Question about LG L1717S-BN 17" LCD Monitor
I have two lg monitors on spreat dispaly adapters
I have these two display adapters one is built in and the other one is built out, now there's a lg monitor flatron t711s on the built out, and lg l1717s lcd on the built in, i dont know how ut was workin'?!! but it was workin' till i formated the c: drive and installed winxp sp2, well.....the lcd moniter didnt work and the system sees the built out adapter only of course it cant see both of-em !!! can it?? now i installed the driver to t711s , but i dont have the driver to the l1717s, could this be the problem????? lpz reply to me as fast as u can :) cuz this pc that i formated.....its...THE BOSS'S PC !!!!!! <^_^>
  • 51 Answers
You don't need a driver for the monitors, the native plug and play driver in XP usually works as well as any manufacturer supplied driver. What's happened is XP doesn't recognize the onboard display adapter. If this is a name brand system (you didn't mention what type it is) download the XP display driver from the manufacturer's web site. If it's a custom built system, there should be a motherboard CD that came with the system that has the display driver on it. When all else fails, download System Information for Windows from http://www.gtopala.com/ It will tell you what type of onboard display adapter the system has.
Posted on Oct 04, 2007
SOURCE:
Monitor dispaly picture for 3 to 5 second then display gone
From the description one of the inverter transformers have failed, located on the power supply/inverter board.
May 21, 2012 | Samsung SyncMaster 510N (Silver) 15 inch...
I got recently a Packard Bell -Easy note TX86 ,my question is how can I choose between the Nvidia dispaly adapter and the Intel Display Adapter . Thanks, abraham.
Hi Abraham,
The best way to select an adapter is to connect the monitor/TV cable to the display adapter you want to use or you can go to the Display properties and choose the adapter to be used (you have option to make the display adapter Default).
Thanks and regards,
Anil.B.R
Sep 24, 2010 | Computers & Internet
The display does not expand the entire monitor? i have a 25" monnitor and the dispaly is only using 15"?
You need to setup your monitor for full display. Look at the button in your monitor and press "Auto/Set" (or something similar) then it will start to display as desired. Actually, your 25" monitor has a built-in option to display in several aspect ratio. Please choose a ratio that will fill up the entire screen.
Another one restriction here is your video cards. Some video cards limit display size and resolution.
Feb 08, 2010 | Computers & Internet
When I startup the monitor turns on and off until startup is complete
rite click on the desktop screen
go to properties
go to dispaly settings
go to the display adapter, increase the screen refresh rate to maximum and there wuld be an option there to select to stop this screen flickering to turn off
uncheck it
this shld work
Nov 04, 2009 | Princeton Digital VL1918 Monitor
My LG monitor was fine my daughter played with keyboard now i only get display in the middle its widescreen but its square display only in the middle pls help how to adjust back to wide dispaly mode
well, there are two options
properties------settings and then change the screen resolution which best fits u
OR
if the settings were changed from the monitor then use the buttons on the monitor and there is an option to reset it to default, do that
this should work
Nov 02, 2009 | Computers & Internet
Hi - Received a LG monitor, W53 Series as a gift.
in your laptop there is button press f5 or f6 to get dipaly on lg monitor or you can right click and go to display properties and set the dispaly.
Sep 08, 2009 | Computers & Internet
Can't change the resolution of ACER X193W. All attempts to change the resolution come up with "... not supported". What is the problem?
check in your computer graphic drivers are installed correctly.
If installed then when you power up the computer press F8 key then enter in enable vga mode.Set screen resolution to 1024*768 then apply and ok.
You can set screen resolution in control panel dispaly property.
Jul 14, 2009 | Acer X193W LCD Monitor
No driver
Monitors do not need drivers, the drivers are used on the video display adapter.
If monitor does not display full definition, then it is the display adapter driver.
If the monitor does not display anything, then the monitor is faulty or the cable is not well connected or faulty.
Provide video adapter model to get drivers for your video adapter.
Apr 01, 2009 | Computers & Internet
Monitor dispaly problem
I think this problem appear video o/p section.Dry solder Pl. solder video output section
Jun 01, 2008 | LG Computers & Internet
Open Questions:
See all LG L1717S-BN 17" LCD Monitor Questions
LG L1717S-BN 17" LCD Monitor Logo
206 people viewed this question
Top LG Computers & Internet Experts
Ekse
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
