Washed seat cover need diagram to return seat cover to stroller
SOURCE: how to wash maclaren techno classic seat cover?
the material does not clean well with regular methods;
however; any upholstery cleaning company or, drycleaner should be able to do this job
SOURCE: How do i remove the
Hi Marion, All the Maclarens are pretty much the same with exception of the vintage Macs and the Daytrippers. Their fabrics are bolted on. Ok to remove the seat cover I tend to start with the uncliping the shoulder straps 1) go to the rear of the pushchair where the top of the shoulder straps sit. You will see the black/grey clips that are attached to the end of the harness 2) feed each one back through the hole/slot in the plastic backrest all the way through to the front seat cover side. So you have released both shoulder straps 3) Then you need to do a similar thing with the lap sections of the harness HOWEVER on the newer models you have an added complication. Before we continue I tend to use a flat head screw driver JUST TAKE CARE WHEN USING TOOLS. Before feeding the harness from front to the sides of the stroller you will need to separate the lap section from the section that actually clips into the **** section to lock the child in. You need to separate the lap section from the remainder of the harness. You take the screwdriver and gently AWAY from you just lift the black plastic that is rectangular in size and about 1 inch long raise the right hand side and release the lap section from the remainder of the harness 4) now you can feed the lap section of the harness from the front of the seat through to the rear. 5) then repeat this on the other side 6) what we're still in that area if you look either side Of the stroller seat section just under the frame about an inch away from the lap sections you have just f'ed through there is a single round peg where the middle section of the seat cover attaches itself to the seat cover as an added safety lock so there's no movement. You release the seat fabric from the chassis on both sides NEARLY THERE LAST BIT ALMOST.... 7) now you need to remove the **** section to release the bottom section of the seat cover. You should be able the start from the back and feed this back through to the front of the seat cover 8) then you should have released all the sections of the harness from the buggy frame. Now simply pull the top of the seat cover off the two rods either side Of the backrest and the remainder of the seat cover should come off. Once you need to replace then just do the opposite to get the harness f'ed back through the seat cover, etc. Really do hope this helps you. Regards, Liz.
SOURCE: The baby sitter have removed
Try here for a manual www.karlisles.com.au/baby_repairs_spares/instruction_manuals_Maclaren.html
