Question about Whirlpool MH7140XF Microwave Oven
Microwave malfunction Microwave operation light and sound appear normal, but no cooking takes place.
  • 209 Answers
This could be a diode between the capacitor and magnetron, (its like a fuse) i do not recommend self repair, but give you this info as a guide to what maybe wrong, microwaves contain high voltage and care should be used if you do attempt repair hope i have helped a little
Posted on Oct 04, 2007
SOURCE:
Maytag microwave MMV4205BAW interior fan continues to run when door is closed
One of the micro switches has malfunctioned, and must be replaced for normal operation.
Apr 02, 2012 | Maytag Microwave Ovens
GE Spacemaker XL1800 Microwave
see for the turn table obstacle of any screw or something else.
Aug 04, 2008 | Samsung MW1030WA Microwave Oven
My GE Spacemaker Microwave Oven appears to be working normally (light comes on, table turns, sounds normal), but it doesn't cook anything. Might there be an easy fix to this problem?
Unscrew the screws holding the exterior shell to the unit, then lift off. Now unplug the magnetron and take it in the shop to match up the #s so you can get an exact replacement. Now install the new part and you should be re-heating left overs in no time. Make sure you discharge the capacitor before poking around inside or you will shock the hell out of yourself. Unless your sadistic and like that sort of pain, then forget about the last suggestion.
Nov 11, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
My JVM1653 stopped cooking, The turntable turns
your magnetron might be out. its what heats
Feb 13, 2010 | GE JVM1653 Microwave Oven
Microwave still continues after cooking time is ended
It is the fan. Im guessing it only happens on combination cook and not when you are only using the microwave setting. It happens because the oven is hot and it helps to cool it quicker. It is normal. The microwaves are not working and neither is the oven-just the fan.
Mar 31, 2009 | Oster 0.7 Cu. Ft. Compact Microwave
Whirlpool microwave only cooks for limited time?
It's possible that the module that produces the microwaves is failing. The parts are cheaper but the labor may not so get an estimate before deciding if it's worth repairing or replacing.
Nov 20, 2017 | Whirlpool GH5184XPQ Microwave Oven
Wow. A shocking tale...
It sounds to me like they're guessing ("shotgunning" as it's called) and don't have a clue how a microwave works or how to fix one.
They can't possibly be a Whirlpool-authorized service center can they?!
They apparently replaced two parts that did not fix it, so they should not charge you for those parts, or they should put your old parts back in. What are the odds they would have them still?
If you've not paid them any (or much) money, I would tell them to keep the oven and buy yourself a new one.
If you have paid them anything, I would insist on a full refund and your microwave back with all your original parts (if available).
If you hired someone to paint your house, and they only painted your window panes, should you pay them for the labor or the paint??
But to be honest, I would not trust this shop as far as I could thrown it. If you do get this oven out of the shop, the next servicer may find a whole lot of bad parts all of a sudden... Know what I mean?
If they give you any more trouble, I would go straight to your State Attorney General's Web site and file a complaint with their consumer protection division (or at least threaten the shop with this action).
A State government's Web site is at www.state.xx.us or www.xx.gov where xx is replaced with your Stat's official two-letter abbreviation.
Good luck.
Oct 23, 2008 | Whirlpool MH2155XP Microwave Oven
Maytag Rangehood Microwave Loud Humming
Sounds like you just fried your magnetron. Normally when they go bad, they make a very loud noise like what you described. The smell concerns me because you may have ruined the waveguide as well. If the magnetron burns through the protective painted surface of the waveguide, the waveguide is ruined. In most microwave ovens this means replacing the entire unit because the waveguide is not replaceable. Putting a new magnetron in a damaged waveguide will result in the same arcing and eventual failure. In addition to the magnetron, the following components are part of the same high voltage network: HV Transformer HV Diode HV Capacitor Magnetron Thermal Cut-Out Any one of these components could have also been damaged. I DO NOT recommend taking any voltage measurements inside the HV network. Potentials of over 4000 volts can be reached and make it very dangerous for the do-it-yourselfer. Taking resistance readings with the unit unplugged is strongly encouraged. If you decide to pursue a repair, inspect the magnetron tip and inside of the waveguide first. If the magnetron is melted and/or there are burn marks inside the waveguide, a new microwave may be a in order. This actually may be a better option than an expensive repair. I hope you find this advice helpful.
Jul 31, 2007 | Whirlpool GH4155XP Microwave Oven
Cooks fine, but fan & carousel run slow and light is dim
It sounds perfectly normal. A microwave generally draws about 13 amps or more when cooking at full power. That's a considerable amount. This current draw will actually "load down" the power line, resulting in a small but measurable drop in the voltage. The decreased voltage means the light will be dimmer and the motors for the fan and turntable will run a bit slower. BUT if you ever have _chronic_ flickering, dimming or brightening lights in your home, it could be the result of a bad connection on the neutral, etc., which can lead to a very dangerous condition. Once in a while is okay, but if it happens a lot, your landlord or electric company should examine the lines.
Apr 24, 2007 | Sharp R-401CW Microwave Oven
Whirlpool MH7140XF Microwave Oven Logo
249 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Steve Allison
Steve Allison
Jaime Hernandez
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
