Question about Sharp AL 1631 Copier
F2 maintenance B required sf 2540 sharp photocopier what should i do?
  • 62 Answers
This is a drum code either the dm or id sensor.
Posted on Oct 09, 2007
  • Kevin Shearer Oct 09, 2007
    Also check the drum count if over 160,000 copies the drum needs replace.
    Problem Solver:
  • 8 Answers
Its a shame as I dont think you can cheat this unless you have a new IC.
Posted on Mar 01, 2009
43-2
Posted on Oct 23, 2008
  • 163 Answers
Please clean the drum unit or make the program, c interrupt o interrupt .press 44 copy key 7 copy key, after it you can make copies or check toner motor connector or at the last if no result change the drum
Posted on Oct 05, 2007
SOURCE:
My sharp SF-2540 it has a code H5-02
its an error code for the fusing unit
Sep 06, 2016 | Sharp SF 2540 Copier
Sharp 2540 code f2
F2 mean toner not supply .Change toner chip
Jul 12, 2014 | Sharp SF 2540 Copier
After powering on, it will show F2 on the Sharp SF 2540 Copier, So please, I need a programme code to clear it or any other solutions to solve it problem
You need to take it to a Sharp technician to check machine , usually a toner issue that toner is unable to replenish in developer unit and so blows the chip on toner cartridge ,
replacing toner cartridge rarely helps
seeing as it is a deeper issue
Sep 12, 2013 | Sharp SF 2540 Copier
What is error F2 in sharp copier machine?
F2 in sharp means, aproblem related to toner supply make sure the proper catridge is inserted, check with another toner catridge to make it clear that crum on the toner catridge is still good, then if the problem again continues you try to change the developer, next is ATC sensor and the next is developer unit if you have any queries feel free to contact me and rate me
May 03, 2011 | Sharp SF 2540 Copier
I have sharp AR-163 it indicate f5 error. And Sf 2030 error code f2
Ar163 F5 = Copy lamp problem.
Possible causes are:
Blown Copy Lamp
Inverter trouble (copy lamp driver module)
MCU Board failure
This is most likely to be a blown copy lamp.
Ar2030 F2 is a process control error - depending on the sub-code it could be a number of different things. Please repost with the full code.
Hope this helps.
Feb 09, 2011 | Sharp SF 2540 Copier
Sharp sf 2530 hang
I would suggest to throw that old thing in to a pond see if it will float..
Oct 24, 2008 | Sharp SF 2540 Copier
Sharp sf.2540
Press C - interrupt - 0 - interrupt - flash
and then
14 and press start
Feb 26, 2008 | Toshiba e-Studio65 Copier
My sharp sf 2022 machine, i need solution
mr engineer please check the drum mark sensor and clean it and also check the check the toner motor connector and do this program    c interrupt 0 interrupt ,44 copy key 07 copy key after stoping the machine off and then on but first clean drum unit maintenance code is 20 then copy key and then three times ca ca ca
Oct 18, 2007 | Sharp AL 1631 Copier
Sharp AL 1631 Copier Logo
187 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
amir hamza
amir hamza
k24674
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
