My DLP projector HP vp6110 is not working. When i powered on the fan and the lamp is working.But there is no menu or color screen from the projector.Only the white light is being projected.The warning lights for both high temp and bad bulb is off.
SOURCE: Both the LAMP/COVER and FAN/TEMP indicator lights come on, not blinking
with both lights solid. according to the manual all it says is (there is an electrical failure inside the unit, please take to an authorized servicer). if you are able to do this yourself you will need the schematics and a voltmeter to start testing your voltages. your lamp is fine so dont waste your money replacing that anymore. if you would like the service manual send me an email to [email protected].
SOURCE: Permanent Coloured tint
When the image turns pink, we find that replacing the cable between the projector and the lap top fixes the problem.
SOURCE: Bad Lamp lights even with new bulb.
confirm that it is not made in china-because some chinese lamps is not good in life time.
SOURCE: VPL-fx51 Sony projector "Please replace the lamp"
Hi there
It is quite easy to reset the lamp timer nd remove the prompt.
Start up the Projector and hold down the right and left scroll buttons on your remote and then press Menu.
This will reset the timer.
SOURCE: how to check for lamp life of my mitsubishi multimedia Projector xd 450u (DLP)
This should work:
How to reset the operation time meter
Plug in the power cord, switch on the projector, and
reset lamp time by pressing the (left and right arrow) and POWER buttons on the control panel simultaneously.
Important:
• If the 3 buttons was not pressed at the same time,
the lamp time may not be reset.
• Please confirm the TEMP indicator illuminates
about 2 seconds and the lamp time has been
reset.
• The projector will not turn on if you do not secure
the lamp lid.
• You must reset the operation time meter after you
replace the lamp.
• Do not reset the operation time meter unless the
lamp has been replaced.
