet, I'm just try to convey that this is how the camera should be left to dry for the next hour. After an hour or so try using the SD card that you cleaned the pins with. If it works, enjoy! If not, drop me a note. Good luck If you want me to continue to help people with there problems, please rate me!! Thanks
Posted on Oct 04, 2007
SOURCE:
My M100 shows SD card error What to do
The card may be full, corrupted, or have the write-protect switch set. Is it readable in your computer ?
Nov 17, 2016 | Cameras
HOW TO FORMAT WRITE-PROTECTED MEMORY CARD
SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Sep 07, 2014 | Cameras
When i try to format my micro sd card system shows remove write protect how can i format it
Hi, i have here a photo that will show you on how to remove write protect on a micro SD.
1. You need to insert your micro SD into an adapter. 2. Unlock the micro SD through your adapter as shown below. 3. Once done, your micro SD is no longer write protected. eibraz_16.jpg
NOTE: The lock switch doesn't lock the micro SD into the adapter; The lock switch doesn't lock the data on the micro SD; The lock switch simply tells the "user" not to write. It just says "please, don't write me."
I hope this helps.
Aug 09, 2011 | SanDisk 2GB microSD Memory Card
Memory card error card says locked
Hi!
SD cards (or MicroSD, using an adapter) are locked using a mechanical switch on their left side.
Simply, take the SD card (or the SD adapter) and change the switch position.
Usually the UP position is the Unlocked position...
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
B
est regards,
Pelu.
Jan 04, 2011 | Canon PowerShot SD1100 IS Digital Camera
Micro sd memory card for 3110c password protected was forgotten
connect ur memory card, to the comp. through card reader,, then format it,,, lock will be opend
Jan 09, 2010 | Nokia 3110 Cellular Phone
My Fuji digital camera model Finepix Z20 is showing a protected card message when I insert both my old SD card and my new SD card. My old SD card was working fine yesterday but now it says protected c
Good day,
This is a common problem that many people experience with their SD Cards.
It is normally an easy fix and you can follow a method that I posted on my tips here:
http://www.fixya.com/support/r7042428-sd_card_write_protect
Please feel free to let me know if this was helpful!
Regards
May 06, 2009 | Fuji Finepix Z20fd Digital Camera
Polaroid a300 camera is saying sd protected
Well, make sure you have checked the small gray tab on the left side of the sd card. It needs to be in the unlocked position. Too bad for me, because i have the same problem and my sd card isn't locked...
Nov 05, 2007 | Cameras
SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Oct 30, 2007 | Polaroid a300 Digital Camera
Card Error
If the memory card is not recognized in the PC or it is impossible to access the data on it, the controller on the card is damaged. There is only one way to get the data back, unsolder memory chips and directly access their raw data with a programable chip reader. Software can't help, that is a physical damage! Have a look at: http://card-recovery.biz/us/service.php
Sep 11, 2005 | Toshiba PDR-M25 Digital Camera
Nikon Coolpix 5600 Digital Camera Logo
42 people viewed this question
Top Nikon Cameras Experts
Ric Donato
Ekse
pictureman4u
Are you a Nikon Camera Expert? Answer questions, earn points and help others
