Question about Hotpoint Aquarius WMA56 Front Load Washer
No spin i have a wm56 washing machine, there is power, and it fills with water and drains properly, but the drum will not go round, we have checked the belt and that is intact, wondering if the motor has gone????
Sounds like you need. New brushes in the motor.
Just done mine. Very easy to change.
The motor only has two bolts that hold it in and it comes straight out through the bottom. Make sure there is no power to the machine and unplug the motor leads, before removing it.
Your find that its just two screws at the back of the motor, that hold each brush in...
Posted on Nov 03, 2007
SOURCE:
Hi i have a hoover washing machine hnf 6127 it functions perfectly but wont spin the drum goes round on the wash cycles but will not pick up speed on the spin i have checked the filter is not blocked
If it is not picking up speed on the spin cycle then it is the motor or the belt. check the belt first for proper tension and make sure the motor has the proper output. I think something is slipping and not transferring torque to the tub.
Mar 12, 2014 | Hoover Washing Machines
Hotpoint WM56 front loading. Machine makes a deaf inducing noise when spinning in particular.The drum will wobble front to back when pushed by hand and does not seem to sit level with the outer drum, it is...
Ours did exactly the same. The drum bearing's worn and the spider had broken causing a noise like a road drill. Check out the video on Youtube from Apart4U. It's a pig of a job though.
Apr 12, 2011 | Hotpoint WM56 Front Load Washer
The drum doesn;t turn during wash or spin cycle
Kindly remove the back panel of the unit and check whether the belt is properly fixed if it is ok means check the wire connection if everything is fine. kindly check the motor humming sound once the water is filled if you find the humming sound means kindly replace the motor
May 18, 2010 | Whirlpool LHW0050PQ Front Load Washer
Washing machine not washing or spinning
More than likely worn brushes in motor
Remove top cover, and slacken motor bolts holding motor at top right of washer. slide out carbon brush holders in motor, and replace if less than 3 or 4mm long.
This should solve the problem.
Apr 09, 2010 | Hotpoint WM56 Front Load Washer
The drum will not go round
Possible belt snapped or motor brushes need replacing.
Jan 24, 2010 | Washing Machines
Washing machine wont drain keeps bleeping ERR2
It will not spin with water in.
See if you can locate a filter, and clean same.
Jan 19, 2010 | Haier Washing Machines
The machine wheel inside wont go round
I suggest that you remove the motor, and check the brushes in the motor.
If there is less than 3 or 4mm left, then replace them.
Please rate my solution.
Thanks.
Nov 17, 2009 | Bosch Classixx WFL 2066 Front Load Washer
WFD 2460 will not start wash cycle after it has filled with water
Isolate power and water supply and gain access to the main drum motor. Check for condition of carbon brushes by removing them and repla
ce if severely worn. Check wiring loom around motor and right back to module controller. The clicking is obviously power being supplied to motor via the loom to the motor. finally check for any dry solder joints or burnt areas on the circuit board controlling the motor.
Dec 07, 2008 | Bosch Logixx WFT 2806 Front Load...
Hotpoint Aquarius WMA56 Front Load Washer Logo
121 people viewed this question
Top Hotpoint Washing Machines Experts
vince
gbob59
Eric Taylor
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
