Question about Nikon D40x Digital Camera
Nikon D40 built in flash not working, it seems the the flash will not popup when you take a photo indoors when it should. Has anyboby any idea why and how it can be fixed, and how much would it cost to fix it? Any info welcome.
  • 5 more comments
  • gball Oct 04, 2007
    Thank for this, but in the first problem, I forgot to say that it fall from about a foot to the ground. The strap got cought onto the edge of a church seat as I was walking by. So this in turn prob broke it.
    Any other info welcome and want should I do next.
    Yes the lightmeter is working, thats the little light at the side that flashes before the main flash. I have taken photos in a dark place and still does not work. The flash icon is diplayed when you take the shot, even if I change the flash settings in the main menu it still does not work. When you press down to shot it sounds like the flah is trying to popup, but does not maybe as you said mechanicaly jammed. Any other ideas?
    Thanks a mill.
    Hi, you can open it manualy by pressing a button to the side of it, but this those not function now, but I dont know if it ever did becauce I dont have it long. You have to open it yourself like forcing it open, but still will not flash even when open. When it is up then when you try and put it back down again it takes a few trys to click it back into place, it look like it not lined up in the right place.
    Hope this is more info.
  • 4267foxy Dec 23, 2007
    I have just purchased my Nikon D40. I took a few photos with it and everything seemed to be fine. The flash was working fine. However, after about ten minutes of flashing photos the flash fails to work. I have reset everything to default. I have removed the battery and replaced it, I have charged the battery to full charge, I am at a lose as to what to try now. The camera was not dropped or damaged in any way.
  • smsagor Dec 24, 2008
    My flash is firing but, the photo is still dark. I took a photo in front of a mirror & found a mismatch of time in btn the shutter and flash firing. How to solve it ?
    S M Sagor
    smsagor@live.com
  • seeadawn Feb 18, 2009
    i got my nikon d40 a little over a month ago and the flash was working fine when i first got it. But about 2 weeks after having it, the flash started taking forever to open. It would come up, but it came up soo slowly that i'd have to lift it the rest of the way.
    after about a week of that, the flash just stopped working completely. it opens, ( just as slowly as before) but it wont actually flash.
    and when you push the shutter release half way, the flash clicks trying to lift it up, but the flash is already up.
    i hate using flash in the first place, but i never new how much i needed it until it broke =/
  • nikon user12 Mar 21, 2009
    Hi I have the exact same problems as seeadawn, my nikon d40x takes about 5 to 10 secs to open, although it after that still fires...have you got a final solution?
  • 93 Answers
Check if the flash is by accident set to OFF.
Posted on Oct 04, 2007
  • 1 more comment
  • Mico Dukic Oct 04, 2007
    Oh, that's not very good. Try to check is the in-built lightmeter works at all. Try to take a shot in the dark place and see do you have a flash icon in display (or viewfinder). Try to set flash settings to FORCED ON (to flashes in all ocassions) and see will it work. Maybe pop-up flash is mechanicaly jammed.
    I'm preety shure that you have mechanical problem. I'm not familiar with thic particular product, (I have Panasonic Lumix DMC-FZ50), so if my questions don't make sense, sorry.
    Is there any way to open flash manualy? Problem could be and lever which lifts flash, also.
  • Mico Dukic Oct 05, 2007
    Yeah, it not lined up. Hope that all parts are in one piece. Worth to try carefuly put it back into right place. Try to chech with ohmmeter is the flashbulb OK, and contacts leading to bulb. When you shake the camera do you hear that something is loosen in it? If you do, that's not good, because taking camera apart is job for experts.
I have a Nokon D40 DSLR and a Vivatar Zoom Thyristor 3500 flash that I want to fire off camera to capture high speed photos.I would have the D40 in dark room with shutter in bulb setting. any Ideas
You can either use a PC cord to connect the flash and camera, or you can use a remote trigger to fire the flash cordlessly. Your local camera store should be able to provide options for both.
Jan 25, 2017 | Nikon D40 Digital Camera
Fmay nikon d40 flash in not working..
You might be shooting with a higher ISO or in settings where the D40 meter finds enough light and doesn't activate the flash.
Try changing the ISO to a lower one, like ISO 200 and take some test shots indoors, in a darkened room.
OR, you might have the mode dial set to "no flash". That's the crossed out lighting-bolt symbol. Just set it for P or another mode and you're back in business.
Hope this helps
Mar 02, 2011 | Nikon D40 Digital Camera
My popup flash on my nikon d40 didnt fire when i open the popup, and cant take picture..
Go to service center. it may loose the cable connection. don't fix it. it may lose your warranty.
Apr 14, 2010 | Nikon Photography
Nikon d40 built in flash not firing but it popped up
there is a sensor in there that tells the camera the flash is up you need to take it to a repair shop its not a at home thing
Mar 11, 2009 | Nikon D40x Digital Camera
Nikon D40 shutter speed problem
The D40 will not take great photos of an indoor event without blurring or noise. You need a fast lens and a high ISO using the popup flash or on camera flash would be ideal but some of these events you can not use flash. All these images I shot with a Nikon D40. http://www.facebook.com/home.php?src=fftb#/pages/Keller-TX/Raving-Design/78762448229?v=photos&ref=ts Learn to use the camera for ur events. Experiment it's all about trial and error. Ray
Dec 20, 2008 | Nikon D40 Digital Camera with G-II 18-55mm...
Dark wiew
is it set to auto? if not i suggest you check the aperture and shutter speed setting :)
Sep 22, 2008 | Nikon D40 Digital Camera with G-II 18-55mm...
Nikon D40 Image Darkness
You probably have "bracketing" turned on. In your menu settings, search for bracketing and make sure it is off.
Feb 10, 2008 | Nikon D40 Digital Camera with G-II 18-55mm...
Nikon D70 - indoor flash problems
Unfortunately, you may have a faulty flash pcb (printed circuit board) The part is around 50$ plus installation 200+ total repair cost. A work around would be to use an external flash unit from the hot shoe
Dec 26, 2007 | Nikon D70s Digital Camera
Nikon D40x Digital Camera Logo
1,205 people viewed this question
Top Nikon Cameras Experts
Ric Donato
pictureman4u
Geoff Hone
Are you a Nikon Camera Expert? Answer questions, earn points and help others
