It sounds like that memory should be compatible with your tablet PC. It may be a bad memory stick -- try to replace it with a different memory stick (preferably from a different manufacturer) and see if it still gives you the same problem.
If you didn't have this problem before you installed the new memory, a different memory stick will likely correct the issue. You can also try removing the new memory and see if the PC boots up like it should.
Try pressing the clean cell now button & check pre filter button at the same time hold buttons down at the same time for about 5 seconds with the air cleaner turned of and blue screen lit
Try taking out the hard disk, plug in power and see if you have a display on your screen or external monitor. if same thing happen, try taking out the memory card. If you hear a beep sound it's a faulty mem. card, if no beep sound appears I suspected it's a motherboard faulty.
