Question about Acer Aspire 5670 Notebook
Aspire 5634 Monitor Screen Dead
I suspect its to do with the leads connecting the monitor, but how do i actually open the thing?!?!
  • chemovio Oct 16, 2007
    yes it is but cant find my reciept of purchase seen as i moved house! bad days
  • 51 Answers
Is it under warranty?
Posted on Oct 04, 2007
SOURCE:
Black screen during startup Acer Aspire L310
Has your monitor worked for it in the past? This may be a stupid question, have you also tried to use your monitor with another computer?
It's possible your graphics controller is out, have you checked the cables insides to see if any wires are bent? Or have you tried to use another cable for the monitor to tower connection?
If you have done all of the above and the monitor works with another computer, it's possible your GPU is out :(
If your GPU is out, you can buy a new one in it's place and it will plug into a PCI slot, chances are your graphics card is integrated.
Do you get any beep codes on the computer? Another odd chance could be the computer itself is actually dead, even if a computer is dead a motherboard can still be active since electricity can still flow through it.
I hope this helps. x: I hope your problem is resolved sooner than later.
Feb 26, 2013 | Acer Aspire L310 Desktop
My Acer Aspire R1600 is not getting a signal from the monitor. The acer is connected to a switch which also connects to a Mac. The Mac works fine. I plugged the monitor directly into the acer and still...
Hello, try and see if you can start it with another monitor. Or another video cable, it might be the cable is busted...
If neither of these yield any relief - check if Acer actually starts when you press the power button (it might be monitor does not come up because there's nothing to show if Acer is still dead).
If Acer starts OK, but still no video signal, check its video port, or video card inside.
Jan 12, 2018 | Computers & Internet
Screen won't come on !!
Hello
The problem you are experiencing might be as a result of virus or the screen of your laptop is damaged.All you need to do is to connect your laptop with an external monitor to know if its the screen or not.
If the screen is damaged then it needs to be replaced.
GOODLUCK
Jul 28, 2010 | Acer Aspire One PC Notebook
Monitor will not stay on
First of all check your mains lead make sure it is not fused. then check the lead from the monitor to the computer make sure it is connected ok then check your video card You can try connecting the monitor to another computer to see if it works on that one
May 01, 2010 | LG 22" FLATRON LCD Monitor
I have a aspire 5610 , the problem is when the laptop coming up just showing windows logo and after that nothing , i did try with monitor and thats showing same thing , i want to know the problem is with...
If you are seeing the same thing on your Notebook screen and an external monitor then it is most likely NOT the monitor, and VGA would be more suspect. Before doing much else though, right click a blank spot on your desktop and click "Personalize"; go through the various video items there to try to make things more useful. Let me know, OK?
Dec 02, 2009 | Acer Aspire 5610-4648 Notebook
I have just bought a VGA canble and sound lead to use my Samsung LCD TV as the monitor for the Acer Aspire 5920. When the power lead is turned on there is a flickering constantly on the screen and an...
I hook an HP to a Samsung HDTV in much the same way. Two things, if you connect to the monitor out on the laptop after it's already started up with Windows loaded, you will need to do a restart to activate the monitor out. You can leave TV on during this process. Second, be sure you have selected the correct input source on the TV. Mine actually has a PC input and that's how it reads when I select it via the TV's remote.
Something I've done since that you may want to consider is upgrading to a graphics card (via PCMCIA card or if daring enough you could try upgrading the internal mini-PCIe graphics assuming your PC is capable of that) that support DVI or HDMI out. This method is better if you intend to connect through a home theater or surround amp.
Oct 19, 2009 | Acer Aspire 5920-6727 Notebook
I am trying to connect my Acer Aspire Desk top and my Advent 4211c Notebook to this screen using a 15 PIN Analogue Monitor Lead .VGA Monitor Cable ? No luck ?
There is a switching methode..pressing the Fn switch then F4 (One Monitor Symbol is there),you will get the result..
Jul 10, 2009 | Computers & Internet
Acer aspire 5220 booting problem
Try connecting to an external monitor. If it displays on the external monitor then the LCD is probably dead. If it doesn't display on the external monitor, its a problem with the video card.
Feb 25, 2009 | Dell Inspiron 6000 Notebook
Acer 5634 laptop screen occasionally turns pink!
You have broken wire that connect screen to the motherboard, when moving screen it connect somtime and sometimes disconnect. It about 18pin wire but only one is broken.
Jan 12, 2009 | Acer Aspire 5630 Notebook
Acer Aspire 5670 Notebook Logo
35 people viewed this question
Ekse
Alun Cox
