Question about Sharp 27C-240 27" TV
Sharp (friendly series)
I turn on the tv and then the monitor show this: STEREO SAP MONO what is this means? what button should i press?
  • ajwhc Jan 09, 2008
    I have a new sharp 27inch tv, that shows
    STEREO
    SAP
    MONO
    how can I get rid of the display?
    Genius:
  • 1,694 Answers
1)Stereo==stereo sound 2)SAP=second audio program,i.e.alternate language 3)Mono=all the sound,left side & right side, no stereo effect Hope this is helpful--let me know.
Posted on Oct 04, 2007
Hello friends...i have a 15 lcd of alba company..model no alcd15tv2 ro3sx2...i m having problem with my tv sound as when i connects to tv through rf in sound dosent come...and when i join a dvd or any...
You have something in the set's menu set wrong--if sound ok with a DVD set is ok---look in menu for something like SAP= most sets have Mono-Stereo-Sap settings.
Sap is secondary audio program which is for a second language to be broadcast (French, Spanish etc.) and if not active there will be no sound on selected channels.
I suspect a careful look will show SAP is engaged and some remotes have a button (MTS etc that will unwittingly get pressed).
Good luck and hope this helped.
Apr 18, 2012 | Televison & Video
MY TURNS ON BUT HAS NO SOUND AND IT SHOWS THE WO RD MONO WHAT DO I DO. MY EMAIL HOSHINO01JAIME@YAHOO.COM
from your remote
Press MTS to select a sound mode if available with the TV programming: MONO,
STEREO, and SAP.
Mar 16, 2011 | RCA TruFlat 27F520T 27" TV
How do I get my rca truflat tv to get out of mono?
Hello
Press the MTS on the remote control handset to select STEREO, MONO or SAP. All the options will be available only when the current TV channel is broadcasting that option. Channels will not always carry programes, that have all MTS options. If "STEREO" appears on the screen when you select a channel means stereo sound is available with current programme. You can hear sound from both speakers. If broadcast is not strong and clear, stereo sound will not be available. Press "MTS" button to change it to "Mono". This will eliminate the noise. If "MONO" appears on the screen when you select a channel, stereo effect will not be availabe, even though you have set it to stereo. If "SAP" appears when you select a channel 'Second Audio Programe' [SAP] broadcasting is available for that programme. Press the "MTS" button to 'SAP' and you can hear that programe in different language or some other kind of audio.
Oct 28, 2010 | RCA TruFlat 27F520T 27" TV
Audio only has mono how do you change it
If you open the menu,there should be an option for sound.If you have a universal remote,you will probably have to do it with the buttons on the TV.SAP and stereo are about the same.It most likely cycles through mono,stereo,SAP with the volume button.Good luck!
Aug 05, 2010 | Sharp Televison & Video
I am getting SAP or Spanish on some stations. How do I change or remove that feature?
Press the Stereo or MTS button on the remote control until the words STEREO appear on screen. There usually are 3 options MONO/STEREO/SAP
Jun 29, 2010 | Orion STV2763 27" TV
No sound on some channels, other channels fine
Your SAP/MTS function is most likely turned on. This feature has 3 modes: Stereo, Mono and SAP. Stereo and Mono are easy to understand, it's the SAP that can get you. SAP stands for Second Audio Production. It is used to provide weather, information or an additional language translation of a program. Some broadcasters simply transmit the mono audio over the SAP audio channel when the are not using it for other purposes. Other broadcasters simply do not use it, which does not give you any audio. Look on your remote for a SAP or MTS button. If you do not see one, look in your TV user menu for this feature. If you are using a cable box, look in the audio menu of the cable box. You are looking for something set to SAP... just change it to STEREO. I hope this was helpful.
Mar 26, 2010 | Televison & Video
I have a durabrand tv and need to figure out how to take sap off the tv. the tv is model DU2701
on the remote there may be a button marked MTS. if so press this button (toward tv) repeatedly till stereo mode displays. otherwise go into tv menu under audio section and scroll to parameter that allows you to adjust mono,stereo, or sap mode. mch
Mar 09, 2009 | Televison & Video
Sharp Aquos LC-32D44U stuck in ""Mono"
I dont know if this will work for you, but its worth a try. I had the same problem.
1. I changed to a station that was having the problem (an analog station with MONO displayed on the screen).
2. I unplugged the TV for about 15-20 minutes. (I was thinking maybe something needed to refresh, so thats why i unplugged the tv.)
3. I plugged the tv back in and voila. The station showed up as MONO then immediately swtiched to STEREO.
After that, i was able to use the AUDIO feature on the remote to actually change from MONO to SAP, etc.
Ive had my Sharp for about 5 months now, and thats the first time its happend to me. Luckily, i solved the problem...this time.
Hope it helps.
Feb 12, 2009 | Sharp AQUOS LC-32D44U 32 in. LCD TV
TV stuck in SAP mode
The link above does not work.
Aug 13, 2008 | Sylvania 6427TE 27" TV
Sharp (friendly series II)
well, i am no tech, you either need to choose one of the 3 above to watch your tv. I have stereo on mine for better sound. hope this helps.
Oct 04, 2007 | Sharp 32C-240 32" TV
Sharp 27C-240 27" TV Logo
217 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
