Back to:
Tags:
Wireless Adapters
Generic problem for all Wireless Adapters
Wireless Adapters
posted by neilbridge on Oct 04, 2007
I want to connect a Yamaha Clavinova Digital Piano wirelessly to the internet. I purchased a Belkin Router and USB Wireless Adapter, (Models F5D7632-4 and F5D7050). The Router seems to work but the Adapter is not accepted by the Clavinova. Yamaha appear to recommend the Belkin F5D7330 or F5D6050. Before wasting more money on this can someone tell me what the difference is between these various adapters and why manufacturers don't seem to make these differences clear. Thanks
Neil Ogg
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Oct 04, 2007
FixYa! (100)
PCTServices
Rank:Guru Guru
Rating: 85%, 264 votes
The reasons could be numerous really. The clavinova has to have software writen into the memory to interface with that specific wireless card. The easy answer is that they simply can't write in drivers to every possible wireless card of every brand. This is especially true when you are dealing with wireless cards that we're produced after the piano is built. The drivers simply didn't exist when the manufacturer made the driver support for the piano.
Wireless cards aren't plug and plug even on a computer, they need drivers, and this goes without saying on a device like a piano. So without the ability to upload and install software/drivers onto your piano you've got to deal with the driver support they built into that model.
A more technical answer to the question would be the difference in internal chipsets these wireless cards have can make a huge difference. Wireless networking technology is a HUGE market right now and the companies that supply them change the internals literally almost monthly. This is based off the cost of the parts needed to built the unit fluctuating and the features needed to be built into the device. For example a linksys router with the same model number wrt54g has over 8 different versions with different chipsets in each one.
Some budget chipsets aren't as good as others. They don't get as good signal, and it's not easy / possible to make a robust driver selection for them. This can lead to the problem you're encountering. You have 2 wireless cards that on the outside look like any other wireless card, but on the inside may not have a chipset thats as good as some others in terms of hardware.
Manufacturers generally make these changes in chipsets based off the bottle line price. If they can purchase a similar chipset from a company for cheaper they are going to do it to make more profit. Most networking companies to not list the differences in chipsets at all. It's pretty much up to the enthusiast crowd to take them apart and find out who made the chips, what operating system they run, and what specs they have. This information can sometimes be found on the internet with the more popular hardware, but sometimes the obscure or less special stuff can get ignored. In the end there isn't really a sure fireway to find out the specs of every piece of wireless hardware on the market.
I hope this has explained your question in detail. If I've helped you please don't forget to rate me.
Peter
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Wireless Adapters:
I don't want to Accept this solution
Can you Help with these Wireless Adapters problems?
Generic Memory (WLG1203) Wireless Adapter
I do not have the original installation disc (lost it)....
Linksys Rangeplus Wireless Pc Adapter
I have Windows Vista and bought the Rangeplus PCI adaptor,...
Vodafone Mobile Connect (055270) Wireless...
I am using a Blackberry locked for vodaphone use only. I...
fastinnerhtml!
fastinnerhtml!
Loading problems.
Repair Service
Find Wireless Adapter Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
