Question about Aurora Electronics AS1010TX Cross-cut Shredder
Aurora as1010tx shredder won't run unless
For some time now it would stop working until it got jolted in the holding case, or switch on/off quickly. I opened the activate switches, they are fine.I can get it to run as long as I short the orange(power from circuit board)& blue wire(one side of led)& depress both of other two switches,I think it may be on circuit board but have no specs on checking it. If any one can help or know where to get circuit specs?
    Scholar:
  • 102 Answers
You will probally have a tough time getting specs on a pc board from the manufacturer you will probally have to find a service dealer in your area that works on shredders or you will probally need to purchase a new pc board from the manufacturer if they still have one available or you may be able to find one online if you know the item number for a pc board replacement.
Posted on Mar 02, 2008
Its not working and shredder wont turn on
It maybe that the shredder cutters are jammed. Unplug from mains, and lift off top and place upside down. Use a small screwdriver and poke at any compressed paper wrapped around the blades - can take a while. Give a quick spray to cutters with WD40 Replace - turn on - and run in reverse.
If all else fails, contact the maker
Feb 27, 2014 | Aurora Electronics AS1010TX Cross-cut...
How do I remove the shredder head case of an Aurora AS890C? I have removed the 6 screws (it's unplugged), but it still won't come apart. It quit working, so I don't know if it's jammed or...
There are 7 screws. You missed the one hidden under the small silver label.
Once you take it apart, don't waste your time calling Aurora as you voided your warranty and ability to get help from them. That happened to me.
May 12, 2011 | Aurora Electronics AS890C Shredder
My shredder makes a thumpping noise then stop. Inreverse it does the same thing. My model is Aurora AS701X-MS The motor runs but it does'nt shred the paper unless you shake the paper then it stops.
It sounds like one of the drive gears has broken. I have contacted this manufacturer before and was told that they do not make replacement parts for their machines. If it is less than a year old, they will replace the unit but that is about all they will do.
Jun 20, 2010 | Aurora Electronics (AS701X) Shredder
Shredder won't run unless Istrike it on the side.
go buy another one , stick this lemon in the box and return it ! lol
sounds like you got a bad solder joint thats causing an intermitant problem until you bang it and complete the connection,, or a switch inside is bad or dirty , open it up check it out .
Mar 10, 2009 | Techko SH1524CP Shredder
My Aurora AS1010TX paper shredder will not shred paper. It will work in reverse.
If you want to attemp to take the machine apart, there should be a small spoked wheel called a pulse sensor that runs through U-shaped black device.
Blow this out as well as all electric devices inside.
Sep 27, 2008 | Office Equipment & Supplies
Shredding
check door safty switch or is the bag or box full that has a switch also? just a suggestion.
Jun 24, 2008 | Aurora Electronics AS1015CD Cross-Cut...
Overheating
You should probally have the water pump checked if it is not operating correctly it can cause overheating or it could be as simple as a faulty radiator cap
Feb 16, 2008 | Aurora Electronics AS1010TX Cross-cut...
Shredder stops after about 10 minutes
spray the sheddred wheels with wd40 or any lubricant
Jan 18, 2008 | Aurora Electronics AS1010TX Cross-cut...
Aurora Electronics AS1018CD Shredder
I personally work with Fellowes brand shredders, but it sounds like you have a paper feed sensor issue. This may be a mechanical or electronic sensor located in the center of the paper feed slot. If it is electronic it may just need cleaning(qtip dipped in rubbing alchohol. If it is a mechanical sensor check to make sure it has not been broken or it may be stuck because of paper that has become wedged behind it(you may need to jiggle the switch a few times to free it). If none of this works you may have a burned out switch or a bad pc1.gif board, contact manufacturer for more info.
Nov 28, 2007 | Office Equipment & Supplies
Aurora AS1010TX Will run forward for 1/3 of paper then into reverse.
I'm going to say it needs oiling. Try oiling the gears and cutting blades. You can buy paper shredder oil at Office Depot or Office Max.
Jul 10, 2007 | Aurora Electronics AS1010TX Cross-cut...
Aurora Electronics AS1010TX Cross-cut Shredder Logo
318 people viewed this question
Top Aurora Electronics Office Equipment & Supplies Experts
k24674
skiffy99
skiffy99
Level 1 Expert
Dabu42
Level 1 Expert
Are you an Aurora Electronics Office Equipment and Supply Expert? Answer questions, earn points and help others
