Question about HP PSC 2175 All-In-One InkJet Printer
Juddering When I turn it on it makes a juddering sound and won;t otherwise function. The sound doesn't stop if I press cancel etc. I've had this before over the years with this marvellous printer and it has always gone away if if I just leave it overnight - but this time not. This time it started after I changed the cartridge but there was no paper in it to print the test sheet - then the juddering started. Anyone else had this? Any ideas? Thanks
  • puttputt2 Nov 12, 2007
    1. When I turn it on it makes a juddering
      juddering started.
      Thanks
    Genius:
  • 1,003 Answers
Okay TRY THIS: open printer cover (printer unplugged) LOOK FOR A LARGE SILVER BAR THAT THE INK CARTRIGES RIDE ON .
APPLY two or three drops of 3 in 1 oil to the top of this bar close cover and plug back in the wall see if this helps.
Posted on Jan 17, 2008
SOURCE:
PC won't stay on, doesn't make it past the boot up menu
the fan on the CPU working? Try a different power supply the one you have might be faulty
Nov 18, 2012 | HP Computers & Internet
My htc incredible s won't charge, I've tried
It sounds like the charging port on your phone is broken. This could have happened a number of ways. Either by dropping your phone, putting the charger in wrong, or taking it out wrong. If you call HTC(866-449-8358) and it is still under warranty they will probably fix it for free as long as it doesn't have any water damage(http://www.ehow.com/how_4479971_check-cell-phone-water-damage.html). Otherwise you could also get a new phone.
Oct 19, 2012 | Cell Phones
Frigidaire Affinity ATF7000E Front Load Washer won't stop spinning with 1 minute on timer- it continues until I hit cancel. I don't like to babysit a machine but have to make sure it doesn
If the unit is washing properly, as far as you can tell, but it won't stop spinning, then I would have a professional look at the control panel and timer to be diagnosed because there seems to be in miscommunication.
Sep 14, 2012 | Frigidaire Affinity ATF7000E Front Load...
How do i get the flashed turned on
First, check to make sure you're not in the macro mode. There's a slide switch on the end of the camera, near the SD card slot. Slide the switch away from the flower toward the mountain to take it out of macro mode. The flash won't fire in macro mode.
Then, if the flash still doesn't fire, take a look at the flash mode. Press the up-arrow button to bring up the flash menu. If it's currently set in the lightning-bolt-in-a-circle-with-a-slash-through-it symbol, you've got the flash turned off. Set it to the lightning-bolt-and-"A" for automatic flash or the lightning-bolt for forced flash.
If the flash still doesn't fire, then it's broken.
Sep 10, 2011 | Vivitar ViviCam 5024 Digital Camera
My RCA XL100 is hooked up to cable and works perfectly fine. We've had it for ages and the picture is clear, sound is beautiful, and it gets along fine with my universal remote. There's just one...
Some of their very old sets the video input was located on channels in the 90's; Try scrolling down from 99 to 90 to see if you locate the video input; this is just the way they did things in the older sets.
Before you rate this solution let me know what you find first.
SD TECH
Jul 08, 2011 | RCA Televison & Video
Our bread maker doesn't heat at all, it will make the bread then just turns off. We've had it for about a year, we've made 10 loafs, maybe. Those were some expensive loafs of bread :( Any...
Contact [email protected] for a service center near you.
Otherwise, try to reboot your breadmaker's computer by plugging it in then pressing and holding the Stop/Pause button down for at least 3 seconds.
Hope this helped. ;)
Jun 10, 2011 | Cuisinart CBK-200 Bread Maker
Dishwasher won't run. keypad buttons light when pushed, and I've locked and unlocked the keypad, which seems to be otherwise functioning normally. It has been working fine until now. I push...
Hello, welcome to FixYa. If you can provide the model number (usually on inside of door frame or tub frame around door opening) and make/brand name, I'll see what I can find for you. It does sound like a door switch, but I'll need to clarify the make & model before moving forward. Regards, Macmarkus :)
Jun 04, 2011 | Dishwashers
HP PSC 2175 All-In-One InkJet Printer Logo
75 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
