SOURCE: how much svi 10 high performance suspension fluid
The recommended weight is 5 weight oil.
There is a different oil level depending on spring size.
No mark or three on the top end of the spring is 98mm. Max of 137mm and minimum of 123mm.
Two marks on spring is 94mm. Max of 33mm and minimum of 118mm.
Two sets of two marks (Four) is102mm. Max of 41mm and minimum of 127mm.
This is measured from the top of the tube (pushed down to the seal) to the top of the fluid level.
SOURCE: what is the best gasolone for honda tmx 155
super is the way to go. try using some stabil marine formula gas treatment if your bike does a lot of sitting
SOURCE: honda magna vf750c v45 1982
i put this in my mates 83 magna and it felt brilliant:
right 360 c.c. SAE 10
left 380 c.c. SAE 10
hope this helps
SOURCE: how to clean the honda
The main issue is usually the jets get clogged due to gas sitting in the bowl for extended periods. the simplest solution is the remove the carb and remove the bowl and needle and float. Then, if possible, remove the main jet and air tube and also the idle jet (the smaller one ) (remove the jet from the bottom and gently push the air tube out from inside the carb body). Then clean the jets in carburetter cleaner in a glass jar.over night.
Take a piece of electric "zip" chord and strip back the insulation to expose the wiring which is very fine copper . use one of those strands to clean the jet until you can see through it and see no deposits or roughness. do the same for the idle jet.
reassemble take care on the air tube because it is likely "keyed" in to a certain alignment.
