The unit runs for 2 minutes, then stops-fan & compressor off, but indicator lights on. Frost forms on top coils before shutdown. Can power OFF, then ON after a short time, and cycle repeats itself. Mike
Top of Form
If there is no cooling
at all , before we go further we must confirm the first step of confirming the
compressor and gas pressure. So shut off the fridge and leave it off while you
clean and check the evaporator for frost. If frost is seen it is a good
indication as the compressor is working with sufficient gas within.
Now after about 6 hours plug in the fridge to start. Observe cooling to happen
in about one hour and ice to from under three hours.
Earlier make sure that the thermostat was set to normal mode for freezer and
fridge. If there is no ice formation we have a big issue as the compressor and
gas must be checked out. If compressor is running check the pressure, get help
to test gas pressure. If not you will need to fill up ,If gas pressure is good
the possibility of the compressor being inefficient is high. In such a case you
must take consensus to estimate and decide, if RPM of motor is low check
capacitor.
However if Ice forms then observe the fridge for about 24 hours for cooling to
continue and the fridge to cut off. If not the auto defrost timer, or the
thermostat must be checked.
The ventilation fan that
circulates the COLD air from the evaporator coils could get clogged with frost
and so could be jammed. Also the wires to the fan can be worn out due to the
frost. If so check if the defrost timer works to switch the heater to remove
the frost. Also the check if the compressor is shut down by the timer /thermostat . If the
heaters are not working, check continuity of the heaters.
So attempt to test using a multi-meter / clamp tester from the outside and make
your observations so that we come to the solution.
Please check this link
for tips to work.
http://www.espares.co.uk/advice/fridges-and-freezers/a/2
Thank you for using Fixya.
Top of Form
If there is no cooling at all on the fridge section but the freezer works then it is confirmed that the compressor and gas pressure is OK. Now shut off the fridge and leave it powered off while you clean and check the evaporator for frost. If frost is seen it is a good indication as the compressor is working with sufficient gas within.
Now after about 6 hours plug in the fridge to start. Observe cooling to happen in about one hour and ice to from under three hours.
Earlier make sure that the thermostat was set to normal mode for freezer and fridge.
However if ice forms in the freezer then observe the fridge for about 24 hours for cooling to continue and the fridge to cut off . If not the auto defrost timer, or the thermostat must be checked. Frost formation without defrosting could block the air flow and so shut the air passage to the fridge. Also the blower fan must work and if this is not working then the fan can be faulty. Also a fault on the control unit is a suspect to non functioning of any one of these components.
If defrost timer works but frost keeps forming check while the compressor shuts if the heaters are working, check continuity of the heaters.
So try this test using a multi-meter on the defrost timer and the thermostat and make your observations so that we come to the solution.
Please check the link below for tips to remove the panels/parts:
Top of Form
Top of Form
If there is no cooling at all , before we go further we must confirm the first step of confirming the compressor and gas pressure. So shut off the fridge and leave it off while you clean and check the evaporator for frost. If frost is seen it is a good indication as the compressor is working with sufficient gas within.
Earlier make sure that the thermostat was set to normal mode for freezer and fridge. If there is no ice formation we have a big issue as the compressor and gas must be checked out. If compressor is running check the pressure, get help to test gas pressure. If not you will need to fill up ,If gas pressure is good the possibility of the compressor being inefficient is high. In such a case you must take consensus to estimate and decide, if RPM of motor is low check capacitor.
However if Ice forms then observe the fridge for about 24 hours for cooling to continue and the fridge to cut off . If not the auto defrost timer, or the thermostat must be checked.
So try this test from the outside and make your observations so that we come to the solution.
Wishing you a Happy and Prosperous New Year.
Are you still having trouble?
