Question about Nikon F60 35mm SLR Camera
Nikon F60 Film rewind uncoded film help
My photography teacher put a non DX-coded film in my camera [=/] and now I want to remove the film cause it doesn't work. but i don't want to just pull the film out cause i don't want to damage the camera but it won't rewind even when i press the film rewind button..i can't even take photos to get it to go forwards then rewind like that..help!?
  • MissBB Oct 04, 2007
    okay don't worry, managed to get it out!
  • ereena Jan 06, 2008
    I am getting my automatic camera fixed and in the meantime I have to use a manual camera. The only thing I don't know how to so is rewind the film and I don't have th camera's manual. Please help me.
  • 148 Answers
It sounds to me as if the film has broke inside the camera. For it to have no DX coding on, I can guess it was a very old film, or it was a hand-wound cartridge. both are likely to cause issues.
Posted on Dec 12, 2008
  • 44 Answers
Most manual cameras have a button to release the film on the bottom of the camera, push the button in and turn the rewind crank (left side of the top of the camera) until you feel the crank suddenly turning much easier.
How do I clean the DX contacts/censors
If you think the contacts are dirty or oxidised, you could try to clean them with a cotton swap and a prop of contact oil. But be sure you can remove all the oil you apply.
Be aware to move the contacts as little as possible. You are allowed to pus them in, but move them sideways can cause them to lose the correct position or worse they can be broken.
It is great to see, Nikon USA, still has lots of manuals of the elder SLR camera's
Jan 12, 2014 | Nikon N2020 35mm SLR Camera
Im the one with the Maxxum 3xi iso problem ... Our teacher gave us film with 400iso but we have to change the iso to 100 to shoot the roll..
If you use DX-coded film between 25-5000, the camera sets the ISO automatically to match the film. If you use non-DX-coded film, the ISO is automatically set to 100 ISO.
Jan 13, 2011 | Cameras
How do i rewind the film in my nikon n2020
Set the film advance mode selector to L.
While sliding film rewind lever, push film rewind button.
Fold out film rewind crank and rotate until film advance indicator stops moving.
If you don't have a manual, you can download one from http://www.butkus.org/chinon/nikon.htm
Feb 13, 2010 | Nikon N2020 35mm SLR Camera
Problem with loading film in my Nikon F60.
Draw the film all the way to the receiving spool. There's an 'eye' inside the film compartment to check that the film is loaded. When the film is not correctly loaded the camera thinks it's empty and rewinds the film.
Aug 08, 2009 | Nikon F60 35mm SLR Camera
How so I inaert film
I'm not familiar with your exact model so what follows is generic to many film SLR cameras and assumes that the camera is already empty:-
Open the back of the camera by pulling upwards the rewind crank on the top left hand end of the camera (as viewed from behind). The back of the camera should pop open a little, open it all the way.
Before fitting the film, check if the film can is DX coded. It will have DX printed on it somewhere if it is, but will also have a large area bare metal squares interspaced with printed black squares or rectangles. if the film is not DX coded then look for an ISO number, ASA number or DIN number and note it somewhere.
Drop the roll of film into the space at the left of the camera, and push the rewind crank back down to secure the film canister. Pull out the film leader across to the right hand end of the camera. Often there are printed instructions or diagrams showing what to do. Your camera probably has an easy loading system in which you pull the film leader until it's level with a printed line and then close the camera back until it clicks.
Turn the camera on, normally it will staert whirring as it autoloads the fil onto the take up spool. If successful the number one will appear in the film counter display within a few seconds. If not then open the camera back and try again.
What you do next depends on whether the film is DX coded or not. There will either be a dial or a menu item which allows you to set the film speed, for DX coded films set the control to DX or to AUTO. If the film is a rare non DX-coded one then you need to set the speed manually. Select the correct ISO number in the menu. If your film had an ASA number then use it as an ISO number and if it had a DIN number then look up DIN to ISO conversion online.
If this has solved your problem then please return the favour by rating my answer, thanks.
Jun 30, 2009 | Minolta Dynax 404Si Film Camera
Putting film into nikon f60
It is fairly simple. Insert the film canister with the hole side (not the projection) down. Insert the spool of the camera into this hole and slide the canister inside the chamber. Now pull the film out slightly so that the leader (the narrow portion at the end of the film) aligns with the orange mark at the lower right end of the film chamber. Make sure there is no slack in the film. Close the door and turn on the camera.
Mar 13, 2009 | Nikon F60 35mm SLR Camera
Film rewind
For some reason the camera thinks it is at the end of the roll. You could turn off auto rewind, Custom Menu #1, to 0. This issue could manifest itself in cold weather as well, film becomes too stiff causing drag tripping the auto rewind. Call Nikon Film 1-800-645-6687. The camera may need to go in for CLA.
Feb 06, 2008 | Nikon F100 with 28-80 and 70-300 lens 35mm...
Nikon N50 SLR film
Hi: You may want to try changing the aperature setting,or removing the lens,then re-installing the lens. Good luck.
May 29, 2007 | Nikon N50 35mm SLR Camera
Premature Film Rewinding
the only thing that I could think of when I read your situation is, that you might not be using a DX coated films. see, the camera reads the bar code on the film and maybe it is not the same program. check the camear manual and make sure you are using the same kind of the suggested film in the manual. good luck
Apr 11, 2007 | Nikon N65 35mm SLR Camera
N75 will not load film
Quick solution: force a manual rewind.
1. Remove film
2. Close camera back.
3. With the power turned on, press the two rewind buttons together. They are marked in red.
4. The camera will make a rewind sound and will stop after about 2 seconds.
5. DO NOT fire the shutter yet.
6. Put the mode on Manual and select a fast shutter speed like 1/90 sec. Any aperture will do.
7. Load the film correctly as given in the user's manual.
8. As you close the camera back, the film will prewind to the end of roll. At the end of the roll pre-wind the LCD will show you the total number of frames available.
9. Select any shooting mode.
10. Go on and take pictures.
Hope this helps
Dec 14, 2006 | Nikon N75 35mm SLR Camera
Nikon F60 35mm SLR Camera Logo
170 people viewed this question
Top Nikon Photography Experts
pontelemon
pontelemon
michael galang
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Nikon Photography Expert? Answer questions, earn points and help others
