Question about Epson Stylus CX3200 All-In-One InkJet Printer
The printer is not taking the paper
My printer is not taking the paper, i have tried reloading the paper but it looks like the 'roller' is not catching it. I am in desperate need for my printer so if anybody can help PLEASE ASAP. Thank you
  • Anonymous Feb 22, 2008
    I have this problem the paper won't feed and it makes an awful noise..any suggestions.
  • Anonymous Jun 12, 2008
    MY PRINTER
    Scholar:
  • 94 Answers
Hi, please try the following to resolved that issue:
1. Turn the printer off and check for paper jams or any obstruction inside the printer.
2. Adjust the platen lever or left edge guide, make sure it was setead correctly as paper will fit to the paper feeder.
3. Reload paper and try printing.
If all of those steps above wont resolved that issue, your printer is needed to send to the nearest service center in your area.
--->> Tirzo
Posted on Jun 12, 2008
SOURCE:
WHILE TROUBLESHOOT THE SAMSUNG PRINTER SHOWS ERROR LOW PAPER
some copier needs more paper loads for it to function. must try. it could work.
Oct 09, 2018 | Samsung Office Equipment & Supplies
Errors with my Printer/scaner
Jessica:
This could be one of a few things... First, Windows 8 is a completely different animal from Windows XP! Try reloading your printer driver in Windows 8. If this doesn\'t work, you need to clean the paper pickup rollers at the front of the printer (where the paper first feeds into the machine. I use a Q-tip moistened (not sopping wet) with rubbing alcohol... gently scrub the whole pickup roller and then the feed roller next to it. Check carefully (with a flashlight) for any shards of paper that might be blocking the paper path. There is also a sensor flag (small finger of plastic) sticking up that the paper must hit to let the printer know that the paper is feeding through. If you do not see the sensor flag, it is either jammed or has been broken off when a piece of paper was pulled backward out of the paper feed area. First reload the printer driver, and try to print. If it doesn\'t print, check and clean the rollers and look for the sensor flag.
May 31, 2014 | HP 1050 Plain Paper Inkjet Fax
My printer wont recognize paper
Remove all of the paper from the tray and shine a flashlight into the printer. Look for any torn pieces of paper or other debris that could be blocking the paper sensor.
Pull the paper guides back as far as they will go, then reload the paper tray. Push the paper guides until they are tight against the paper on all sides. If the paper guides are loose or not properly adjusted, the printer may not sense that the paper is in place.
Look inside the printer if you have a unit with a single paper tray. Locate the print rollers, then look for a small plastic flag that moves up and down when the paper feeds into the printer. Jiggle this paper flag until it moves freely. If the paper flag is out of place the printer may not recognize that there is paper in the tray.
Pull each tray out of the printer carefully if you have a unit with multiple trays. Find the print rollers and the paper flag. Jiggle the paper flag until it moves up and down freely, then replace the tray.
If you need any technical help on printer then you can reach at http://www.vtechsquad.com/
Feb 22, 2013 | Epson stylus nx110 All-In-One InkJet...
No matter how much paper is in the tray the printer will not feed paper. I can't figure out how the printer grabs the paper. any help?
Open the rear of the printer and turn the rollers with your fingers to make sure they are free rolling.Look in the manual for proper loading of the paper tray and try reloading the paper
Sep 28, 2009 | HP Deskjet 6980 InkJet Photo Printer
Cartridge error on 4225
Remove the jammed paper. Unplug the printer from the mains and PC. Inspect the rollers, etc for tiny paper piece(s) that may be stuck, or other debris. Try to clean rollers and make sure they are dry.
Keep printer unplugged for about 2 minutes and replug and try a test print.
Also make sure that you have waited long enough for the printer to heat up before giving a print job.
Finally, it could be an issue with the paper sensor. If this is the case, you will probably have to take the printer in for servicing..
Aug 22, 2009 | HP OfficeJet 4255 All-In-One InkJet...
Keeps saying out of paper but is not how can I reset, I have tried reloading paper, and have turned of power, and disconected network cable, then restarted but still no use. How can I make a default reset
Remove the jammed paper. Unplug the printer from the mains and PC. Inspect the rollers, etc for tiny paper piece(s) that may be stuck, or other debris. Try to clean rollers and make sure they are dry. Keep printer unplugged for about 2 minutes and replug and try a test print. Also make sure that you have waited long enough for the printer to heat up before giving a print job. Finally, it could be an issue with the paper sensor. If this is the case, you will probably have to take the printer in for servicing.
Aug 19, 2009 | HP Officejet Pro L7580 All-In-One InkJet...
Printer not picking up paper from paper tray
1). take all the paper out of the paper tray.
2). look at the printer pickup roller while you enable the printer to print a test page.
3). if the roller is not turning, and hear click sound, then you need to take the printer to be service. The gear that runs the pickup roller is broken.
4). if the pickup roller truns, but you still hear the click sound, then most likely the secondary roller gear is broken. You still need to bring it to be repair.
call the repair shop and find out how much it cost and how long, It is cheaper to get a new printer than to have it fixed.
Jun 03, 2009 | HP Photosmart C6100 All-In-One Printer
I receive out of paper message with paper loaded and ready
Try these steps :
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button. (On the X83, press the Select button.)
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Jan 27, 2009 | Lexmark X5150 All-In-One InkJet Printer
Paper jam
If Hp laserjet change rollers? If any kind of printer roller get rubber rejuvination liquid at an electronic store.
Oct 23, 2007 | Brother MFC 8500 All-In-One Laser Printer
Reload printer error
Try removing the paper tray, and look under where the paper goes. You should see a rubber pick up roller. Try cleaning it with a rag and some rubbing alcohol. The roller is probably slipping and not carrying the paper in far enough! Good luck John
Jul 10, 2007 | Brother MFC-5840CN All-In-One InkJet...
Epson Stylus CX3200 All-In-One InkJet Printer Logo
248 people viewed this question
Top Epson Office Equipment & Supplies Experts
Inky Fingers
Inky Fingers
Clive
Clive
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
