I want replace ram ddr 1 by ddr 2 or 3 at my computer Intel D915GAV Motherboard
SOURCE: IS DDR SDRAM IS DDR II RAM OR DDR
No. DDR replaced the SD in RAM so SDRAM and DDR RAM are two completely different things but each ram type has its own frequency hence you get SDRAM 100(mhz) and SDRAM 133(Mhz) just like you get DDR 1 RAM at 266(mhz) and 400(mhz) and DDR 2 RAM at 533(mhz) and 800(mhz). Therefore as you can see how these things differ, but if your mboard takes SDRAM that it can take and frequency of SDRAM but you must ensure that all the frequencies of all your RAM modules in all your slots correspond otherwise you will have problems, meaning that if you decide to use 133mhz RAM then all your RAM modules that you use must be the same. Let me know how you go. thanks
regards
SOURCE: DDR SLOTS INSTEAD OF SDRAM
Good work seeker 1969! Guess what I found???
It took a lot of sleuth work but....
Go HERE for your motherboard manual. :)
It's a zipped Microsoft Word document file. I've scanned it. It's virus-free. All the information that you need is there. Go to page 11 for instructions (including illustrations) for installing SDRAM and DDR RAM.
Please, let me know if this response was "Helpful" or a "FixYa" for you or, of course, if you have more questions, etc on this topic.
If I did not answer your question satisfactorially, please, b4 assigning a "Thanks for Trying" or lower rating to my "Solution", let me know. I may have misunderstood you or the problem you are experiencing. I will work w/ you until your problem is resolved or diagnosed. I promise! :)
Thank you
BJ
SOURCE: ddr 2 ram connecting to intel d101 motherboard
Well first of all, there is no "adapter". You have to use the specified RAM that you motherboard supports. Secondly, even if there was an adapter so to speak, it would not be beneficial. The only difference performance wise between DDR and DDR2 is speed. So if your motherboard supports DDR, and you had an "adapter", your motherboard would only read the DDR2 at DDR speed. In my opinion, DDR2 is not really worth the upgrade to another motherboard just for DDR2. If you want the biggest bang for your buck, upgrade the CPU, or put more memory in the motherboard you already have. Hope this helps, and please don't forget to rate. Thanks.
SOURCE: Max RAM for Intel 102 GGC motherboard
Thanks to Intel website The board has two 240-pin DIMM sockets and supports the following memory features: * 1.8 V (only) DDR2 SDRAM DIMMs with gold-plated contacts * Unbuffered, single-sided or double-sided DIMMs with the following restriction: Double-sided DIMMs with x16 organization are not supported. * 2 GB maximum total system memory * Minimum total system memory: 128 MB * Non-ECC DIMMs * Serial Presence Detect * DDR2 533 or DDR2 400 SDRAM DIMMs Note To be fully compliant with all applicable DDR SDRAM memory specifications, the board should be populated with DIMMs that support the Serial Presence Detect (SPD) data structure. This allows the BIOS to read the SPD data and program the chipset to accurately configure memory settings for optimum performance. If non-SPD memory is installed, the BIOS will attempt to correctly configure the memory settings, but performance and reliability may be impacted or the DIMMs may not function under the determined frequency.
SOURCE: Finding Intel 845GVSR & 915GLVG Compatible Motherboard & Proc
you can use intel dg41 mbd , dualcore processor,1 gb ram,160 gb hdd or use intel atom for support contact 91-9645071021
