Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
code p0153 refers to heated oxygen sensor-1 bank 2 slow response/no activity detected===causes ---heating inoperative---wiring---oxygen sensor. code po133 refers to the same problem as 153 and states the oxygen sensor several times so I would be replacing that unit.
Hi there: Both generic codes refer at Oxygen Sensors, an HO2S that responds too slowly is most likely defective. In order to solve it just replace the HO2S; check there description and diagnosis: - DTC P0136 - O2 Sensor Circuit Malfunction (Bank 1 Sensor 2) - DTC P0153 - O2 Sensor Circuit Malfunction (Bank 1 Sensor 2)
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
the tech is right.. the trouble codes do not tell you what is wrong with the car... they just give you a general area to look in which involves testing multiple components and sensors. if the tech quoted you for and hour diag time i would say that you should at least expext to spend somewhere in the 300$ area depending on part cost.
